I am using Jetson Nano on my custom carrier board.It can work good with the old SSD (PE50 128GB).But after I change the SSD (MTE672A 256GB).It cannot boot normally .
The screen show the same messgae as the console.
Here is the console message.
[16:49:28.696]
[0000.231] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[16:49:29.727] [0000.237] Processing in cold boot mode Bootloader 2
[16:49:29.727] [0000.241] A02 Bootrom Patch rev = 1023
[16:49:29.737] [0000.245] Power-up reason: pmc por
[16:49:29.737] [0000.248] No Battery Present
[16:49:29.737] [0000.251] pmic max77620 reset reason
[16:49:29.737] [0000.254] pmic max77620 NVERC : 0x40
[16:49:29.737] [0000.257] RamCode = 0
[16:49:29.737] [0000.260] Platform has DDR4 type RAM
[16:49:29.746] [0000.263] max77620 disabling SD1 Remote Sense
[16:49:29.746] [0000.267] Setting DDR voltage to 1125mv
[16:49:29.757] [0000.271] Serial Number of Pmic Max77663: 0x1e2f63
[16:49:29.757] [0000.279] Entering ramdump check
[16:49:29.767] [0000.282] Get RamDumpCarveOut = 0x0
[16:49:29.767]
[0000.285] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[16:49:29.787] [0000.290] Last reboot was clean, booting normally!
[16:49:29.787] [0000.295] Sdram initialization is successful
[16:49:29.787] [0000.299] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[16:49:29.787] [0000.305] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[16:49:29.797] [0000.311] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[16:49:29.797] [0000.317] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[16:49:29.806] [0000.323] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[16:49:29.806] [0000.328] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[16:49:29.816] [0000.334] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[16:49:29.827] [0000.340] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[16:49:29.827]
[0000.356] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[16:49:29.847] [0000.362] Platform-DebugCarveout: 0
[16:49:29.847] [0000.366] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[16:49:29.866] [0000.371] Non secure mode, and RB not enabled.
[16:49:29.866] [0000.376] *** Booting BFS0.
[16:49:29.866] [0000.378] Initialize FailControl
[16:49:29.866] [0000.381] Read PT from (0:3)
[16:49:29.866]
[0000.396] Csd NumOfBlocks=0
[16:49:29.887]
[0000.435] PT crc32 and magic check passed.
[16:49:29.926] [0000.439] Using BFS PT to query partitions
[16:49:29.926]
[0000.443] PT: Partition LNX NOT found !
[16:49:29.947] [0000.447] *** Booting KFS0.
[16:49:29.947] [0000.450] NvTbootFailControlDoFailover: No failover; Continuing ...
[16:49:29.947] [0000.456] BoardID = 3448, SKU = 0x2
[16:49:29.947] [0000.459] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:29.947] [0000.465] Read GPT from (0:3)
[16:49:29.957] [0000.473] Using GPT Primary to query partitions
[16:49:29.967] [0000.478] NvTbootFailControlDoFailover: No failover; Continuing ...
[16:49:29.967] [0000.484] Loading Tboot-CPU binary
[16:49:29.976] [0000.490] Verifying TBC in OdmNonSecureSBK mode
[16:49:29.976]
[0000.501] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[16:49:29.997] [0000.508] Bootloader downloaded successfully.
[16:49:29.997] [0000.512] Downloaded Tboot-CPU binary to 0xa0000258
[16:49:30.007] [0000.517] MAX77620_GPIO5 configured
[16:49:30.017] [0000.521] CPU power rail is up
[16:49:30.017] [0000.523] CPU clock enabled
[16:49:30.017] [0000.527] Performing RAM repair
[16:49:30.017] [0000.530] Updating A64 Warmreset Address to 0xa00002e9
[16:49:30.027] [0000.535] BoardID = 3448, SKU = 0x2
[16:49:30.027] [0000.539] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:30.027]
[0000.544] NvTbootFailControlDoFailover: No failover; Continuing ...
[16:49:30.047] [0000.551] Loading NvTbootBootloaderDTB
[16:49:30.047] [0000.568] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[16:49:30.066]
[0000.639] Bootloader DTB Load Address: 0x83000000
[16:49:30.137] [0000.644] BoardID = 3448, SKU = 0x2
[16:49:30.147] [0000.647] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:30.147] [0000.653] Loading NvTbootKernelDTB
[16:49:30.147]
[0000.670] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[16:49:30.168]
[0000.741] Kernel DTB Load Address: 0x83100000
[16:49:30.237] [0000.745] BoardID = 3448, SKU = 0x2
[16:49:30.247] [0000.748] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:30.247] [0000.754] NvTbootFailControlDoFailover: No failover; Continuing ...
[16:49:30.256] [0000.761] Loading cboot binary
[16:49:30.256] [0000.773] Verifying EBT in OdmNonSecureSBK mode
[16:49:30.267]
[0000.814] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[16:49:30.317] [0000.821] Bootloader downloaded successfully.
[16:49:30.317]
[0000.825] BoardID = 3448, SKU = 0x2
[16:49:30.337] [0000.829] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:30.337] [0000.835] NvTbootFailControlDoFailover: No failover; Continuing ...
[16:49:30.337] [0000.841] PT: Partition NCT NOT found !
[16:49:30.352] [0000.845] Warning: Find Partition via PT Failed
[16:49:30.352] [0000.849] Next binary entry address: 0x92c00258
[16:49:30.362] [0000.853] BoardId: 3448
[16:49:30.362] [0000.858] Overriding pmu board id with proc board id
[16:49:30.362] [0000.863] Display board id is not available
[16:49:30.371] [0000.867] BoardID = 3448, SKU = 0x2
[16:49:30.380] [0000.870] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:30.380] [0000.876] NvTbootFailControlDoFailover: No failover; Continuing ...
[16:49:30.380] [0000.890] Verifying SC7EntryFw in OdmNonSecureSBK mode
[16:49:30.396]
[0000.980] /bpmp deleted
[16:49:30.477] [0000.982] SC7EntryFw header found loaded at 0xff700000
[16:49:30.487]
[0001.390] OVR2 PMIC
[16:49:30.906] [0001.392] Bpmp FW successfully loaded
[16:49:30.906] [0001.395] BoardID = 3448, SKU = 0x2
[16:49:30.916] [0001.398] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:30.916] [0001.404] NvTbootFailControlDoFailover: No failover; Continuing ...
[16:49:30.926] [0001.412] WB0 init successfully at 0xff780000
[16:49:30.926] [0001.416] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[16:49:30.926] [0001.421] Set NvDecSticky Bits
[16:49:30.937] [0001.425] GSC2 address ff53fffc value c0edbbcc
[16:49:30.937] [0001.431] GSC MC Settings done
[16:49:30.947] [0001.434] BoardID = 3448, SKU = 0x2
[16:49:30.957] [0001.437] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[16:49:30.957] [0001.444] TOS Image length 53680
[16:49:30.957] [0001.447] Monitor size 53680
[16:49:30.967] [0001.449] OS size 0
[16:49:30.967] [0001.455] Secure Os AES-CMAC Verification Success!
[16:49:30.977] [0001.459] TOS image cipher info: plaintext
[16:49:30.977] [0001.463] Loading and Validation of Secure OS Successful
[16:49:30.977] [0001.479] SC7 Entry Firmware - 0xff700000, 0x4000
[16:49:30.996] [0001.484] NvTbootPackSdramParams: start.
[16:49:30.996] [0001.489] NvTbootPackSdramParams: done.
[16:49:31.006] [0001.493] Tegraboot started after 160893 us
[16:49:31.006] [0001.497] Basic modules init took 743277 us
[16:49:31.016] [0001.501] Sec Bootdevice Read Time = 55 ms, Read Size = 3682 KB
[16:49:31.027] [0001.506] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[16:49:31.027] [0001.512] Next stage binary read took 7385 us
[16:49:31.027] [0001.516] Carveout took -34779 us
[16:49:31.027] [0001.519] CPU initialization took 652089 us
[16:49:31.037] [0001.523] Total time taken by TegraBoot 1367972 us
[16:49:31.047]
[16:49:31.047] [0001.528] Starting CPU & Halting co-processor
[16:49:31.047]
[16:49:31.047] 64
NOTICE: BL31: v1.3(release):f9bf1e1
[16:49:31.067] NOTICE: BL31: Built : 21:16:40, Jun 8 2023
[16:49:31.067] ERROR: Error initializing runtime service trusty_fast
[16:49:31.067]
[0001.651] RamCode = 0
[16:49:31.166]
[0001.660] LPDDR4 Training: found 4 entries (2 nominal, 2 derated)
[16:49:31.186] [0001.666] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[16:49:31.186]
[0001.679] EMC Training Successful
[16:49:31.207] [0001.682] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[16:49:31.207] [0001.694] EMC Training Successful
[16:49:31.220] [0001.697] 408000 not found in DVFS table
[16:49:31.220]
[0001.738] RamCode = 0
[16:49:31.257] [0001.743] DT Write: emc-table@204000 succeeded
[16:49:31.267] [0001.751] DT Write: emc-table@1600000 succeeded
[16:49:31.278] [0001.759] DT Write: emc-table-derated@204000 succeeded
[16:49:31.287]
[0001.767] DT Write: emc-table-derated@1600000 succeeded
[16:49:31.307] [0001.772] LPDDR4 Training: Write DT: Number of tables = 4
[16:49:31.307] [0001.824]
[16:49:31.307] [0001.825] Debug Init done
[16:49:31.307] [0001.827] Marked DTB cacheable
[16:49:31.307] [0001.830] Bootloader DTB loaded at 0x83000000
[16:49:31.307]
[0001.835] Marked DTB cacheable
[16:49:31.327] [0001.838] Kernel DTB loaded at 0x83100000
[16:49:31.327] [0001.842] DeviceTree Init done
[16:49:31.327] [0001.857] Pinmux applied successfully
[16:49:31.339] [0001.861] gicd_base: 0x50041000
[16:49:31.339] [0001.865] gicc_base: 0x50042000
[16:49:31.349] [0001.868] Interrupts Init done
[16:49:31.349] [0001.873] Using base:0x60005090 & irq:208 for tick-timer
[16:49:31.367] [0001.878] Using base:0x60005098 for delay-timer
[16:49:31.367] [0001.882] platform_init_timer: DONE
[16:49:31.367] [0001.886] Timer(tick) Init done
[16:49:31.367] [0001.890] osc freq = 38400 khz
[16:49:31.367]
[0001.894]
[16:49:31.407] [0001.895] Welcome to L4T Cboot
[16:49:31.407] [0001.898]
[16:49:31.407] [0001.899] Cboot Version: 00.00.2018.01-t210-acb23272
[16:49:31.407] [0001.904] calling constructors
[16:49:31.407] [0001.907] initializing heap
[16:49:31.407] [0001.910] initializing threads
[16:49:31.407] [0001.912] initializing timers
[16:49:31.407] [0001.915] creating bootstrap completion thread
[16:49:31.407] [0001.920] top of bootstrap2()
[16:49:31.407] [0001.923] CPU: ARM Cortex A57
[16:49:31.407] [0001.925] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[16:49:31.407] [0001.930] initializing platform
[16:49:31.407]
[0001.985] Config for emmc ddr50 mode completed
[16:49:31.507] [0001.989] sdmmc bdev is already initialized
[16:49:31.507] [0001.993] Enable APE clock
[16:49:31.507] [0001.996] Un-powergate APE partition
[16:49:31.507] [0001.999] of_register: registering tegra_udc to of_hal
[16:49:31.507] [0002.005] of_register: registering inv20628-driver to of_hal
[16:49:31.507] [0002.010] of_register: registering ads1015-driver to of_hal
[16:49:31.507] [0002.016] of_register: registering lp8557-bl-driver to of_hal
[16:49:31.507] [0002.021] of_register: registering bq2419x_charger to of_hal
[16:49:31.507] [0002.027] of_register: registering bq27441_fuel_gauge to of_hal
[16:49:31.507]
[0002.040] gpio framework initialized
[16:49:31.556] [0002.043] of_register: registering tca9539_gpio to of_hal
[16:49:31.556] [0002.049] of_register: registering tca9539_gpio to of_hal
[16:49:31.556] [0002.054] of_register: registering i2c_bus_driver to of_hal
[16:49:31.556] [0002.060] of_register: registering i2c_bus_driver to of_hal
[16:49:31.556] [0002.065] of_register: registering i2c_bus_driver to of_hal
[16:49:31.556] [0002.071] pmic framework initialized
[16:49:31.556] [0002.074] of_register: registering max77620_pmic to of_hal
[16:49:31.556] [0002.080] regulator framework initialized
[16:49:31.556] [0002.084] of_register: registering tps65132_bl_driver to of_hal
[16:49:31.568] [0002.090] initializing target
[16:49:31.568] [0002.096] gpio_driver_register: register 'tegra_gpio_driver' driver
[16:49:31.586] [0002.105] board ID = D78, board SKU = 2
[16:49:31.586] [0002.112] fixed regulator driver initialized
[16:49:31.586]
[0002.133] initializing OF layer
[16:49:31.617] [0002.136] NCK carveout not present
[16:49:31.617] [0002.139] Skipping dts_overrides
[16:49:31.617] [0002.143] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[16:49:31.628] [0002.162] I2C Bus Init done
[16:49:31.647] [0002.165] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[16:49:31.647] [0002.176] I2C Bus Init done
[16:49:31.656] [0002.178] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[16:49:31.656]
[0002.189] I2C Bus Init done
[16:49:31.677] [0002.192] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[16:49:31.677] [0002.203] I2C Bus Init done
[16:49:31.688] [0002.206] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[16:49:31.688] [0002.217] I2C Bus Init done
[16:49:31.707] [0002.219] of_children_init: Ops found for compatible string maxim,max77620
[16:49:31.707] [0002.231] max77620_init using irq 118
[16:49:31.707] [0002.235] register 'maxim,max77620' pmic
[16:49:31.717] [0002.240] gpio_driver_register: register 'max77620-gpio' driver
[16:49:31.727] [0002.246] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[16:49:31.737] [0002.257] I2C Bus Init done
[16:49:31.737] [0002.261] NCK carveout not present
[16:49:31.737]
[0002.272] Find /i2c@7000c000's alias i2c0
[16:49:31.757] [0002.276] get eeprom at 1-a0, size 256, type 0
[16:49:31.757]
[0002.286] Find /i2c@7000c500's alias i2c2
[16:49:31.797] [0002.290] get eeprom at 3-a0, size 256, type 0
[16:49:31.797] [0002.294] get eeprom at 3-ae, size 256, type 0
[16:49:31.797] [0002.299] pm_ids_update: Updating 1,a0, size 256, type 0
[16:49:31.797] [0002.304] I2C slave not started
[16:49:31.797] [0002.307] I2C write failed
[16:49:31.797] [0002.310] Writing offset failed
[16:49:31.797] [0002.313] eeprom_init: EEPROM read failed
[16:49:31.797] [0002.317] pm_ids_update: eeprom init failed
[16:49:31.797] [0002.321] pm_ids_update: Updating 3,a0, size 256, type 0
[16:49:31.797]
[0002.351] pm_ids_update: The pm board id is 3448-0002-401
[16:49:31.827]
[0002.358] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[16:49:31.847] [0002.367] pm_ids_update: pm id update successful
[16:49:31.847] [0002.371] pm_ids_update: Updating 3,ae, size 256, type 0
[16:49:31.847]
[0002.401] eeprom_init: EEPROM incompatible version found
[16:49:31.887] [0002.406] pm_ids_update: eeprom init failed
[16:49:31.887]
[0002.437] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[16:49:31.927] [0002.442] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[16:49:31.927] [0002.451] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[16:49:31.937] [0002.456] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[16:49:31.937] [0002.465] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:e0:51:7b
[16:49:31.947] [0002.471] Plugin Manager: Parse ODM data 0x000a4000
[16:49:31.947] [0002.484] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[16:49:31.966]
[0002.501] Find /i2c@7000c000's alias i2c0
[16:49:31.987] [0002.504] get eeprom at 1-a0, size 256, type 0
[16:49:31.987]
[0002.514] Find /i2c@7000c500's alias i2c2
[16:49:32.027] [0002.518] get eeprom at 3-a0, size 256, type 0
[16:49:32.027] [0002.523] get eeprom at 3-ae, size 256, type 0
[16:49:32.027] [0002.527] pm_ids_update: Updating 1,a0, size 256, type 0
[16:49:32.027] [0002.532] I2C slave not started
[16:49:32.027] [0002.535] I2C write failed
[16:49:32.027] [0002.538] Writing offset failed
[16:49:32.027] [0002.541] eeprom_init: EEPROM read failed
[16:49:32.027] [0002.545] pm_ids_update: eeprom init failed
[16:49:32.027] [0002.549] pm_ids_update: Updating 3,a0, size 256, type 0
[16:49:32.027]
[0002.579] pm_ids_update: The pm board id is 3448-0002-401
[16:49:32.057]
[0002.586] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[16:49:32.077] [0002.592] pm_ids_update: pm id update successful
[16:49:32.077] [0002.597] pm_ids_update: Updating 3,ae, size 256, type 0
[16:49:32.077]
[0002.627] eeprom_init: EEPROM incompatible version found
[16:49:32.116] [0002.632] pm_ids_update: eeprom init failed
[16:49:32.116]
[0002.663] Add serial number:1420823029587 as DT property
[16:49:32.146] [0002.671] Applying platform configs
[16:49:32.146]
[0002.678] platform-init is not present. Skipping
[16:49:32.166] [0002.683] calling apps_init()
[16:49:32.166]
[0002.704] Found 17 GPT partitions in "sdmmc3_user"
[16:49:32.197] [0002.708] Proceeding to Cold Boot
[16:49:32.197] [0002.712] starting app android_boot_app
[16:49:32.197] [0002.716] Device state: unlocked
[16:49:32.197] [0002.719] display console init
[16:49:32.197]
[0002.728] could not find regulator
[16:49:32.217] [0002.732] hdmi cable connected
[16:49:32.217] [0002.747] edid read success
[16:49:32.228] [0002.762] edid read success
[16:49:32.246] [000
[0002.769] DT entry for leds-pwm not found
[16:49:32.286] 2.765] width = 640, height = 480, frequency = 25174825
[16:49:32.286] [0002.778] width = 640, height = 480, frequency = 25174825
[16:49:32.286] [0002.784] width = 640, height = 480, frequency = 25174825
[16:49:32.286] [0002.789] width = 1024, height = 600, frequency = 50250000
[16:49:32.286] [0002.795] width = 720, height = 576, frequency = 27000000
[16:49:32.286] [0002.800] width = 720, height = 480, frequency = 26973026
[16:49:32.286] [0002.805] width = 720, height = 480, frequency = 26973026
[16:49:32.286] [0002.811] width = 720, height = 576, frequency = 2
6973026
[16:49:32.327] [0002.816] width = 720, height = 576, frequency = 26973026
[16:49:32.327] [0002.821] width = 1280, height = 720, frequency = 74175824
[16:49:32.327] [0002.827] width = 1280, height = 720, frequency = 74175824
[16:49:32.327] [0002.832] width = 1920, height = 1080, frequency = 148351648
[16:49:32.327] [0002.838] width = 1920, height = 1080, frequency = 148351648
[16:49:32.327] [0002.844] Best mode Width = 1920, Height = 1080, freq = 148351648
[16:49:32.327] [0002.852] tmds-config node not found
[16:49:32.327]
[0002.856] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[16:49:32.347] [0002.871] setting 'vdd-1v8' regulator to 1800000 micro volts
[16:49:32.357] [0002.879] could not find regulator
[16:49:32.367] [0002.882] could not find regulator
[16:49:32.367] [0002.885] could not find regulator
[16:49:32.367]
[0002.913] using default cmu settings
[16:49:32.397] [0002.917] dc_hdmi_enable, starting HDMI initialisation
[16:49:32.397] [0002.923] dc_hdmi_enable, HDMI initialisation complete
[16:49:32.407] [0002.928] list and configure display window
[16:49:32.407] [0002.937] display console init completed
[16:49:32.417]
[0002.949] subnode volume_up is not found !
[16:49:32.447] [0002.952] subnode back is not found !
[16:49:32.447] [0002.956] subnode volume_down is not found !
[16:49:32.447] [0002.960] subnode menu is not found !
[16:49:32.447] [0002.964] Gpio keyboard init success
[16:49:32.447]
[0003.011] found decompressor handler: lz4-legacy
[16:49:32.486]
[0003.026] decompressing blob (type 1)...
[16:49:32.506]
[0003.095] load_bmp_blob: panelresolution=1080 type=3
[16:49:32.597] [0003.100] -------> se_aes_verify_sbk_clear: 747
[16:49:32.597] [0003.104] se_aes_verify_sbk_clear: Error
[16:49:32.597] [0003.108] SE operation failed
[16:49:32.597] [0003.111] bl_battery_charging: connected to external power supply
[16:49:32.597]
[0003.128] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[16:49:32.617] [0003.135] MSC Partition not found
[16:49:32.617]
[0003.145] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[16:49:32.647] [0003.152] USP partition read failed!
[16:49:32.647] [0003.155] blob_init: blob-partition USP header read failed
[16:49:32.647] [0003.161] android_boot Unable to update recovery partition
[16:49:32.647] [0003.166] kfs_getpartname: name = LNX
[16:49:32.647] [0003.170] Loading kernel from LNX
[16:49:32.647]
[0003.269] load kernel from storage
[16:49:32.747] [0003.278] decompressor handler not found
[16:49:32.757]
[0003.311] Successfully loaded kernel and ramdisk images
[16:49:32.796] [0003.317] board ID = D78, board SKU = 2
[16:49:32.796] [0003.322] load_bmp_blob: panelresolution=1080 type=3
[16:49:32.807]
[0003.818] display bmp image done
[16:49:33.307] [0003.821] NCK carveout not present
[16:49:33.307] [0003.824] Skipping dts_overrides
[16:49:33.307] [0003.827] NCK carveout not present
[16:49:33.307]
[0003.839] Find /i2c@7000c000's alias i2c0
[16:49:33.327] [0003.842] get eeprom at 1-a0, size 256, type 0
[16:49:33.327]
[0003.852] Find /i2c@7000c500's alias i2c2
[16:49:33.367] [0003.856] get eeprom at 3-a0, size 256, type 0
[16:49:33.367] [0003.861] get eeprom at 3-ae, size 256, type 0
[16:49:33.367] [0003.865] pm_ids_update: Updating 1,a0, size 256, type 0
[16:49:33.367] [0003.870] I2C slave not started
[16:49:33.367] [0003.873] I2C write failed
[16:49:33.367] [0003.876] Writing offset failed
[16:49:33.367] [0003.879] eeprom_init: EEPROM read failed
[16:49:33.367] [0003.883] pm_ids_update: eeprom init failed
[16:49:33.367] [0003.887] pm_ids_update: Updating 3,a0, size 256, type 0
[16:49:33.367]
[0003.917] pm_ids_update: The pm board id is 3448-0002-401
[16:49:33.397] [0003.924] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[16:49:33.407] [0003.933] pm_ids_update: pm id update successful
[16:49:33.417] [0003.937] pm_ids_update: Updating 3,ae, size 256, type 0
[16:49:33.417]
[0003.967] eeprom_init: EEPROM incompatible version found
[16:49:33.447] [0003.973] pm_ids_update: eeprom init failed
[16:49:33.447]
[0004.003] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[16:49:33.486] [0004.009] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[16:49:33.486]
[0004.017] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[16:49:33.506] [0004.023] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[16:49:33.506] [0004.031] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:e0:51:7b
[16:49:33.519] [0004.038] Plugin Manager: Parse ODM data 0x000a4000
[16:49:33.519] [0004.051] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[16:49:33.537] [0004.059] Add serial number:1420823029587 as DT property
[16:49:33.537] [0004.069] "bpmp" doesn't exist, creating
[16:49:33.547] [0004.075] Updated bpmp info to DTB
[16:49:33.557] [0004.080] Updated initrd info to DTB
[16:49:33.567] [0004.083] "proc-board" doesn't exist, creating
[16:49:33.567] [0004.089] Updated board info to DTB
[16:49:33.577] [0004.092] "pmu-board" doesn't exist, creating
[16:49:33.577] [0004.098] Updated board info to DTB
[16:49:33.577] [0004.102] "display-board" doesn't exist, creating
[16:49:33.577] [0004.108] Updated board info to DTB
[16:49:33.587] [0004.111] "reset" doesn't exist, creating
[16:49:33.587]
[0004.116] Updated reset info to DTB
[16:49:33.636] [0004.119] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1
[16:49:33.636] [0004.158] DTB cmdline: earlycon=ua
[16:49:33.657] [0004.164] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[16:49:33.657] [0004.180] Updated bootarg info to DTB
[16:49:33.657] [0004.184] Adding uuid 00000001642d78862000000002fe80c0 to DT
[16:49:33.671] [0004.190] Adding eks info 0 to DT
[16:49:33.671] [0004.196] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[16:49:33.687] [0004.202] Updated memory info to DTB
[16:49:33.687]
[0004.211] set vdd_core voltage to 1075 mv
[16:49:33.707] [0004.215] setting 'vdd-core' regulator to 1075000 micro volts
[16:49:33.707] [0004.221] Found secure-pmc; disable BPMP
[16:49:33.707]
[16:49:34.106]
[16:49:34.106] U-Boot 2020.04-g4335beb (Jun 08 2023 - 21:16:44 -0700)
[16:49:34.106]
[16:49:34.106] SoC: tegra210
[16:49:34.106] Model: NVIDIA Jetson Nano Developer Kit
[16:49:34.106] Board: NVIDIA P3450-0000
[16:49:34.106] DRAM:
4 GiB
[16:49:34.307]
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
[16:49:34.417] Loading Environment from MMC...
*** Warning - bad CRC, using default environment
[16:49:34.477]
[16:49:34.477]
In: serial
[16:49:34.497] Out: serial
[16:49:34.497] Err: serial
[16:49:34.497] Net: No ethernet found.
[16:49:34.497] Hit any key to stop autoboot: 2
1
0
[16:49:36.497] MMC: no card present
[16:49:36.497]
switch to partitions #0, OK
[16:49:36.547] mmc0(part 0) is current device
[16:49:36.547]
Scanning mmc 0:1...
[16:49:36.807]
Found /boot/extlinux/extlinux.conf
[16:49:36.916] Retrieving file: /boot/extlinux/extlinux.conf
[16:49:36.916]
879 bytes read in 29 ms (29.3 KiB/s)
[16:49:36.987] 1: primary kernel
[16:49:36.987] Retrieving file: /boot/initrd
[16:49:36.987]
7159654 bytes read in 183 ms (37.3 MiB/s)
[16:49:37.207] Retrieving file: /boot/Image
[16:49:37.207]
34707464 bytes read in 784 ms (42.2 MiB/s)
[16:49:38.067] append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=
/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[16:49:38.087]
## Flattened Device Tree blob at 83100000
[16:49:38.197] Booting using the fdt blob at 0x83100000
[16:49:38.197] ERROR: reserving fdt memory region failed (addr=83410000 size=10000)
[16:49:38.197] ERROR: reserving fdt memory region failed (addr=83400000 size=10000)
[16:49:38.197] ERROR: reserving fdt memory region failed (addr=0 size=0)
[16:49:38.197] Using Device Tree in place at 0000000083100000, end 000000008317dfff
[16:49:38.197] copying carveout for /host1x@50000000/dc@54200000...
[16:49:38.209] copying carveout for /host1x@50000000/dc@54240000...
[16:49:38.209]
[16:49:38.218] Starting kernel ...
[16:49:38.218]
[16:49:38.218]
[ 0.000000] Booting Linux on physical CPU 0x0
[16:49:38.377] [ 0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5434-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 8 21:19:14 PDT 2023
[16:49:38.377] [ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[16:49:38.377] [ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[16:49:38.377] [ 0.000000] OF: fdt: - 80000000 , 7ee00000
[16:49:38.377] [ 0.000000] OF: fdt: - 100000000 , 7f200000
[16:49:38.387] [ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[16:49:38.387] [ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[16:49:38.387] [ 0.000000] bootconsole [uart8250] enabled
[16:49:38.387]
[ 1.161784] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:39.956]
[ 1.173757] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00001000/00002000
[16:49:39.976] [ 1.174149] tegradc tegradc.1: dpd enable lookup fail:-19
[16:49:39.976] [ 1.187563] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:39.976]
[ 1.187615] nvme 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0100(Transmitter ID)
[16:49:40.016] [ 1.187620] nvme 0000:01:00.0: device [1d79:2263] error status/mask=00001040/0000e000
[16:49:40.016] [ 1.187624] nvme 0000:01:00.0: [ 6] Bad TLP
[16:49:40.016] [ 1.187629] nvme 0000:01:00.0: [12] Replay Timer Timeout
[16:49:40.016] [ 1.187743] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.016] [ 1.187747] pcieport 0000:00:01.0: device [10
[16:49:40.067] [ 1.187751] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.067] [ 1.187796] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.067] [ 1.187800] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00001000/00002000
[16:49:40.067] [ 1.187803] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.067] [ 1.187916] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Trans
mitter ID)
[16:49:40.107] ** 262 printk messages dropped ** [ 1.271430] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.107] ** 1103 printk messages dropped ** [ 1.284685] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.107] ** 725 printk messages dropped ** [ 1.293546] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.107] ** 763 printk messages dropped ** [ 1.302949] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.107] ** 739 printk messages dropped *
* [ 1.311769] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.157] ** 759 printk messages dropped ** [ 1.321232] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.157] ** 1149 printk messages dropped ** [ 1.334927] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.157] ** 758 printk messages dropped ** [ 1.343679] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.157] ** 1154 printk messages d
ropped ** [ 1.357638] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.196] ** 1161 printk messages dropped ** [ 1.371030] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.196] ** 1131 printk messages dropped ** [ 1.384415] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.196] ** 431 printk messages dropped ** [ 1.389872] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[16:49:40.196]
** 4 printk messages dropped ** [ 1.389953] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0008(Transmitter ID)
[16:49:40.217]
I am looking for your advice.Thanks.
