i have nothing found about this problem …
In my sample application i have created two CPU-threads … the first one will generate some texture-data inside OpenGL and register them with the cudaGraphicsGLRegisterImage function …
The second thread should do some work on this registered texture-data and will at first try to map the registered texture-data with the cudaGraphicsMapResources function. If i run the program single-threaded, so Cuda stuff and openGL stuff runs in a single CPU-thread, all will be fine. If i try to do the Cuda-Work inside a separte CPU-thread the cudaGraphicsMapResources function returns an cudaErrorInvalidDevice error.
So my questions are:
- Is it possible to register the texture-data and map/unmap this data in seperate CPU-threads?
- I’am not sure about that cuda-context stuff … i use the “CUDA Runtime API” and do not mixing up with the driver API! … so since Cuda 4.0 there should be one Cuda-Context for the whole process (all subsequent threads) which is bind to one cuda-device. Is this right? And if so … are the registered OpenGL resources acessable from any CPU-thread (and therefore same Cuda-context) inside this Process?
I’am using CUDA-SDK 5.0 with one cuda-device and my sample program runs well if CPU-single-threaded.
With best regards, Torsten
