Originally published at: Optimizing Data Movement in GPU Applications with the NVIDIA Magnum IO Developer Environment | NVIDIA Technical Blog
Magnum IO is the collection of IO technologies from NVIDIA and Mellanox that make up the IO subsystem of the modern data center and enable applications at scale. If you are trying to scale up your application to multiple GPUs, or scaling it out across multiple nodes, you are probably using some of the libraries…
