I have used a Jetson Nano to run a model for object detection, at the beginning I ran the inference system on my laptop and the timing I got for the prediction was pretty low (~1 sec) the thing is that I switched the model as it was to the Jetson Nano and I ran it to test (without any optimization)the timing I would get and for prediction it took about ~10 seconds.
can I get support in order to optimize the timing for my system? the details are:
Framework: Tensorflow.
Architecture: R FCN.
inference: ~10 Sec.
I suppose that we may use Tensor RT to improve efficiency and timing, however I would like to know if there is something already done that can be leveraged or if we can get the support to improve it.
also, my assumption is that the Jetson Nano has been developed to run ML algorithms, so if I can get literature and examples on how to take advantage of the hardware as much as it can be done I will be grateful.
thanks!
Luis G.
