Latest OTA tools (R35.6.0) that supports Xavier AGX fails to apply OTA update on 64gb xavier version:
Command: ./nv_ota_start.sh /dev/mmcblk0 /home/jetuser/ota_payload_package.tar.gz
Current rootfs is on /dev/mmcblk0
init_ota_log /ota_log
Creating log dir at /ota_log
Create log file at /ota_log/ota_20250222-100405.log
OTA_LOG_FILE=/ota_log/ota_20250222-100405.log
Extract /home/jetuser/ota_payload_package.tar.gz
update_nv_boot_control_in_rootfs /ota_work
2888-402-0005-G.0-1-2-jetson-agx-xavier-devkit-
check_prerequisites
decompress_ota_package ota_package.tar /ota_work
decompress_ota_package: start at Sat Feb 22 10:04:48 UTC 2025
Sha1 checksum for /ota_work/ota_package.tar (fc0e76ba49e15583e1ad96cc5eb0a52203aa7e68) matches
decompress_ota_package: end at Sat Feb 22 10:05:10 UTC 2025
nv_ota_update_with_layout_change.sh /dev/mmcblk0
Command: nv_ota_update_with_layout_change.sh /dev/mmcblk0
check_bsp_version /ota_work BASE_VERSION
check_target_board /ota_work TARGET_BOARD
set_msi_emmc_min_size jetson-agx-xavier-devkit MSI_EMMC_MIN_SIZE
ota_check_rollback /ota_work jetson-agx-xavier-devkit R32-7 /dev/mmcblk0
OTA_PACKAGE version: branch:35 revision:6.0 major.minor:6.0
16384+0 records in
16384+0 records out
8388608 bytes (8.4 MB, 8.0 MiB) copied, 2.45499 s, 3.4 MB/s
boot_device_size=8388608
VER_b's offset is 2203648 and size is 65536
VER's offset is 2269184 and size is 65536
VER_b version: branch:32 revision:7.5 major.minor:7.5
VER version: branch:32 revision:7.5 major.minor:7.5
Check BCT/MB1/MB1_BCT partiton for fresh OTA
Checking BCT partition
Checking MB1 partition
Checking MB1_BCT partition
ver_check_res=0
ota_choose_images /ota_work
COMPATIBLE_SPEC=2888-402-0005-G.0-1-2-jetson-agx-xavier-devkit-
TEGRA_CHIPID=0x19
_BOARD_SPEC_NAME=2888-402-0005-G.0
No image is found for compatible SPEC 2888-402-0005-G.0
Failed to call "copy_board_spec_dep_files /ota_work/internal_device"
Failed to run "ota_choose_images /ota_work"
Could you fix it please? It seems, that problem exist for both 0004 and 0005.
Also, I succesfully applied OTA update with this workaround:
--- a/ota_tools/version_upgrade/ota_multi_board_specs.sh
+++ b/ota_tools/version_upgrade/ota_multi_board_specs.sh
@@ -61,6 +61,9 @@ construct_board_spec_name()
# board_spec_name=${boardid}-${boardver}-${boardsku}-${boardrev}
# For example, for jetson-agx-xavier-devkit, board_spec_name can be 2888-400-0001-D.0
# or 2888-400-0001-E.0.
+ if [ "${boardsku}" == "0005" ]; then
+ boardrev=""
+ fi
name="${boardid}-${boardver}-${boardsku}-${boardrev}"
eval "${board_spec_name}=${name}"
return 0
Are you using the devkit or custom board for AGX Xavier?
What’s you L4T release before update? (i.e. are you trying to update from r35.6.0 to r35.6.0)
Would you like to perform image-based OTA update for each partitions including rootfs? Or you just want to update bootloader through capsule update?
Please also share the result of the following command on your board.
Could you modify the following line of /opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.sh in your board ?
@@ -251,7 +251,11 @@ update_jetson_xavier_spec () {
board_ver="400"
return 0
fi
+ if [[ "${board_sku}" == "0005" ]]; then
+ board_rev=""
+ board_ver="402"
+ return 0
+ fi
if [[ "${board_ver}" == "400" ]]; then
if [[ "${board_rev}" == "D.0" || "${board_rev}" < "D.0" ]]; then
board_rev="D.0"
After rebooting the board, please share the result of the following command on your board.
$ cat /etc/nv_boot_control.conf
If its COMPATIBLE_SPEC becomes 2888-402-0005--1-2-jetson-agx-xavier-devkit-, then you can try using the OTA payload you generated before to update the board.
Please also modify those lines in file of you BSP package(<Linux_for_Tegra>/rootfs/opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.sh) and generate OTA payload again.
done, ota update from 32.7.5 to 35.6.0 successfully finished, thanks.
Is there any chance to have update with fixed bug soon?
Thanks for your update.
We are working on fixing this issue with internal, it may be fixed in the next release.
Before that, please take above modification as WA for AGX Xavier SKU5.
Your esp partition is vfat format as expected.
This error looks like mount command does not support vfat format.
Have you customized the rootfs on your board?
We would suggest applying the following patch in BSP package of r35.6.0 before generate OTA payload.
Please also help to clarify if the issue is specific to OTA update.
(i.e. would you hit the similar issue if your flash R35.6.0 to your board directly?)
