[OpenMP][nvc++] "Duplicate name in reduction clause" error with recent SDK
How I should understand this error message:
nvc++ -mp -target=gpu condition_reduction.cpp -o test && ./test
NVC+±S-0155-Duplicate name in reduction clause - sum (condition_reduction.cpp: 9)
NVC++/x86-64 Linux 23.5-0: compilation completed with severe errors
The code is:
#include <iostream>
int main()
  bool kernelOnDevice = false;
  int sum=0;
  //std::cerr << kernelOnDevice << std::endl;
  #pragma omp target teams distribute parallel for if (kernelOnDevice) reduction(+:sum)
  for (int num_face=0; num_face<10000; num_face++)
      sum += 1;
  std::cerr << sum << std::endl;
  return 0;
It worked fine with SDK 22.1. It works if I remove the conditional “if (kernelOnDevice)”.
Thanks,
Hi pledac,
Thanks for the report. This does look like a regression in 22.5, hence I added a problem report, TPR #33727, and sent it to engineering for review.
Note that changing the order, i.e. moving the “if” clause after the reduction, works around the issue as well.
% cat test.cpp
#include <iostream>
int main()
  bool kernelOnDevice = true;
  int sum=0;
#ifdef USE_IF_ORDER1
  #pragma omp target teams distribute parallel for reduction(+:sum) if(kernelOnDevice)
#elif defined(USE_IF_ORDER2)
  #pragma omp target teams distribute parallel for if(kernelOnDevice) reduction(+:sum)
#else
#endif
      sum += 1;
  return 0;
% nvc++ -mp=gpu test.cpp -w -V23.5 -DUSE_IF_ORDER1
% nvc++ -mp=gpu test.cpp -w -V23.5 -DUSE_IF_ORDER2
NVC++-S-0155-Duplicate name in reduction clause - sum (test.cpp: 13)
-Mat
Hi Mat,
Again, thanks for the quick reply and for the tip to permute “if” and “reduction” !
Unhappily, my C++ IDE (clion), rewrite the code like that and compiler complains:
    if(kernelOnDevice)
So the only option for now to me is to duplicate the code as:
if (kernelOnDevice)
       sum += 1;
else
       sum += 1;
Thanks again, and hope this regression will be fixed.
Is the “if” clause on a new line or is it just how it’s shown in the post?
If it is on a new line, then it’s no longer part of the pragma so yes, this could cause an error. You’d need to add an escape character at the end of the pragma in order for it to continue to a new line.
Indeed Mat, you are right, I can add \ at the end of the line. Thanks.
Hi pledac,
Apologies on the lateness, but I wanted let you know TPR #33727 was fixed in the 23.9 release.
-Mat
