Patterns in the outcome of a simple race condition
Hello, I’m new to CUDA and recently learned about race conditions.
So I created a simple kernel that has a race condition and observed the results.
__global__ void raceKernel(float *A, float *result, int n) {
    int row = blockIdx.y * blockDim.y + threadIdx.y;
    int col = blockIdx.x * blockDim.x + threadIdx.x;
    if (row < n && col < n) {
        *result = A[row*n + col];
I expected the result to be random based on which thread finishes execution last and overwrites the value.
But when I run this kernel many times with different launch parameters I see a lot of repeating outcomes.
And in some combinations of input matrix size and block size the result is always from the same (0th) index of an arbitrary warp.
Example: matrix size 48x48, block size = 16x16
Launched the kernel 10000 times with the same parameters.
// WarpIdx X Y means result came from Xth warp Yth thread in that warp
Iteration 1 - Result: 1056 - WarpIdx: 33 0
Iteration 2 - Result: 960 - WarpIdx: 30 0
Iteration 6 - Result: 1440 - WarpIdx: 45 0
Iteration 284 - Result: 1248 - WarpIdx: 39 0
Iteration 292 - Result: 96 - WarpIdx: 3 0
Iteration 332 - Result: 864 - WarpIdx: 27 0
Iteration 338 - Result: 1856 - WarpIdx: 58 0
Iteration 486 - Result: 672 - WarpIdx: 21 0
Iteration 1002 - Result: 768 - WarpIdx: 24 0
Iteration 2277 - Result: 1664 - WarpIdx: 52 0
Iteration 6334 - Result: 288 - WarpIdx: 9 0
Iteration 6622 - Result: 2048 - WarpIdx: 64 0
12 different outcomes
1 unique warp indexes: 0
I only tested a couple combinations but these have the same property
matrix width, block width
  • 2048, 32
  • 24, 8
  • 16, 16
  • or any matrix size that is divisible by 32 and block size of 32
And there are other interesting outcomes too
8, 6 - the result is always 48
16, 16 - the results are always multiples of 32
and for 16, 32 results are multiples of 64
Iteration 1 - Result: 128 - WarpIdx: 4 0
Iteration 2 - Result: 720 - WarpIdx: 22 16
Iteration 112 - Result: 192 - WarpIdx: 6 0
Iteration 275 - Result: 656 - WarpIdx: 20 16
Iteration 505 - Result: 448 - WarpIdx: 14 0
Iteration 684 - Result: 384 - WarpIdx: 12 0
Iteration 9306 - Result: 528 - WarpIdx: 16 16
7 different outcomes
2 unique warp indexes: 0 - 16
I did not test all combinations because my code assumes number of total threads and threads in a block are divisible by 32.
Here is the C code I used:
Summary
#include <cuda_runtime.h>
#include <stdio.h>
int is_in(float value, float *array, int size) {
    for (int i = 0; i < size; i++) {
        if (array[i] == value) {
            return 1;
    return 0;
int main() {
    int n = 48;
    int size = n*n * sizeof(float);
    float *A = (float *)malloc(size);
    for (int a = 0; a < n*n; a++){
        A[a] = a;
    float *dA;
    cudaMalloc((void**)&dA, size);
    cudaMemcpy(dA, A, size, cudaMemcpyHostToDevice);
    float result;
    float *dresult;
    cudaMalloc((void**)&dresult, sizeof(float));
    int blockSize = 16; // max is 32
    int gridSize = (n + blockSize - 1)/blockSize;
    dim3 blockDim(blockSize, blockSize);
    dim3 gridDim(gridSize, gridSize);
    int iters = 10000;
    int nResults = 0;
    float results[iters];
    int nIdxs = 0;
    float warpIdxs[32];
    for (int i = 0; i < iters; i++) {
        results[i] = -1; // will be overwritten
        result = 0.0;
        cudaMemcpy(dresult, &result, sizeof(float), cudaMemcpyHostToDevice);
        raceKernel<<<gridDim, blockDim>>>(dA, dresult, n);
        cudaMemcpy(&result, dresult, sizeof(float), cudaMemcpyDeviceToHost);
        if (!is_in(result, results, i)) {
            int idx = (int)result%32; // index inside a warp
            if (!is_in(idx, warpIdxs, nIdxs)){
                warpIdxs[nIdxs] = idx;
                nIdxs++;
            results[i] = result;
            nResults++;
            printf("Iteration %d - Result: %d - WarpIdx: %d %d\n", i+1, (int)result, (int)result/32, idx);
    printf("%d different outcomes\n", nResults);
    printf("%d unique warp indexes: ", nIdxs);
    for(int j = 0; j < nIdxs; j++){
        printf("%d - ", (int)warpIdxs[j]);
    printf("\n");
    cudaFree(dA);
    cudaFree(dresult);
    free(A);
    return 0;
Again I’m new to CUDA and might be missing a crucial point here but if the way I’m calculating this and my assumptions about warps are correct I am curious about the reason of this behaviour.
Multiple threads writing to the same location without any explicit ordering that you explicitly provide via source code, is undefined behavior. Full stop. Specifically what is meant is that one of the written values will end up in that location, but which value will end up there is undefined. No additional qualifications or characterizations based on order of execution, or any other ideas that might seem to be relevant, are actually relevant.
That is a statement that describes the CUDA programming model. Based on that statement, you should not form expectations about what value will end up there (other than it will be one of the written values).
Beyond that, of course the actual machine (ie. a CUDA GPU) is not some kind of random engine, like a blender full of spaghetti. It has quite a bit of structure, and rules that sort out what happens in various situations. Much of this structure and rules are unpublished, and unspecified externally/publicly.
But that structure and unpublished rules do not violate the previous statements about the CUDA programming model. There is no requirement for any sort of “random” behavior, and in fact there is no behavioral requirement at all, except that one of the written values must end up there. So observation of patterns is not surprising because: 1. it is not prohibited by the CUDA programming model and 2. The actual machine does have structure, and rules that it follows.
So even if the observation were always that the lowest numbered thread would “win”, and its value would always end up there (for example regardless of presumed or imagined ordering), that would be a legitimate outcome, not in violation of any guarantees that CUDA makes, nor in violation of any expectations you should have.
