I adapted a cuSPARSE example (shown below) to benchmark cusparseSpMM. The code benchmarks the dense matrix memory bandwidth (I have my reasons for that) and I would like to get as close to the full bandwidth as possible. The code is setup to perform a non-transpose SpMM operation with the dense matrix either in col- or row-major format and with ALG1 (suggested with col-major) or ALG2 (suggested with row-major). I’m using the CUDA Toolkit v11.7 (also tried v12 which yielded the same results) and A100 cards with 40GB memory.
Let’s consider (col, alg1) first. If the dense matrix is large enough (as specified in the legend by [log2(#vec)]), I can get up to 1500 GB/s for a certain range of sparse matrix dimensions. The strange thing is that there is a sharp drop in performance passed a certain sparse matrix dimension, and that sparse matrix dimension cutoff is multiplied by two when the number of entries in the dense matrix is also multiplied by two. A quite regular pattern emerges. The strangest things is the following, take for example the 2**29 and 2**30 problems with a sparse matrix of dimension 2**9, which timings data is as follows
SIZE, SPSIZE, TIME, BANDWIDTH
536870912, 9, 0.218228, 393.622
1073741824, 9, 0.110788, 1550.7
The drop in performance is so severe (about x4) that it takes half the time to multiply twice as much data.
In other words, it would be faster to double the problem size with padding, then perform the smaller matrix multiply.
I don’t really see how that could happen except for poor heuristics mapping the problem to the GPU hardware, but I may be missing something.
Let’s consider (col, alg2) now (so CUSPARSE_SPMM_CSR_ALG2). We get better performance for smaller sparse and dense matrices. This is somewhat unexpected as the documentation mentions that CUSPARSE_SPMM_CSR_ALG1 “[p]rovide[s] the best performance with column-major layout”. In addition, the performance cutoff pattern reappears, but the cutoffs are now lower than for CUSPARSE_SPMM_CSR_ALG1.
The situation is similar for the row-major benchmarks, except that the low-performance plateaus are lower than for col-major ordering.
* Copyright 1993-2022 NVIDIA Corporation. All rights reserved.
* NOTICE TO LICENSEE:
* This source code and/or documentation ("Licensed Deliverables") are
* subject to NVIDIA intellectual property rights under U.S. and
* international Copyright laws.
* These Licensed Deliverables contained herein is PROPRIETARY and
* CONFIDENTIAL to NVIDIA and is being provided under the terms and
* conditions of a form of NVIDIA software license agreement by and
* between NVIDIA and Licensee ("License Agreement") or electronically
* accepted by Licensee. Notwithstanding any terms or conditions to
* the contrary in the License Agreement, reproduction or disclosure
* of the Licensed Deliverables to any third party without the express
* written consent of NVIDIA is prohibited.
* NOTWITHSTANDING ANY TERMS OR CONDITIONS TO THE CONTRARY IN THE
* LICENSE AGREEMENT, NVIDIA MAKES NO REPRESENTATION ABOUT THE
* SUITABILITY OF THESE LICENSED DELIVERABLES FOR ANY PURPOSE. IT IS
* PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY OF ANY KIND.
* NVIDIA DISCLAIMS ALL WARRANTIES WITH REGARD TO THESE LICENSED
* DELIVERABLES, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY,
* NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
* LICENSE AGREEMENT, IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY
* SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, OR ANY
* DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
* WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
* ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
* OF THESE LICENSED DELIVERABLES.
* U.S. Government End Users. These Licensed Deliverables are a
* "commercial item" as that term is defined at 48 C.F.R. 2.101 (OCT
* 1995), consisting of "commercial computer software" and "commercial
* computer software documentation" as such terms are used in 48
* C.F.R. 12.212 (SEPT 1995) and is provided to the U.S. Government
* only as a commercial end item. Consistent with 48 C.F.R.12.212 and
* 48 C.F.R. 227.7202-1 through 227.7202-4 (JUNE 1995), all
* U.S. Government End Users acquire the Licensed Deliverables with
* only those rights set forth herein.
* Any use of the Licensed Deliverables in individual and commercial
* software must include, in the user documentation and internal
* comments to the code, the above Disclaimer and U.S. Government End
* Users Notice.
#include <cuda.h>
#include <cuda_runtime_api.h> // cudaMalloc, cudaMemcpy, etc.
#include <cusparse.h> // cusparseSpMM
#include <stdio.h> // printf
#include <stdlib.h> // EXIT_FAILURE
#include <cassert>
#include <cmath>
#include <sys/time.h> // gettimeofday()
#include <sys/types.h> // struct timeval
#include <complex>
#include <cuComplex.h>
using cuZ = cuDoubleComplex;
#define CHECK_CUDA(func) \
cudaError_t status = (func); \
if (status != cudaSuccess) { \
printf("CUDA API failed at line %d with error: %s (%d)\n", __LINE__, \
cudaGetErrorString(status), status); \
return EXIT_FAILURE; \
#define CHECK_CUSPARSE(func) \
cusparseStatus_t status = (func); \
if (status != CUSPARSE_STATUS_SUCCESS) { \
printf("CUSPARSE API failed at line %d with error: %s (%d)\n", __LINE__, \
cusparseGetErrorString(status), status); \
void get_A_matrix(const int sblk, int *hA_csrOffsets, int *hA_columns,
cuDoubleComplex *hA_values);
double getTime();
void tellTime(int size, int rank, int param0, int param1, double elapsedTime);
int main(int argc, char *argv[]) {
cusparseOrder_t order = CUSPARSE_ORDER_COL;
cusparseSpMMAlg_t algo = (order == CUSPARSE_ORDER_ROW)
? CUSPARSE_SPMM_CSR_ALG2
: CUSPARSE_SPMM_CSR_ALG1;
algo = CUSPARSE_SPMM_CSR_ALG1;
cusparseOperation_t trans = CUSPARSE_OPERATION_NON_TRANSPOSE; // fixed
// READ COMMAND LINE ARGUMENTS
std::size_t log_S = 20; // log size
std::size_t S = 0; // total size 2**log_S
std::size_t T = 0; // target (block size)
std::size_t nrepeat = 100; // number of repeats of the test
for (int i = 0; i < argc; i++) {
if ((strcmp(argv[i], "-T") == 0)) {
T = atoi(argv[++i]);
} else if ((strcmp(argv[i], "-S") == 0)) {
log_S = atof(argv[++i]);
} else if (strcmp(argv[i], "-nrepeat") == 0) {
nrepeat = atoi(argv[++i]);
} else if ((strcmp(argv[i], "-h") == 0) ||
(strcmp(argv[i], "-help") == 0)) {
printf(" H*V Options:\n");
printf(" -T <int>: target (default: 0)\n");
printf(" -Size (-S) <int>: log size (num)"
"size 2**num (default: 2**20 = 1024*1024 )\n");
printf(" -nrepeat <int>: number of repetitions (default: "
"100)\n");
printf(" -help (-h): print this message\n\n");
exit(1);
S = pow(2, log_S);
std::size_t sblk = std::pow(2, T); // block size div-by-2
std::size_t nblk = std::pow(2, log_S - T - 1); // number of blocks
// HOST PROBLEM DEFINITION
int A_num_rows = sblk * 2;
int A_num_cols = sblk * 2;
int A_nnz = sblk * 4; // 2 non-zero per row/col
int B_num_rows = A_num_cols;
int B_num_cols = nblk;
int B_size = B_num_rows * B_num_cols;
int C_size = A_num_rows * B_num_cols;
int ldb = (order == CUSPARSE_ORDER_ROW) ? B_size / B_num_rows : B_num_rows;
int ldc = (order == CUSPARSE_ORDER_ROW) ? C_size / A_num_rows : A_num_rows;
int *hA_csrOffsets;
int *hA_columns;
cuZ *hA_values;
cuZ *hB;
cuZ *hC;
cuZ *hC_result;
cuZ alpha = {1.0, 0.0};
cuZ beta = {0.0, 0.0};
hA_csrOffsets = (int *)malloc((A_num_rows + 1) * sizeof(int));
hA_columns = (int *)malloc(A_nnz * sizeof(int));
hA_values = (cuZ *)malloc(A_nnz * sizeof(cuZ));
hB = (cuZ *)malloc(std::pow(2, log_S) * sizeof(cuZ));
hC = (cuZ *)malloc(std::pow(2, log_S) * sizeof(cuZ));
hC_result = (cuZ *)malloc(std::pow(2, log_S) * sizeof(cuZ));
get_A_matrix(sblk, hA_csrOffsets, hA_columns, hA_values);
// DEVICE MEMORY MANAGEMENT
int *dA_csrOffsets, *dA_columns;
cuZ *dA_values, *dB, *dC;
CHECK_CUDA(cudaSetDevice(0));
CHECK_CUDA(
cudaMalloc((void **)&dA_csrOffsets, (A_num_rows + 1) * sizeof(int)))
CHECK_CUDA(cudaMalloc((void **)&dA_columns, A_nnz * sizeof(int)))
CHECK_CUDA(cudaMalloc((void **)&dA_values, A_nnz * sizeof(cuZ)))
CHECK_CUDA(cudaMalloc((void **)&dB, B_size * sizeof(cuZ)))
CHECK_CUDA(cudaMalloc((void **)&dC, C_size * sizeof(cuZ)))
CHECK_CUDA(cudaMemcpy(dA_csrOffsets, hA_csrOffsets,
(A_num_rows + 1) * sizeof(int), cudaMemcpyHostToDevice))
CHECK_CUDA(cudaMemcpy(dA_columns, hA_columns, A_nnz * sizeof(int),
CHECK_CUDA(cudaMemcpy(dA_values, hA_values, A_nnz * sizeof(cuZ),
CHECK_CUDA(cudaMemcpy(dB, hB, B_size * sizeof(cuZ), cudaMemcpyHostToDevice))
CHECK_CUDA(cudaMemcpy(dC, hC, C_size * sizeof(cuZ), cudaMemcpyHostToDevice))
// CUSPARSE APIs
cusparseHandle_t handle = NULL;
cusparseSpMatDescr_t matA;
cusparseDnMatDescr_t matB, matC;
void *dBuffer = NULL;
size_t bufferSize = 0;
CHECK_CUSPARSE(cusparseCreate(&handle))
// Create sparse matrix A in CSR format
CHECK_CUSPARSE(cusparseCreateCsr(&matA, A_num_rows, A_num_cols, A_nnz,
dA_csrOffsets, dA_columns, dA_values,
CUSPARSE_INDEX_32I, CUSPARSE_INDEX_32I,
CUSPARSE_INDEX_BASE_ZERO, CUDA_C_64F))
// Create dense matrix B
CHECK_CUSPARSE(cusparseCreateDnMat(&matB, A_num_cols, B_num_cols, ldb, dB,
CUDA_C_64F, order))
// Create dense matrix C
CHECK_CUSPARSE(cusparseCreateDnMat(&matC, A_num_rows, B_num_cols, ldc, dC,
CUDA_C_64F, order))
// allocate an external buffer if needed
CHECK_CUSPARSE(cusparseSpMM_bufferSize(handle, trans, trans, &alpha, matA,
matB, &beta, matC, CUDA_C_64F, algo,
&bufferSize))
CHECK_CUDA(cudaMalloc(&dBuffer, bufferSize))
// execute SpMM
cudaDeviceSynchronize();
double startTime = getTime();
for (int c = 0; c < nrepeat; ++c) {
CHECK_CUSPARSE(cusparseSpMM(handle, trans, trans, &alpha, matA, matB, &beta,
matC, CUDA_C_64F, algo, dBuffer))
double Gbytes = 1.0e-9 * double(sizeof(cuZ) * S);
auto time = (getTime() - startTime);
printf("%12d, %12d, %12d, %12g, %12g, %12g\n", S, T, nrepeat, Gbytes * 1000,
time, Gbytes * nrepeat / time);
// CLEANUP
// destroy matrix/vector descriptors
CHECK_CUSPARSE(cusparseDestroySpMat(matA))
CHECK_CUSPARSE(cusparseDestroyDnMat(matB))
CHECK_CUSPARSE(cusparseDestroyDnMat(matC))
CHECK_CUSPARSE(cusparseDestroy(handle))
// device memory deallocation
CHECK_CUDA(cudaFree(dBuffer))
CHECK_CUDA(cudaFree(dA_csrOffsets))
CHECK_CUDA(cudaFree(dA_columns))
CHECK_CUDA(cudaFree(dA_values))
CHECK_CUDA(cudaFree(dB))
CHECK_CUDA(cudaFree(dC))
// host memory deallocation
free(hA_csrOffsets);
free(hA_columns);
free(hA_values);
free(hB);
free(hC);
free(hC_result);
return EXIT_SUCCESS;
cuZ *hA_values) {
std::size_t count = 0;
std::size_t i;
for (i = 0; i < sblk; ++i) {
hA_csrOffsets[i] = count;
hA_columns[count] = i;
hA_values[count] = {1.0, 0.0};
count += 1;
hA_columns[count] = i + sblk;
count += 1;
for (i = sblk; i < 2 * sblk; ++i) {
hA_columns[count] = i - sblk;
count += 1;
count += 1;
hA_csrOffsets[++i] = count;
double getTime() {
struct timeval tv;
gettimeofday(&tv, nullptr);
return tv.tv_sec + tv.tv_usec * 1.e-6;
void tellTime(int size, int rank, int param0, int param1, double elapsedTime) {
if (rank == 0) {
printf("%6d, ", size);
printf("%10d, ", param0);
printf("%10d, ", param1);
printf("%12.8f\n", elapsedTime);
