Hi All,
I am having a Geforce GTX 460 and am planning to do some parallel image processing.
Problem def: I have an image A. I want to apply an image processing algo (for example lets say image dilation) for different regions of the image (the shape of the ROI is not fixed). How can i do this in parallel such that each ROI of the image is processed by different cuda blocks and hence speed up the process.
Thanks in advance for all the help.
Jacky,
Hi All,
Jacky,
You could either execute the same kernel multiple times concurrently with different ROIs. Or, store all ROIs in some sort of array in global memory, and use blockIdx to select a ROI for each threadblock. This would be my best guess at this time.
