First result (disappointing) :
qcam5@ubuntu:~$ v4l2-ctl --list-formats-ext -d1
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'RG12' (12-bit Bayer RGRG/GBGB)
Size: Discrete 4128x3008
Interval: Continuous 0.034s - 22.934s (0.044-29.200 fps)
[1]: 'Y16 ' (16-bit Greyscale)
[2]: 'GREY' (8-bit Greyscale)
qcam5@ubuntu:~$ nvargus_nvraw --format jpg --c 1 --file /tmp/byargus_nraw-1.jpg nvargus_nvraw version 1.14.0
("nvargus_nvraw") Error BadParameter (0x04): No events in queue (in capture_nvraw/src/mobile/ArgusNvRawCapture.cpp,
func captureRequest(), line 700)
("nvargus_nvraw") Error BadParameter (0x04): (propagating from capture_nvraw/src/mobile/ArgusNvRawCapture.cpp,
func capture(), line 810)
("nvargus_nvraw") Error BadParameter (0x04): Unable to capture (propagating from capture_nvraw/src/mobile/main.cpp,
func main(), line 97)
qcam5@ubuntu:~$
and here are the messages from nvargus-daemon
Connection established (FFFF8F194900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
[IspConfigCheckNR] Error: both NR v8 and v6 are enabled.
Config Error: sensor load cfg: 1, cfg check: 0
socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such file or directory
D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
queue_or_send() failed
CameraProvider initialized (0xffff886e7c20)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
LSC:patch width less than 12LSC:patch width less than 12(NvCamV4l2) Error BadParameter: 0x32314742 pixelFormat not found under current active buffer type (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setActivePixelFormat(), line 1457)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function enableStreamingConfiguration(), line 2343)
(NvOdmDevice) Error BadParameter: enableStreamingConfiguration FAILED (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorBase.cpp, function writeMode(), line 328)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 218)
(NvCamV4l2) Error InvalidState: Invalid active Mode Size (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function streamControl(), line 1655)
(NvOdmDevice) Error InvalidState: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 277)
Module_id 30 Severity 2 : (fusa) Error: Timeout propagating from:/capture/src/fusaViHandler.cpp 776
SCF: Error InvalidState: Sensor 1 already in same state
(in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 0 draining session frameEnd events 3
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 635)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 1 draining session frameEnd events 2
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 2 draining session frameEnd events 1
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 1 draining session frameStart events 2
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 532)
LSC:patch width less than 12SCF: Error Timeout: Sending critical error event for Session 1
(in src/api/Session.cpp, function sendErrorEvent(), line 1039)
PowerServiceCore:handleRequests: timePassed = 2505
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 368)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 1034)
SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1129)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 3 draining session frameEnd events 1
SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 1, capture sequence ID = 3 draining session frameStart events 1
SCF: Error Timeout: NvRmSyncWait failed (in src/api/Buffer.cpp, function cpuWaitFences(), line 622)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function cpuWaitInputFences(), line 543)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function acquire(), line 680)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function ScopedBufferLock(), line 657)
PowerServiceCore:handleRequests: timePassed = 16806
CameraProvider destroyed (0xffff886e7c20)(NvOdmDevice) Error FileOperationFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/HotplugMonitor.cpp, function close(), line 153)
(NvOdmDevice) Error FileOperationFailed: Failure in HotplugMonitor::close() (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/HotplugMonitor.cpp, function removeHotplugCallback(), line 830)
I see that nvargus-daemon is looking for 0x32314742, that’s actually BG12, not RG12.
