This gets complicated and would depend on what you want to do with your machine. If you want to be using CUDA for number crunching while you watch films then this might be a good idea, but otherwise using CUDA and say surfing the web don’t significantly effect each other. There is an issue if your kernel takes longer than the screen refresh delay then things can get hairy but if you write good CUDA code this won’t happen anyway. At the end of the day a cheep NVIDIA card would do the job and a 285 would be wasted. That said if you go for a 285GTX or similar in addition to the 480 then you will always have the multiGPU CUDA programming option… again depends on what you want to do with it.
Related topics
| CUDA hardware & software | 9 | 2753 | November 13, 2010 | |
| Advice on first CUDA system | 13 | 2797 | July 7, 2009 | |
| Shopping-list for Cuda GPGPU System in 800-1000 euro price-range Goal: A 'budget' GTX 470 (F | 59 | 12232 | April 15, 2010 | |
| CUDA with4 cards GTX 480 | 25 | 15091 | September 29, 2010 | |
| newbie questions | 14 | 1969 | September 24, 2010 | |
| CUDA development cluster (using old filing cabinet!) Advice needed on hardware specification | 38 | 10547 | October 4, 2010 | |
| Hardware Recommendations Recs for hardware for GTX 275 or 285 on Linux | 20 | 24341 | January 13, 2010 | |
| CUDA Rig Any experience/ideas about Thermaltake SwordM | 12 | 2321 | May 31, 2010 | |
| CUDA GPU? | 11 | 18291 | August 11, 2010 | |
| board recommendation / headless dedicated / chipset tradeoffs | 18 | 10743 | July 3, 2009 |
