I was busted by Apple’s update 10.13.6 0004, so I formated my macbookpro 2013 - GT750M - with OSX 10.13.6 02 installer.
But surprise, the number is 17G66, I cannot find anything on that version. I installed the webdrivers through GITHUB @Benjamin-Dobbel and the webdriver 10.10.40.130 was installed.
I then installed the latest CUDA 418-105 and it looked good-> I could do an install cuda update through nvidia’s preference interface and got CUDA 418.163
but underneath it says : GPU Driver version 355.11.10.10.40.102 update required while the driver manager says I have the latest 355.11.10.10.40.130 ?!?
What would be the last best High sierra update where a webdriver version work magically ?
Thanks for your help and for this forum…
Neil
0/ Download on an external drive :
- SecUpd2019-002HighSierra.dmg update taken from Apple’s download page (Apple - Support - Downloads). this is the 2019-march-29 High Sierra update
- Installer MacOS_High_Sierra 10.13.6 02
- CUDA driver : cudadriver_418.163_macos.dmg
- WebDriver-387.10.10.10.40.127
1/ Format with Installer MacOS_High_Sierra 10.13.6 02 (use a bootkey -I used DiskCreator) (if you have problems finding this High Sierra installer, write to me)
CAREFULL, you will have to go QUICK on this one : you have about 20 seconds after login
- When you arrive on the High Sierra desktop window the first time, immediatly deactivate wifi and/or connexion to internet → immediatly go to the “preference system > App Store” and UNCHECK all updates !
(Otherwise, it will connect to Apple servers, and you’ll get the 0004 update notification !)
2/ Copy on the desk the ‘SecUpd2019-002HighSierra.dmg’ (it would not install from another drive in my case), and then launch the update.
3/ After reboot, Install FIRST the CUDA driver - I know, it’s weird to do it that way)
4/ Reconnect wifi or internet connexion and go to the github website :
5/ Open terminal and copy and paste this line :
bash <(curl -s https://raw.githubusercontent.com/Benjamin-Dobell/nvidia-update/master/nvidia-update.sh) 387.10.10.10.40.127
5/ Reboot
6/ You should have this
http://www.demontais.com/image/Webdriver127.png
Hope this helps a few…
