I got a question regarding the reference pass to global functions.
As I searched about it, a question about it says it is not supported.
https://forums.developer.nvidia.com/t/passing-by-reference-in-global-functs-arguments/26976
But when I tested the following code on Linux Ubuntu 18.04, it works fine.
Am I misunderstanding something?
Or passing reference to global functions is not illegal?
#include <cuda_runtime.h>
#include <iostream>
template <typename T>
__global__ void kernel(T& a)
atomicAdd(&a, static_cast<T>(1));
int main(int argc, char *argv[])
double *ptr;
cudaMalloc(&ptr, sizeof(double));
cudaMemset(ptr, 0, sizeof(double));
kernel <<< 1, 1024 >>> (*ptr);
double check;
cudaMemcpy(&check, ptr, sizeof(double), cudaMemcpyDeviceToHost);
cudaDeviceSynchronize();
auto status = cudaPeekAtLastError();
std::cout << "STATUS " << status << std::endl;
std::cout << "RESULT " << check << std::endl;
