It seems the rmapi control command NV2080_CTRL_CMD_BUS_GET_INFO does not populate the busInfo. I have also tested in non-CC mode and this configuration works fine. Could you explain the reason for passing through the GPU with a pcie-root-port? Thanks.
The card is available in the nvidia-smi. But I cannot run the CUDA application. It will report NVRM: getPCIELinkRateMBps: Unknown PCIe speed
The driver version is 550.54.15
Thank you for pointing out. I did not notice that before.
Before experts from Nvidia reply to this question, I suggest hacking into the function getPCIELinkRateMBps that reports this error. For example, remove the error in this function and hard-code linkRate.
