categraf: 2024/01/20 00:19:03 systemd_linux.go:178: E! couldn’t get unit NRestarts unit chronyd.service err Unknown property or interface.
categraf: 2024/01/20 00:19:03 systemd_linux.go:178: E! couldn’t get unit NRestarts unit nslcd.service err Unknown property or interface.
kernel: pciehp 0000:4c:01.0:pcie204: Slot(2-1): Card not present
kernel: pciehp 0000:4c:01.0:pcie204: Slot(2-1): Link Down
kernel: NVRM: GPU at PCI:0000:4e:00: GPU-6d34b5e2-a686-f21c-83b7-3b36cb566060
kernel: NVRM: Xid (PCI:0000:4e:00): 79, pid=‘’, name=, GPU has fallen off the bus.
kernel: NVRM: GPU 0000:4e:00.0: GPU has fallen off the bus.
kernel: NVRM: A GPU crash dump has been created. If possible, please run#012NVRM: nvidia-bug-report.sh as root to collect this data before#012NVRM: the NVIDIA kernel module is unloaded.
kernel: snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD buf size -1
mmsysmon: [I] Event raised: All quorum nodes are reachable PC_QUORUM_NODES
mmsysmon: [I] Event raised: The state of component GPFS changed to HEALTHY.
mmsysmon: [I] Event raised: The state of this node changed to HEALTHY.
kernel: NVRM: Attempting to remove device 0000:4e:00.0 with non-zero usage count!
systemd: Starting titanagent check exception…
systemd: Started titanagent check exception.
kernel: pciehp 0000:4c:01.0:pcie204: Slot(2-1): Card present
kernel: pciehp 0000:4c:01.0:pcie204: Slot(2-1): Link Up’
What are the possible causes of this problem?
