Performance analysis on Jetson Orin Nano 8GB
I am using Jetson Orin Nano 8GB developer kit. And I am a beginner to edge development and deployment.
and I am using the following packages
python: 3.8.10
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.5
cuDNN Version: 8.6
libNVWarp360 Version: 2.0.1d3
numpy: 4.9.0
opencv: 1.23.5
Actually, I have to fuse two frames coming from thermal and optical cameras. I am using TarDAL (GitHub - JinyuanLiu-CV/TarDAL: CVPR 2022 | Target-aware Dual Adversarial Learning and a Multi-scenario Multi-Modality Benchmark to Fuse Infrared and Visible for Object Detection.) for fusion. I have first converted trained PyTorch model to onnx and then to tensorrt with fp16 precision. The model shows improvement in speed and fusion takes around ~60ms with tensorrt. However, the strange thing is that when I don’t use tensorrt engine file for inference and use just the trained pytorch model in .pth format I get ~6ms fusion inference. However, again the strange thing is that with tensorrt the preprocessing and post processing takes around ~90ms and without it takes more than 300ms. So the overall tensorrt takes around ~150ms and PyTorch trained model takes more than ~320 ms for inference with opencv on jetson orin nano. Could anyone please let me know why is that? Should I change my code to read streams concurrently, how I can I optimize my code. the code is given below:
fusion_inferece_code
import cv2
import numpy as np
import argparse
import yaml
from typing import Tuple
from pathlib import Path
import time
import matplotlib.pyplot as plt
import warnings
warnings.filterwarnings("ignore")
import torch
from torchvision.transforms import ToTensor, Resize, Grayscale, ToPILImage
import torchvision.transforms as trf
import torchvision.transforms.functional as F
from torch import Tensor
# import loader
from config import ConfigDict, from_dict
from pipeline.fuse import Fuse
from tools.dict_to_device import dict_to_device
from kornia.color import rgb_to_ycbcr, bgr_to_rgb, rgb_to_bgr, ycbcr_to_rgb
# load tensorrt engine file
from run_trt_inference import RunTRT
# Logger
import logging
logger = logging.getLogger(__name__)
logger.setLevel(logging.INFO)
stream_handler = logging.StreamHandler()
formatter = logging.Formatter(fmt = "%(asctime)s: %(message)s", datefmt= '%Y-%m-%d %H:%M%S')
stream_handler.setFormatter(formatter)
logger.addHandler(stream_handler)
def align_images(img1, img2, hmatrix):
    Align two frames for fusion
    Parameters
    img1: Numpy.ndarray
    img2: Numpy.ndarray
    homography: str (Path)
    Return
    aligned_img2: Numpy.ndarray
    # Apply perspective transformation to img2 (thermal image)
    aligned_img2 = cv2.warpPerspective(img2, hmatrix, (img1.shape[1], img1.shape[0]))
    return aligned_img2
def get_ms(tic, toc):
    return (toc - tic) * 1000
def read_grayscale(frame, transformation=None):
    read in grayscale format and preprocess the frame
    parameters
    frame: Numpy.ndarray
    im = transformation(frame)
    im = F.rgb_to_grayscale(im)
    if len(im.shape) == 3:
        im = im[None]  # expand for batch dim
    return im
def ycbcr_read(frame, transformation=None) -> Tuple[Tensor, Tensor]:
    read in ycbr format and preporcessin the frame
    parameters
    img_t = transformation(frame)
    img_t = rgb_to_ycbcr(bgr_to_rgb(img_t))
    y, cbcr = torch.split(img_t, [1, 2], dim=0)
    if len(y.shape) ==3:
        y = y[None]
        cbcr = cbcr[None]
    return y, cbcr
def image_fusion(frame1, frame2, homography, fuse, trt, transformation=None):
    Fuse two video frames
    Parameters
    frame1: Numpy.ndarray
    frame2: Numpy.ndarray
    homography: str (path to the homography matrix)
    fuse: Fusion object
    Return
    fused_frame: Numpy.ndarray
    pre_tic = time.time()
    # since the acquired images are not well aligend, wrap the thermal image on the coordinates of optical image
    frame2_aligned = align_images(frame1, frame2, homography) # 25 ms avg
    # read frame as ycbcr, gray and cbcr channels for post processing
    frame1, cbcr = ycbcr_read(frame1, transformation=transformation)
    frame2_aligned = read_grayscale(frame2_aligned, transformation=transformation) # 40 ms preprocessing block
    assert frame1.shape == frame2_aligned.shape, 'both frames should have the same size'
    pre_toc = time.time()
    pre_processing_time = get_ms(pre_tic, pre_toc)
    # run inference on optical and aligned thermal frames
    infer_tic = time.time()
    if not trt:
        device = 'cuda' if torch.cuda.is_available() else 'cpu'
        fused_frame = fuse.inference(ir=frame1.to(device), vi=frame2_aligned.to(device))
    else:
        frame1, frame2_aligned = frame1.permute(0, 2, 3, 1).numpy().astype(np.float16), frame2_aligned.permute(0, 2, 3, 1).numpy().astype(np.float16)
        fused_frame = fuse.predict((frame1, frame2_aligned))
        # plt.imshow(fused_frame[0], cmap= 'gray')
        # plt.show()
        fused_frame = torch.from_numpy(fused_frame).permute(0, 3, 1, 2)
    infer_toc = time.time()
    infer_time = get_ms(infer_tic, infer_toc)
    post_tic = time.time()
    fused_frame = torch.cat([fused_frame.cpu(), cbcr], dim=1)
    fused_frame = ycbcr_to_rgb(fused_frame)
    fused_frame = fused_frame.numpy().squeeze(0)
    fused_frame = np.transpose(fused_frame, (1, 2, 0))
    fused_frame = cv2.cvtColor(fused_frame, cv2.COLOR_RGB2BGR)
    post_toc = time.time()
    post_time = get_ms(post_tic, post_toc)
    return fused_frame, pre_processing_time, infer_time, post_time
def process_frames(video_path1, video_path2, homography, fuse, write=False, trt = False, transformation=None):
    process the fusion videos
    parameters
    video_path1: str
    video_path2: str
    homography: str
    fuse: Fusion object
    cap1 = cv2.VideoCapture(video_path1)
    cap2 = cv2.VideoCapture(video_path2)
    durations = []
    if write:
        frame_width = int(cap1.get(cv2.CAP_PROP_FRAME_WIDTH))
        frame_height = int(cap1.get(cv2.CAP_PROP_FRAME_HEIGHT))
        fps = int(cap1.get(cv2.CAP_PROP_FPS))
        codec = cv2.VideoWriter_fourcc(*'XVID')
        out = cv2.VideoWriter('videos/output.mp4', codec, fps, (frame_width, frame_height))
    while cap1.isOpened() and cap2.isOpened():
        # tic_pre = time.time()
        ret1, frame1 = cap1.read()
        ret2, frame2 = cap2.read()
        if not (ret1 and ret2):
            break
        # Perform image fusion
        tic = time.time()
        fused_frame, pre_time, infer_time, post_time = image_fusion(frame1, frame2, homography, fuse, trt, transformation=transformation)
        toc = time.time()
        duration = (toc - tic) * 1000
        durations.append(duration)
        print(f'Total mean: {(np.mean(durations)): .2f} ms', end= "")
        print(f' Pre processing: {pre_time: .2f} ms, Fusion inference: {infer_time: .2f} ms, Post processing: {post_time: .2f} ms')
        # write the video
        if write:
            # np.uint8(image)
            img = cv2.cvtColor(np.uint8(fused_frame), cv2.COLOR_BGR2RGB)
            out.write(img)
        # Display or write the fused frame here
        cv2.imshow('Fused Frame', fused_frame)
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    cap1.release()
    cap2.release()
    if write:
        out.release()
    cv2.destroyAllWindows()
if __name__ == "__main__":
    # Get command line args
    parser = argparse.ArgumentParser()
    parser.add_argument('--video1', type = str, default = 'videos/1_optical.mp4', help = 'path to optical video')
    parser.add_argument('--video2', type = str, default = 'videos/1_thermal.mp4', help = 'path to thermal video')
    parser.add_argument('--cfg', default='config/default.yaml', help='config file path')
    parser.add_argument('--homography', type = str, default = 'camera_data/homography.npz', help = 'homography path')
    parser.add_argument('--engine', type = str, default= None, help = 'path to save the generated trt file')
    parser.add_argument('--fp16', action= "store_true",  help = 'use fp16 precisoin')
    parser.add_argument('--batch', type = int, default=32, help = 'batch size')
    parser.add_argument('--write', action = 'store_true', help = 'flag to save the video')
    parser.add_argument('--trt', action = 'store_true', help = 'use tensor rt backend')
    args = parser.parse_args()
    # init config
    logger.info("Initialize model configs")
    config  = args.cfg
    if isinstance(config, str) or isinstance(config, Path):
        config = yaml.safe_load(Path(config).open('r'))
        config = from_dict(config)  # convert dict to object
    else:
        config = config
    # load h matrix
    homography_matrix = np.load(args.homography, allow_pickle = True)
    hmat = homography_matrix['homography']
    # image transforms
    image_shape = (640, 640, 1)
    frame_transformation = trf.Compose([
                                ToPILImage(),
                                Resize(size = image_shape[:2]),
                                ToTensor()])
    # init pipeline
    if not args.trt:
        # use without tensorrt
        fuse = Fuse(config, mode='inference')
        logger.info("Inference: Without using TensorRT")
        process_frames(args.video1, args.video2, hmat, fuse, args.write, trt=False, transformation=frame_transformation)
    else:
        # use tensorrt
        data_type = "fp16" if args.fp16 else "fp32"
        # Image transforms
                                        Grayscale(num_output_channels = 1),
                                        ToTensor()])
        # Initialize tensorrt wrapper
        logger.info("Create TensorRT engine instance for inference.")
        trt_wrapper = RunTRT(args.engine, data_type= data_type, batch_size= args.batch, image_shape= image_shape,
                                img_transforms= transformation, homography_mat= args.homography)
        logger.info("Warm up")
        trt_wrapper.warmup()
        logger.info("Inference: using TensorRT")
        # Run inference
        process_frames(args.video1, args.video2, hmat, trt_wrapper, args.write, trt=True, transformation=frame_transformation)
Dear @engrfaizan.ai,
Could you check dumping the profiling info of each layer to see the bottlenecks?
