Orin NX 16G模组,Jetpack6.2系统,自带浏览器无法播放H.265视频
您好!我们使用Orin NX 16G模组,Jetpack6.2系统,搭配我们自研底板,自带浏览器运行下文链接中视频,无法播放H.265,麻烦帮分析下是何原因?谢谢。
Hardware decoding is not enabled in browser. Please refer to gstreamer user guide and run the command to play the mp4 file:
Accelerated GStreamer — NVIDIA Jetson Linux Developer Guide
您好,目前是通过浏览器打开之前网址无法播放H.265视频。但把视频下载后,可以用系统自带播放器正常播放。还请再帮忙看下。
按您之前回复设置,依旧无法通过自带 chromium web Browser 浏览器播放。
Hardware acceleration is not enabled in browser. Would suggest you check if it is possible to install software h265 decoder plugin to the browser.
您好!我可以理解成jetpack6.2系统安装后自带的浏览器,默认是不支持H.265硬件解码的,需要用户额外自行安装插件呗?谢谢。
Yes. From your description, it does not have both h265 hardware and software decoding in the browser.
