Opensm start failed
# systemctl start opensm
Job for opensmd.service failed because the control process exited with error code.
See “systemctl status opensmd.service” and “journalctl -xe” for details.
# journalctl -xe
Apr 11 14:22:43 ss16 OpenSM[4759]: /var/log/opensm.log log file opened
Apr 11 14:22:43 ss16 OpenSM[4759]: OpenSM 5.10.0.MLNX20211115.e645cc83
Apr 11 14:22:49 ss16 opensmd[4750]: Starting IB Subnet Manager…[FAILED]
Apr 11 14:22:49 ss16 systemd[1]: opensmd.service: Control process exited, code=exited status=1
Apr 11 14:22:49 ss16 systemd[1]: opensmd.service: Failed with result ‘exit-code’.
Apr 11 14:22:49 ss16 systemd[1]: Failed to start LSB: Activates/Deactivates InfiniBand Subnet Manager.
– Subject: Unit opensmd.service has failed
– Defined-By: systemd
– Support: Red Hat Customer Experience & Engagement - Red Hat Customer Portal
– Unit opensmd.service has failed.
The result is failed.
# cat /var/log/opensm.log
Apr 11 11:38:10 408527 [58783740] 0x03 → OpenSM 5.10.0.MLNX20211115.e645cc83
Apr 11 11:38:10 408553 [58783740] 0x80 → OpenSM 5.10.0.MLNX20211115.e645cc83
Apr 11 11:38:10 410916 [58783740] 0x02 → osm_vendor_init: 1000 pending umads specified
Apr 11 11:38:10 410948 [58783740] 0x02 → osm_vendor_init: 1000 pending umads specified
No local ports detected!
# ibstat
CA ‘mlx5_0’
CA type: MT4127
Number of ports: 1
Firmware version: 26.32.1010
Hardware version: 0
Node GUID: 0xb8cef6030083c020
System image GUID: 0xb8cef6030083c020
Port 1:
State: Active
Physical state: LinkUp
Rate: 25
Base lid: 0
LMC: 0
SM lid: 0
Capability mask: 0x00010000
Port GUID: 0xbacef6fffe83c020
Link layer: Ethernet
CA ‘mlx5_1’
CA type: MT4127
Number of ports: 1
Hardware version: 0
Node GUID: 0xb8cef6030083c021
Port 1:
State: Active
Rate: 25
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0xbacef6fffe83c021
Link layer: Ethernet.
I think it needs to be changed to ib mode.
