Oracle - generating combination of numbers
Will give GPU processing needs to be done to it.
Because CPU processing for a long time.
Code: SQL Plus Oracle - OraDB12c
CREATE OR REPLACE FUNCTION my_func
(p_digits IN VARCHAR2)
  RETURN	    SYS.ODCIVARCHAR2LIST PIPELINED
AS
BEGIN
  FOR v_rec IN
	 (SELECT  DISTINCT REPLACE (SYS_CONNECT_BY_PATH (digit, '*'), '*', '') digits
	  FROM	  (SELECT  LEVEL i, SUBSTR (p_digits, LEVEL, 1) digit
		   FROM    DUAL
	   CONNECT BY LEVEL <= LENGTH (p_digits))
  WHERE   LEVEL = LENGTH (p_digits)
  CONNECT BY NOCYCLE PRIOR i != i
  ORDER   BY digits)
 LOOP
 PIPE ROW (v_rec.digits);
 END LOOP;
END my_func;
SELECT *
FROM TABLE (my_func (‘11111111111111111111111111111111222222222222222222222222222222223333333333333333333333333333333344444444444444444444444444444444555555555555555555555555555555556666666666666666666666666666666677777777777777777777777777777777888888888888888888888888888888889999999999999999999999999999999900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’))
WHERE SUBSTR (COLUMN_VALUE, 2, 1) = ‘1’
please tell me.
i look forward to hearing from you.
Yours sincerely,
Thanks with best regards,
Navamin-Thailand.
navaminroad@gmail.com
