I am using NVIDIA GeForce GTX 1650 Ti for my linux machine and ubuntu is my primary distro. Grub is not installed on my machine. But, I face some issue such as freezing screen. I am able to move my mouse cursor, but unable to do any action. I had opened my console by pressing Ctrl+Alt+F3, I found the below error,
pcie bus error severity=uncorrected (non-fatal) type=transaction layer (requester id)
Command- sudo lspci -vvvv
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
Subsystem: ASUSTeK Computer Inc. 10th Gen Core Processor Host Bridge/DRAM Registers
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: [e0] Vendor Specific Information: Len=10 <?>
Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 02) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: c3000000-c40fffff [size=17M]
Prefetchable memory behind bridge: 00000000b0000000-00000000c1ffffff [size=288M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [88] Subsystem: ASUSTeK Computer Inc. 6th-10th Gen Core Processor PCIe Controller (x16)
Capabilities: [80] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee00218 Data: 0000
Capabilities: [a0] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 256 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #2, Speed 8GT/s, Width x8, ASPM L0s L1, Exit Latency L0s <256ns, L1 <8us
ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+
LnkCtl: ASPM L1 Enabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (ok), Width x8 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt+
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #1, PowerLimit 75.000W; Interlock- NoCompl+
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState-
RootCap: CRSVisible-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Not Supported, TimeoutDis- NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via WAKE#, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd-
AtomicOpsCap: Routing- 32bit+ 64bit+ 128bitCAS+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Via WAKE#, ARIFwd-
AtomicOpsCtl: ReqEn- EgressBlck-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [140 v1] Root Complex Link
Desc: PortNumber=02 ComponentID=01 EltType=Config
Link0: Desc: TargetPort=00 TargetComponent=01 AssocRCRB- LinkType=MemMapped LinkValid+
Addr: 00000000fed19000
Capabilities: [d94 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05) (prog-if 00 [VGA controller])
DeviceName: Second VGA
Subsystem: ASUSTeK Computer Inc. CometLake-H GT2 [UHD Graphics]
Interrupt: pin A routed to IRQ 152
Region 0: Memory at c2000000 (64-bit, non-prefetchable) [size=16M]
Region 2: Memory at a0000000 (64-bit, prefetchable) [size=256M]
Region 4: I/O ports at 5000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express (v2) Root Complex Integrated Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE+ FLReset+
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevCap2: Completion Timeout: Not Supported, TimeoutDis- NROPrPrP- LTR-
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
FRS-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- OBFF Disabled,
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee00018 Data: 0000
Capabilities: [d0] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Process Address Space ID (PASID)
PASIDCap: Exec- Priv-, Max PASID Width: 14
PASIDCtl: Enable- Exec- Priv-
Capabilities: [200 v1] Address Translation Service (ATS)
ATSCap: Invalidate Queue Depth: 00
ATSCtl: Enable-, Smallest Translation Unit: 00
Capabilities: [300 v1] Page Request Interface (PRI)
PRICtl: Enable- Reset-
PRISta: RF- UPRGI- Stopped+
Page Request Capacity: 00008000, Page Request Allocation: 00000000
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
Subsystem: ASUSTeK Computer Inc. Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
Region 0: Memory at c4410000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Address: 00000000 Data: 0000
Capabilities: [d0] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device_pci_legacy
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Subsystem: ASUSTeK Computer Inc. Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 255
Region 0: Memory at c4428000 (64-bit, non-prefetchable) [disabled] [size=4K]
Capabilities: [dc] Power Management version 2
Capabilities: [f0] PCI Advanced Features
AFCap: TP+ FLR+
AFCtrl: FLR-
AFStatus: TP-
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
Subsystem: ASUSTeK Computer Inc. Comet Lake PCH Thermal Controller
Region 0: Memory at c4427000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 3
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Comet Lake USB 3.1 xHCI Host Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 125
Region 0: Memory at c4400000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Address: 00000000fee00298 Data: 0000
Capabilities: [90] Vendor Specific Information: Len=14 <?>
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
Subsystem: Intel Corporation Comet Lake PCH Shared SRAM
Region 0: Memory at c4420000 (64-bit, non-prefetchable) [disabled] [size=8K]
Region 2: Memory at c4426000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.3 Network controller: Intel Corporation Comet Lake PCH CNVi WiFi
DeviceName: WLAN
Subsystem: Intel Corporation Wi-Fi 6 AX201 160MHz
Region 0: Memory at c441c000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [40] Express (v2) Root Complex Integrated Endpoint, MSI 00
ExtTag- RBE- FLReset+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
DevCap2: Completion Timeout: Range B, TimeoutDis+ NROPrPrP- LTR+
FRS-
DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis- LTR+ OBFF Disabled,
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [100 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [164 v1] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:15.0 Serial bus controller: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
Subsystem: ASUSTeK Computer Inc. Comet Lake PCH Serial IO I2C Controller
Region 0: Memory at 9f800000 (64-bit, non-prefetchable) [virtual] [size=4K]
Status: D3 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Comet Lake PCH Serial IO I2C Controller #1
Interrupt: pin B routed to IRQ 17
Region 0: Memory at 9f801000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
Subsystem: ASUSTeK Computer Inc. Comet Lake HECI Controller
Latency: 0
Interrupt: pin A routed to IRQ 137
Region 0: Memory at c4423000 (64-bit, non-prefetchable) [size=4K]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00438 Data: 0000
Capabilities: [a4] Vendor Specific Information: Len=14 <?>
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000f000-00000fff [disabled]
Memory behind bridge: c4300000-c43fffff [size=1M]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
ExtTag- RBE+
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
LnkCap: Port #9, Speed 8GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <16us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
LnkSta: Speed 8GT/s (ok), Width x4 (ok)
TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
Slot #12, PowerLimit 25.000W; Interlock- NoCompl+
Changed: MRL- PresDet- LinkState-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+ NROPrPrP- LTR+
FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd+
AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled, ARIFwd-
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee00238 Data: 0000
Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Comet Lake PCI Express Root Port
Capabilities: [a0] Power Management version 3
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
RootCmd: CERptEn+ NFERptEn+ FERptEn+
RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
Capabilities: [140 v1] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid+ TransBlk- ReqRedir+ CmpltRedir+ UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [150 v1] Precision Time Measurement
PTMCap: Requester:- Responder:+ Root:+
PTMClockGranularity: 4ns
PTMControl: Enabled:+ RootSelected:+
PTMEffectiveGranularity: Unknown
Capabilities: [200 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=40us PortTPowerOnTime=44us
L1SubCtl1: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+
T_CommonMode=40us LTR1.2_Threshold=65536ns
L1SubCtl2: T_PwrOn=44us
Capabilities: [220 v1] Secondary PCI Express
LaneErrStat: 0
Capabilities: [250 v1] Downstream Port Containment
DpcCap: INT Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
DpcCtl: Trigger:1 Cmpl- INT+ ErrCor- PoisonedTLP- SwTrigger- DL_ActiveErr-
DpcSta: Trigger- Reason:00 INT- RPBusy- TriggerExt:00 RP PIO ErrPtr:1f
Source: 0000
00:1d.6 PCI bridge: Intel Corporation Device 06b6 (rev f0) (prog-if 00 [Normal decode])
Interrupt: pin C routed to IRQ 124
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: c4200000-c42fffff [size=1M]
ExtTag- RBE+
LnkCap: Port #15, Speed 8GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <16us
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (ok)
Slot #18, PowerLimit 10.000W; Interlock- NoCompl+
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Address: fee00278 Data: 0000
Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device 1f21
T_CommonMode=150us LTR1.2_Threshold=294912ns
L1SubCtl2: T_PwrOn=150us
LaneErrStat: 0
Source: 0000
00:1f.0 ISA bridge: Intel Corporation Comet Lake LPC Controller
Subsystem: ASUSTeK Computer Inc. Comet Lake LPC Controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS (prog-if 80)
Subsystem: ASUSTeK Computer Inc. Comet Lake PCH cAVS
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 154
Region 0: Memory at c4418000 (64-bit, non-prefetchable) [size=16K]
Region 4: Memory at c4100000 (64-bit, non-prefetchable) [size=1M]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
Status: D3 NoSoftRst+ PME-Enable+ DSel=0 DScale=0 PME-
Capabilities: [80] Vendor Specific Information: Len=14 <?>
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00638 Data: 0000
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci_intel_cnl
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
Subsystem: ASUSTeK Computer Inc. Comet Lake PCH SMBus Controller
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at c4422000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Comet Lake PCH SPI Controller
Subsystem: Intel Corporation Comet Lake PCH SPI Controller
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1) (prog-if 00 [VGA controller])
DeviceName: VGA
Subsystem: ASUSTeK Computer Inc. TU117M [GeForce GTX 1650 Ti Mobile]
Latency: 0
Interrupt: pin A routed to IRQ 153
Region 0: Memory at c3000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at b0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at c0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at 4000 [size=128]
Expansion ROM at c4000000 [virtual] [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00618 Data: 0000
Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
LnkCap: Port #0, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <1us, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (ok), Width x8 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via message, ExtFmt- EETLPPrefix-
FRS-
Status: InProgress-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Capabilities: [250 v1] Latency Tolerance Reporting
Max snoop latency: 34326183936ns
Max no snoop latency: 34326183936ns
Capabilities: [258 v1] L1 PM Substates
PortCommonModeRestoreTime=255us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [420 v2] Advanced Error Reporting
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900 v1] Secondary PCI Express
LaneErrStat: 0
Capabilities: [bb0 v1] Physical Resizable BAR
BAR 0: current size: 16MB, supported: 16MB
BAR 1: current size: 256MB, supported: 64MB 128MB 256MB
BAR 3: current size: 32MB, supported: 32MB
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
Subsystem: ASUSTeK Computer Inc. Device 195f
Region 0: Memory at c4080000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express (v2) Endpoint, MSI 00
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes, Disabled- CommClk+
FRS- TPHComp- ExtTPHComp-
Capabilities: [100 v2] Advanced Error Reporting
02:00.0 Non-Volatile memory controller: Intel Corporation SSD 660P Series (rev 03) (prog-if 02 [NVM Express])
Subsystem: Intel Corporation SSD 660P Series
NUMA node: 0
Region 0: Memory at c4300000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25.000W
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L1 <8us
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
PBA: BAR=0 offset=00002100
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
Capabilities: [158 v1] Secondary PCI Express
LaneErrStat: 0
Capabilities: [178 v1] Latency Tolerance Reporting
Max snoop latency: 3145728ns
Max no snoop latency: 3145728ns
Capabilities: [180 v1] L1 PM Substates
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
T_CommonMode=0us LTR1.2_Threshold=65536ns
Kernel driver in use: nvme
Kernel modules: nvme
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
DeviceName: GLAN
Subsystem: ASUSTeK Computer Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at 3000 [size=256]
Region 2: Memory at c4204000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at c4200000 (64-bit, non-prefetchable) [size=16K]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 10.000W
MaxPayload 128 bytes, MaxReadReq 4096 bytes
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
LnkSta: Speed 2.5GT/s (ok), Width x1 (ok)
10BitTagComp- 10BitTagReq- OBFF Via message/WAKE#, ExtFmt- EETLPPrefix-
LnkCap2: Supported Link Speeds: 2.5GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00000800
Capabilities: [140 v1] Virtual Channel
Status: InProgress-
Capabilities: [160 v1] Device Serial Number 01-00-00-00-68-4c-e0-00
Capabilities: [170 v1] Latency Tolerance Reporting
Capabilities: [178 v1] L1 PM Substates
PortCommonModeRestoreTime=150us PortTPowerOnTime=150us
T_CommonMode=0us LTR1.2_Threshold=294912ns
Kernel driver in use: r8169
Kernel modules: r8169
