I am using Astro carrier board with Astro breakout board. I am plugging in a mini PCIe to 4 port RS232 card. After bootting up I get following on by /dev for tty*
crw------- 1 nvidia tty 4, 64 Nov 21 21:07 ttyS0
crw-rw---- 1 root dialout 4, 65 Nov 21 21:06 ttyS1
crw-rw---- 1 root dialout 4, 66 Nov 21 21:07 ttyS2
crw-rw---- 1 root dialout 4, 67 Nov 21 21:06 ttyS3
crw-rw---- 1 root dialout 238, 1 Nov 21 20:41 ttyTHS1
crw-rw---- 1 root dialout 238, 2 Feb 11 2016 ttyTHS2
crw-rw---- 1 root dialout 238, 3 Feb 11 2016 ttyTHS3
When I use Cutecom to perform loopback test on the serial ports, none of the 4 serial ports respond to the loopback.
So I looked in to dmesg with dmesg |grep tty
I get following
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0321917026547 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.014179] console [tty0] enabled
[ 0.441455] console [ttyS0] disabled
[ 0.441542] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.392243] console [ttyS0] enabled
[ 2.394091] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.395069] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.396131] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 12.665081] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.724804] systemd[1]: Created slice system-getty.slice.
[ 13.308593] 0000:02:00.0: ttyS1 at MMIO 0x50200000 (irq = 388, base_baud = 7812500) is a XR17V35X
[ 13.308834] 0000:02:00.0: ttyS2 at MMIO 0x50200400 (irq = 388, base_baud = 7812500) is a XR17V35X
[ 13.309053] 0000:02:00.0: ttyS3 at MMIO 0x50200800 (irq = 388, base_baud = 7812500) is a XR17V35X
and I do sudo lspci -v
02:00.0 Serial controller: Exar Corp. Device 0354 (rev 03) (prog-if 02 [16550])
Flags: fast devsel, IRQ 388
Memory at 50200000 (32-bit, non-prefetchable)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Endpoint, MSI 01
Capabilities: [100] Virtual Channel
Kernel driver in use: serial
It looks like the kernel is recognizing the serial card but the ttyS* devices do not talk to the card for some reason.
Can someone help me find out if I am missing any step?
Do I need to load any kernel module?
Do I need to run anything before this can work?
