Periodically resume to black screen using kernel 6.10.4 with nvidia driver 555.58.02-15 on GTX 970
Hi, I am unable to reliably resume from suspend (S3) when using the Nvidia driver version 555.58.02-15. If I suspend the system into S3 and wake it immediately after it will wake successfully and I will be able to use graphical applications.
However, if I leave the system idle in S3 for a long time (usually over an hour), then the system will consistently fail to resume correctly, and resume to a black screen. The monitors illuminate as though there should be output from the GPU, but nothing is on screen. The system is accessible over SSH, but I cannot get output on the monitors (even if I restart X11 with sudo systemctl restart gdm)
System details:
Asus Z170I Pro Gaming Motherboard
Gigabyte GTX 970 Windforce
Arch Linux (kernel 6.10.4-arch2-1)
Nvidia closed source driver (555.58.02-15)
Running with X11 (gdm 46.2-2)
Kenel commandline: root=PARTUUID=c99ee177-51d8-463e-8e34-84ad44712b35 rw initrd=/intel-ucode.img initrd=/initramfs-linux.img crashkernel=512M console=ttyUSB0,115200
Modesetting is disabled, and I have no applied any special configurations to the kernel module.
What I have tried to resolve the issue:
  • Enabling preservation of all video memory after suspend (and modesettting), as described here: NVIDIA/Tips and tricks - ArchWiki. This seemed to cause errors to appear in the kernel log while suspending the system, rather than while waking it (which I can attempt to gather if desired) Regardless, it did not resolve the issue.
I’ve attached kernel logs from just after waking from suspend that seem like they may point to the problem, as well as the output of sudo nvidia-bug-report.sh --safe-mode --extra-system-data, as running without any options resulted in the script hanging. Please let me know if there is any additional information I should provide or tests I should run
(Possibly) relevant kernel logs:
< ---------- cut here ------------------- >
Aug 17 00:16:42 Daniels-Desktop kernel: ACPI: PM: Low-level resume complete
Aug 17 00:16:42 Daniels-Desktop kernel: ACPI: EC: EC started
Aug 17 00:16:42 Daniels-Desktop kernel: ACPI: PM: Restoring platform NVS memory
Aug 17 00:16:42 Daniels-Desktop kernel: Enabling non-boot CPUs ...
Aug 17 00:16:42 Daniels-Desktop kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Aug 17 00:16:42 Daniels-Desktop kernel: CPU1 is up
Aug 17 00:16:42 Daniels-Desktop kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Aug 17 00:16:42 Daniels-Desktop kernel: CPU2 is up
Aug 17 00:16:42 Daniels-Desktop kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Aug 17 00:16:42 Daniels-Desktop kernel: CPU3 is up
Aug 17 00:16:42 Daniels-Desktop kernel: ACPI: PM: Waking up from system sleep state S3
Aug 17 00:16:42 Daniels-Desktop kernel: ACPI: EC: interrupt unblocked
Aug 17 00:16:42 Daniels-Desktop kernel: ACPI: EC: event unblocked
Aug 17 00:16:42 Daniels-Desktop kernel: xhci_hcd 0000:06:00.0: xHC error in resume, USBSTS 0x401, Reinit
Aug 17 00:16:42 Daniels-Desktop kernel: usb usb3: root hub lost power or was reset
Aug 17 00:16:42 Daniels-Desktop kernel: usb usb4: root hub lost power or was reset
Aug 17 00:16:42 Daniels-Desktop kernel: sd 4:0:0:0: [sdb] Starting disk
Aug 17 00:16:42 Daniels-Desktop kernel: sd 0:0:0:0: [sda] Starting disk
Aug 17 00:16:42 Daniels-Desktop kernel: usb 1-10: reset full-speed USB device number 5 using xhci_hcd
Aug 17 00:16:42 Daniels-Desktop kernel: nct6775: Enabling hardware monitor logical device mappings.
Aug 17 00:16:42 Daniels-Desktop kernel: BUG: unable to handle page fault for address: ffffa29d8bfce834
Aug 17 00:16:42 Daniels-Desktop kernel: #PF: supervisor read access in kernel mode
Aug 17 00:16:42 Daniels-Desktop kernel: #PF: error_code(0x0000) - not-present page
Aug 17 00:16:42 Daniels-Desktop kernel: PGD 100000067 P4D 100000067 PUD 100206067 PMD 0
Aug 17 00:16:42 Daniels-Desktop kernel: Oops: Oops: 0000 [#1] PREEMPT SMP PTI
Aug 17 00:16:42 Daniels-Desktop kernel: CPU: 0 PID: 513 Comm: irq/136-nvidia Kdump: loaded Tainted: P        W  OE      6.10.4-arch2-1 #1 517ed45cc9c4492ee5d5bfc2d2fe6ef1f2e7a8eb
Aug 17 00:16:42 Daniels-Desktop kernel: Hardware name: System manufacturer System Product Name/Z170I PRO GAMING, BIOS 3805 05/16/2018
Aug 17 00:16:42 Daniels-Desktop kernel: RIP: 0010:_nv012398rm+0xbd/0x130 [nvidia]
Aug 17 00:16:42 Daniels-Desktop kernel: Code: 8b 45 20 41 bf 01 00 00 00 41 89 54 24 20 41 89 44 24 24 4c 89 e6 4c 89 ef e8 ef 78 65 00 49 89 c4 48 85 c0 74 5f 49 8b 0c 24 <8b> 41 04 0f ae e8 41 39 44 24 20 74 dc 8b 41 08 0f b7 d8 25 00 00
Aug 17 00:16:42 Daniels-Desktop kernel: RSP: 0018:ffffa29d82887cc0 EFLAGS: 00010282
Aug 17 00:16:42 Daniels-Desktop kernel: RAX: ffff940cf3d37098 RBX: 0000000000000001 RCX: ffffa29d8bfce830
Aug 17 00:16:42 Daniels-Desktop kernel: RDX: fffffffffffffff0 RSI: ffff940c963d3008 RDI: ffff940c963d38e8
Aug 17 00:16:42 Daniels-Desktop kernel: RBP: ffff940ca48eabe0 R08: 0000000000000000 R09: 0000000000000020
Aug 17 00:16:42 Daniels-Desktop kernel: R10: ffff940ca48eac24 R11: ffffffffc08fda10 R12: ffff940cf3d37098
Aug 17 00:16:42 Daniels-Desktop kernel: R13: ffff940c963d38e8 R14: ffff940c963d3008 R15: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: FS:  0000000000000000(0000) GS:ffff940fa6c00000(0000) knlGS:0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 17 00:16:42 Daniels-Desktop kernel: CR2: ffffa29d8bfce834 CR3: 00000003ae020003 CR4: 00000000003706f0
Aug 17 00:16:42 Daniels-Desktop kernel: Call Trace:
Aug 17 00:16:42 Daniels-Desktop kernel:  <TASK>
Aug 17 00:16:42 Daniels-Desktop kernel:  ? __die_body.cold+0x19/0x27
Aug 17 00:16:42 Daniels-Desktop kernel:  ? page_fault_oops+0x15a/0x2d0
Aug 17 00:16:42 Daniels-Desktop kernel:  ? search_bpf_extables+0x5f/0x80
Aug 17 00:16:42 Daniels-Desktop kernel:  ? exc_page_fault+0x18a/0x190
Aug 17 00:16:42 Daniels-Desktop kernel:  ? asm_exc_page_fault+0x26/0x30
Aug 17 00:16:42 Daniels-Desktop kernel:  ? _nv012399rm+0x1f0/0x1f0 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  ? _nv012398rm+0xbd/0x130 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  _nv035255rm+0x19c/0x2f0 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  _nv030183rm+0x21/0xc0 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  _nv021801rm+0x292/0x3c4 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  _nv031947rm+0x60/0xc0 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  _nv012544rm+0x27f/0x3f0 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  _nv031957rm+0x167/0x1d0 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  _nv000735rm+0x113/0x150 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  rm_isr_bh+0x20/0x5c [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  nvidia_isr_kthread_bh+0x1f/0x50 [nvidia c7f6e139f220ed9e0f8d83b04273a1b52e844dc8]
Aug 17 00:16:42 Daniels-Desktop kernel:  irq_thread_fn+0x20/0x60
Aug 17 00:16:42 Daniels-Desktop kernel:  irq_thread+0x18a/0x270
Aug 17 00:16:42 Daniels-Desktop kernel:  ? __pfx_irq_thread_fn+0x10/0x10
Aug 17 00:16:42 Daniels-Desktop kernel:  ? __pfx_irq_thread_dtor+0x10/0x10
Aug 17 00:16:42 Daniels-Desktop kernel:  ? __pfx_irq_thread+0x10/0x10
Aug 17 00:16:42 Daniels-Desktop kernel:  kthread+0xcf/0x100
Aug 17 00:16:42 Daniels-Desktop kernel:  ? __pfx_kthread+0x10/0x10
Aug 17 00:16:42 Daniels-Desktop kernel:  ret_from_fork+0x31/0x50
Aug 17 00:16:42 Daniels-Desktop kernel:  ret_from_fork_asm+0x1a/0x30
Aug 17 00:16:42 Daniels-Desktop kernel:  </TASK>
Aug 17 00:16:42 Daniels-Desktop kernel: Modules linked in: rfcomm cmac algif_hash algif_skcipher af_alg bnep joydev mousedev snd_ctl_led btusb btrtl btintel snd_usb_audio uvcvideo btbcm btmtk videobuf2_vmalloc uvc snd_usbmidi_lib videobuf2_memops videobuf2_v4l2 snd_ump hid_generic bluetooth snd_rawmidi videodev videobuf2_common snd_seq_device mc usbhid xpad cp210x ff_memless nct6775 nct6775_core hwmon_vid intel_rapl_msr intel_rapl_common intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel nls_iso8859_1 vfat fat snd_soc_avs kvm snd_soc_hda_codec snd_hda_ext_core snd_hda_codec_realtek snd_soc_core crct10dif_pclmul snd_hda_codec_generic crc32_pclmul polyval_clmulni snd_compress snd_hda_scodec_component polyval_generic snd_hda_codec_hdmi ac97_bus gf128mul snd_pcm_dmaengine ghash_clmulni_intel snd_hda_intel sha512_ssse3 sha256_ssse3 eeepc_wmi snd_intel_dspcfg sha1_ssse3 snd_intel_sdw_acpi asus_wmi aesni_intel platform_profile snd_hda_codec iTCO_wdt i8042 nvidia_drm(POE) snd_hda_core intel_pmc_bxt crypto_simd snd_hwdep
Aug 17 00:16:42 Daniels-Desktop kernel:  iTCO_vendor_support sparse_keymap ee1004 cryptd wl(POE) mxm_wmi mei_pxp mei_hdcp nvidia_uvm(POE) nvidia_modeset(POE) wmi_bmof serio rapl snd_pcm intel_cstate intel_uncore e1000e pcspkr snd_timer intel_pmc_core i2c_i801 cfg80211 i2c_smbus mei_me snd ptp intel_vsec i2c_mux pps_core video xhci_pci pmt_telemetry rfkill soundcore mei pmt_class wmi xhci_pci_renesas acpi_pad mac_hid nvidia(POE) crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc32c_intel crc16 mbcache jbd2
Aug 17 00:16:42 Daniels-Desktop kernel: ---[ end trace 0000000000000000 ]---
Aug 17 00:16:42 Daniels-Desktop kernel: note: irq/136-nvidia[513] exited with irqs disabled
Aug 17 00:16:42 Daniels-Desktop kernel: BUG: kernel NULL pointer dereference, address: 000000000000032c
Aug 17 00:16:42 Daniels-Desktop kernel: PGD 0 P4D 0
Aug 17 00:16:42 Daniels-Desktop kernel: Oops: Oops: 0000 [#2] PREEMPT SMP PTI
Aug 17 00:16:42 Daniels-Desktop kernel: CPU: 0 PID: 513 Comm: irq/136-nvidia Kdump: loaded Tainted: P      D W  OE      6.10.4-arch2-1 #1 517ed45cc9c4492ee5d5bfc2d2fe6ef1f2e7a8eb
Aug 17 00:16:42 Daniels-Desktop kernel: RIP: 0010:exit_shm+0x4b/0x1d0
Aug 17 00:16:42 Daniels-Desktop kernel: Code: 89 fd 53 48 83 ec 08 4c 89 e7 e8 a0 0b 92 00 48 8b 85 28 08 00 00 4c 39 f8 0f 84 52 01 00 00 4c 8b b5 28 08 00 00 49 8b 5e 10 <8b> 93 2c 03 00 00 85 d2 0f 84 04 01 00 00 48 85 db 0f 84 fb 00 00
Aug 17 00:16:42 Daniels-Desktop kernel: RSP: 0018:ffffa29d82887ea0 EFLAGS: 00010286
Aug 17 00:16:42 Daniels-Desktop kernel: RAX: ffff940c9ee33e28 RBX: 0000000000000000 RCX: 00000000000001c0
Aug 17 00:16:42 Daniels-Desktop kernel: RDX: 0000000000000001 RSI: 0000000000000286 RDI: ffffa29d82887e78
Aug 17 00:16:42 Daniels-Desktop kernel: RBP: ffff940c9ee33600 R08: 0000000000000000 R09: ffffa29d82887d00
Aug 17 00:16:42 Daniels-Desktop kernel: R10: ffffffffac8b2208 R11: 0000000000000003 R12: ffff940c9ee33f1c
Aug 17 00:16:42 Daniels-Desktop kernel: R13: ffff940c80b1a901 R14: ffff940c9ee33e28 R15: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: CR2: 000000000000032c CR3: 00000003ae020003 CR4: 00000000003706f0
Aug 17 00:16:42 Daniels-Desktop kernel:  ? desc_update_last_finalized+0x4c/0x90
Aug 17 00:16:42 Daniels-Desktop kernel:  ? exc_page_fault+0x81/0x190
Aug 17 00:16:42 Daniels-Desktop kernel:  ? exit_shm+0x4b/0x1d0
Aug 17 00:16:42 Daniels-Desktop kernel:  ? task_work_run+0x59/0x90
Aug 17 00:16:42 Daniels-Desktop kernel:  ? do_exit+0x318/0xad0
Aug 17 00:16:42 Daniels-Desktop kernel:  ? make_task_dead+0x90/0x90
Aug 17 00:16:42 Daniels-Desktop kernel:  ? rewind_stack_and_make_dead+0x16/0x20
Aug 17 00:16:42 Daniels-Desktop kernel: Fixing recursive fault but reboot is needed!
Aug 17 00:16:42 Daniels-Desktop kernel: BUG: scheduling while atomic: irq/136-nvidia/513/0x00000000
Aug 17 00:16:42 Daniels-Desktop kernel:  dump_stack_lvl+0x5d/0x80
Aug 17 00:16:42 Daniels-Desktop kernel:  __schedule_bug.cold+0x42/0x4e
Aug 17 00:16:42 Daniels-Desktop kernel:  __schedule+0x109b/0x1520
Aug 17 00:16:42 Daniels-Desktop kernel:  ? __wake_up_klogd.part.0+0x3c/0x60
Aug 17 00:16:42 Daniels-Desktop kernel:  ? vprintk_emit+0x176/0x2a0
Aug 17 00:16:42 Daniels-Desktop kernel:  ? _printk+0x6c/0x87
Aug 17 00:16:42 Daniels-Desktop kernel:  do_task_dead+0x42/0x50
Aug 17 00:16:42 Daniels-Desktop kernel:  make_task_dead.cold+0xd9/0xe5
Aug 17 00:16:42 Daniels-Desktop kernel:  rewind_stack_and_make_dead+0x16/0x20
Aug 17 00:16:42 Daniels-Desktop kernel: RIP: 0000:0x0
Aug 17 00:16:42 Daniels-Desktop kernel: Code: Unable to access opcode bytes at 0xffffffffffffffd6.
Aug 17 00:16:42 Daniels-Desktop kernel: RSP: 0000:0000000000000000 EFLAGS: 00000000 ORIG_RAX: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
Aug 17 00:16:42 Daniels-Desktop kernel: ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 17 00:16:42 Daniels-Desktop kernel: ata5.00: supports DRM functions and may not be fully accessible
Aug 17 00:16:42 Daniels-Desktop kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 17 00:16:42 Daniels-Desktop kernel: ata1.00: supports DRM functions and may not be fully accessible
Aug 17 00:16:42 Daniels-Desktop kernel: ata6: SATA link down (SStatus 4 SControl 300)
Aug 17 00:16:42 Daniels-Desktop kernel: ata3: SATA link down (SStatus 4 SControl 300)
Aug 17 00:16:42 Daniels-Desktop kernel: ata4: SATA link down (SStatus 4 SControl 300)
Aug 17 00:16:42 Daniels-Desktop kernel: ata2: SATA link down (SStatus 4 SControl 300)
Aug 17 00:16:42 Daniels-Desktop kernel: ata5.00: configured for UDMA/133
Aug 17 00:16:42 Daniels-Desktop kernel: ahci 0000:00:17.0: port does not support device sleep
Aug 17 00:16:42 Daniels-Desktop kernel: ata1.00: configured for UDMA/133
Aug 17 00:16:42 Daniels-Desktop kernel: ata1.00: Enabling discard_zeroes_data
Aug 17 00:16:42 Daniels-Desktop kernel: OOM killer enabled.
Aug 17 00:16:42 Daniels-Desktop kernel: Restarting tasks ... done.
Aug 17 00:16:42 Daniels-Desktop kernel: random: crng reseeded on system resumption
Aug 17 00:16:42 Daniels-Desktop kernel: PM: suspend exit
Aug 17 00:16:42 Daniels-Desktop systemd[1]: Started Verify integrity of password and group files.
Aug 17 00:16:42 Daniels-Desktop gdm[462]: GLib: Source ID 88 was not found when attempting to remove it
Aug 17 00:16:42 Daniels-Desktop /usr/lib/gdm-x-session[999]: (II) systemd-logind: got resume for 13:81
Aug 17 00:16:42 Daniels-Desktop systemd-sleep[19310]: System returned from sleep operation 'suspend'.
Aug 17 00:16:42 Daniels-Desktop bluetoothd[551]: Controller resume with wake event 0x0
Aug 17 00:16:42 Daniels-Desktop systemd[1]: systemd-suspend.service: Deactivated successfully.
Aug 17 00:16:42 Daniels-Desktop systemd[1]: Finished System Suspend.
Aug 17 00:16:42 Daniels-Desktop systemd[1]: Stopped target Sleep.
Aug 17 00:16:42 Daniels-Desktop systemd[1]: Reached target Suspend.
Aug 17 00:16:42 Daniels-Desktop systemd[1]: Stopped target Suspend.
Aug 17 00:16:42 Daniels-Desktop systemd[1]: shadow.service: Deactivated successfully.
Aug 17 00:16:42 Daniels-Desktop systemd-logind[407]: Operation 'suspend' finished.
< ------- cut here ------- >
nvidia-bug-report.log.gz (169.4 KB)
I am also seeing the same issue on my new thinkpad P1 Gen7. It has an Intel Core Ultra 7 165H and a RTX 4070 Laptop GPU.
I am using Fedora with KDE PLASMA version 6.1.5 and KDE Framework 6.6.0 and Qt V 6.7.2
I am on Kernel 6.10.10-200.fc40.x86_64 (64-bit) running Wayland.
I have installed the nvidia drivers following Howto/NVIDIA - RPM Fusion including the “Optimus” section.
Similar to Daniel above the issue seems to occur only have sleeping for a long duration. If i just put the laptop to sleep then re-awake immediately this issue will not occur.
Here is the output from my dmesg and journalctl
sudo dmesg | grep nvidia
[    7.216945] nvidia: loading out-of-tree module taints kernel.
[    7.216951] nvidia: module license 'NVIDIA' taints kernel.
[    7.216953] nvidia: module license taints kernel.
[    7.353002] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[    7.354377] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[    7.463334] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    8.536868] nvidia-uvm: Loaded the UVM driver, major device number 507.
[    8.626169] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  555.58.02  Tue Jun 25 01:10:21 UTC 2024
[    8.925111] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    8.930183] nvidia-modeset: WARNING: GPU:0: Correcting number of heads for current head configuration (0x00)
[    8.932450] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 2
[    8.932480] nvidia 0000:01:00.0: [drm] No compatible format found
[    8.932484] nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
sudo journalctl -p 0..3 -xb
Sep 22 07:19:11 my_hostname kernel: intel_vpu 0000:00:0b.0: [drm] *ERROR* ivpu_fw_request(): Failed to request firmware: -2
Sep 22 07:19:11 my_hostname kernel: intel_vpu 0000:00:0b.0: probe with driver intel_vpu failed with error -2
Sep 22 11:19:14 my_hostname kernel: spi-nor spi0.0: unrecognized JEDEC id bytes: f7 f0 30 09 03 00
Sep 22 11:19:14 my_hostname kernel: iwlwifi 0000:09:00.0: WRT: Invalid buffer destination
Sep 22 11:19:15 my_hostname kernel:
Sep 22 11:19:15 my_hostname kernel: iwlwifi 0000:09:00.0: WRT: Invalid buffer destination
Sep 22 11:19:16 my_hostname kernel: iwlwifi 0000:09:00.0: WRT: Invalid buffer destination
Sep 22 11:19:16 my_hostname /usr/bin/nvidia-powerd[1177]: Error in getting the NvPCF static configuration
Sep 22 11:19:16 my_hostname /usr/bin/nvidia-powerd[1177]: Failed to initialize Dynamic Boost
Sep 22 11:19:16 my_hostname /usr/bin/nvidia-powerd[1177]: Failed to detach GPU id 256
Sep 22 11:19:31 my_hostname sddm-helper[1754]: gkr-pam: unable to locate daemon control file
Sep 22 11:19:40 my_hostname sddm-helper[1757]: gkr-pam: unable to locate daemon control file
nvidia-smi
 NVIDIA-SMI 555.58.02              Driver Version: 555.58.02      CUDA Version: 12.5     |
|   0  NVIDIA GeForce RTX 4070 ...    Off |   00000000:01:00.0 Off |                  N/A |
| N/A   39C    P3             13W /   60W |       1MiB /   8188MiB |      5%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
