Peer-to-Peer not enabled on Dell R730 but is on Dell R740
I have two servers, one with two P100s on a Dell R730 host and three P100s on Dell R740 host. For some reason the R740 is peer to peer enabled, but not the R730. If anyone could advise how to enable it or perhaps just let me know that it’s impossible to enable it on the R730, that would be helpful. Here is what you get when you run the following commands:
nvidia-smi topo -m # ON R730
GPU0    GPU1    CPU Affinity
GPU0     X      SYS     0-0,2-2,4-4,6-6,8-8,10-10,12-12,14-14,16-16,18-18,20-20,22-22,24-24,26-26,28-28,30-30,32-32,34-34,36-36,38-38
GPU1    SYS      X      1-1,3-3,5-5,7-7,9-9,11-11,13-13,15-15,17-17,19-19,21-21,23-23,25-25,27-27,29-29,31-31,33-33,35-35,37-37,39-39
Legend:
  X    = Self
  SYS  = Connection traversing PCIe as well as the SMP interconnect between NUMA nodes (e.g., QPI/UPI)
  NODE = Connection traversing PCIe as well as the interconnect between PCIe Host Bridges within a NUMA node
  PHB  = Connection traversing PCIe as well as a PCIe Host Bridge (typically the CPU)
  PXB  = Connection traversing multiple PCIe switches (without traversing the PCIe Host Bridge)
  PIX  = Connection traversing a single PCIe switch
  NV#  = Connection traversing a bonded set of # NVLinks
nvidia-smi topo -m # ON R740
GPU0    GPU1    GPU2    CPU Affinity
GPU0     X      SYS     SYS     0-0,2-2,4-4,6-6,8-8,10-10,12-12,14-14,16-16,18-18,20-20,22-22,24-24,26-26,28-28,30-30,32-32,34-34,36-36,38-38,40-40,42-42
GPU1    SYS      X      NODE    1-1,3-3,5-5,7-7,9-9,11-11,13-13,15-15,17-17,19-19,21-21,23-23,25-25,27-27,29-29,31-31,33-33,35-35,37-37,39-39,41-41,43-43
GPU2    SYS     NODE     X      1-1,3-3,5-5,7-7,9-9,11-11,13-13,15-15,17-17,19-19,21-21,23-23,25-25,27-27,29-29,31-31,33-33,35-35,37-37,39-39,41-41,43-43
Legend:
  X    = Self
/usr/local/cuda-9.1/samples/0_Simple/simpleP2P/simpleP2P # ON R730
[/usr/local/cuda-9.1/samples/0_Simple/simpleP2P/simpleP2P] - Starting...
Checking for multiple GPUs...
CUDA-capable device count: 2
> GPU0 = "Tesla P100-PCIE-16GB" IS  capable of Peer-to-Peer (P2P)
> GPU1 = "Tesla P100-PCIE-16GB" IS  capable of Peer-to-Peer (P2P)
Checking GPU(s) for support of peer to peer memory access...
> Peer access from Tesla P100-PCIE-16GB (GPU0) -> Tesla P100-PCIE-16GB (GPU1) : No
> Peer access from Tesla P100-PCIE-16GB (GPU1) -> Tesla P100-PCIE-16GB (GPU0) : No
Two or more GPUs with SM 2.0 or higher capability are required for /usr/local/cuda-9.1/samples/0_Simple/simpleP2P/simpleP2P.
Peer to Peer access is not available amongst GPUs in the system, waiving test.
/usr/local/cuda-9.1/samples/0_Simple/simpleP2P/simpleP2P # ON R740
CUDA-capable device count: 3
> GPU2 = "Tesla P100-PCIE-16GB" IS  capable of Peer-to-Peer (P2P)
> Peer access from Tesla P100-PCIE-16GB (GPU0) -> Tesla P100-PCIE-16GB (GPU1) : Yes
> Peer access from Tesla P100-PCIE-16GB (GPU0) -> Tesla P100-PCIE-16GB (GPU2) : Yes
> Peer access from Tesla P100-PCIE-16GB (GPU1) -> Tesla P100-PCIE-16GB (GPU0) : Yes
> Peer access from Tesla P100-PCIE-16GB (GPU1) -> Tesla P100-PCIE-16GB (GPU2) : Yes
> Peer access from Tesla P100-PCIE-16GB (GPU2) -> Tesla P100-PCIE-16GB (GPU0) : Yes
> Peer access from Tesla P100-PCIE-16GB (GPU2) -> Tesla P100-PCIE-16GB (GPU1) : Yes
Enabling peer access between GPU0 and GPU1...
Checking GPU0 and GPU1 for UVA capabilities...
> Tesla P100-PCIE-16GB (GPU0) supports UVA: Yes
> Tesla P100-PCIE-16GB (GPU1) supports UVA: Yes
Both GPUs can support UVA, enabling...
Allocating buffers (64MB on GPU0, GPU1 and CPU Host)...
Creating event handles...
cudaMemcpyPeer / cudaMemcpy between GPU0 and GPU1: 8.20GB/s
Preparing host buffer and memcpy to GPU0...
Run kernel on GPU1, taking source data from GPU0 and writing to GPU1...
Run kernel on GPU0, taking source data from GPU1 and writing to GPU0...
Copy data back to host from GPU0 and verify results...
Disabling peer access...
Shutting down...
Test passed
P2P enablement depends on a number of factors. Increasing system design complexity means that it’s no longer possible to infer behavior of a system type based on behavior of another system type or any particular concise set of rules.
As a general rule, P2P support is determined by the software, not any set of published rules. Therefore, the only way to be sure of P2P support is to run the test on the system in question.
In this particular case, the R730 is a broadwell system with the GPUs in question attached to separate sockets. In this particular configuration, P2P is not supported between the 2 GPUs, because they are on separate CPU sockets, and P2P traffic could not reliably flow over the QPI socket link.
In the R740 case, it is a skylake system. The rules here are different, and with Skylake on this particular system, P2P support is enabled even between GPUs connected to separate sockets. In that case, P2P traffic is travelling over the UPI link that connects CPU sockets. This was not typical/available/possible in the broadwell generation, but is possible, in some cases, in the skylake CPU generation.
This should not be interpreted as a blanket statement of how and whether to expect P2P support on any particular system. instead, the test should be run.
In short, your results are expected.
You’ll note that in your R740 configuration, 2 of the GPUs are attached to the same socket. If you had a similar configuration with R730, you would probably find that P2P support between those 2 GPUs is possible. I don’t know if this is possible with R730, and I’m not counseling or advising you to attempt to modify your system. Any such endeavor would be at your own risk. To discover what is possible or supported here, I would contact the OEM vendor of the system (Dell).
