I supposed this problem may have nothing to do with the ‘write’ statements mentioned before. Because, when I remove those two lines in mpp.F90, recompile and run, the same error still came out. Sadly, the compiler could not give a correct information about which line is faulty. Is that possible that ‘Line 88’ refers to a subroutine? Because, I found that the file name “logfile.0000.out” is used in a called subroutine in mpp.F90.
!-------------- mpp.F90 code ---------------------------------------------
! Communication for message-passing codes
! AUTHOR: V. Balaji (V.Balaji@noaa.gov)
! SGI/GFDL Princeton University
! This program is free software; you can redistribute it and/or modify
! it under the terms of the GNU General Public License as published by
! the Free Software Foundation; either version 2 of the License, or
! (at your option) any later version.
! This program is distributed in the hope that it will be useful,
! but WITHOUT ANY WARRANTY; without even the implied warranty of
! MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
! GNU General Public License for more details.
! For the full text of the GNU General Public License,
! write to: Free Software Foundation, Inc.,
! 675 Mass Ave, Cambridge, MA 02139, USA.
module mpp_mod
!a generalized communication package for use with shmem and MPI
!will add: co_array_fortran, MPI2
!Balaji (V.Balaji@noaa.gov) 11 May 1998
! <CONTACT EMAIL="V.Balaji@noaa.gov">
! V. Balaji
! </CONTACT>
! <HISTORY SRC="http://www.gfdl.noaa.gov/fms-cgi-bin/cvsweb.cgi/FMS/"/>
! <RCSLOG SRC="http://www.gfdl.noaa.gov/~vb/changes_mpp.html"/>
! <OVERVIEW>
! <TT>mpp_mod</TT>, is a set of simple calls to provide a uniform interface
! to different message-passing libraries. It currently can be
! implemented either in the SGI/Cray native SHMEM library or in the MPI
! standard. Other libraries (e.g MPI-2, Co-Array Fortran) can be
! incorporated as the need arises.
! </OVERVIEW>
! <DESCRIPTION>
! The data transfer between a processor and its own memory is based
! on <TT>load</TT> and <TT>store</TT> operations upon
! memory. Shared-memory systems (including distributed shared memory
! systems) have a single address space and any processor can acquire any
! data within the memory by <TT>load</TT> and
! <TT>store</TT>. The situation is different for distributed
! parallel systems. Specialized MPP systems such as the T3E can simulate
! shared-memory by direct data acquisition from remote memory. But if
! the parallel code is distributed across a cluster, or across the Net,
! messages must be sent and received using the protocols for
! long-distance communication, such as TCP/IP. This requires a
! ``handshaking'' between nodes of the distributed system. One can think
! of the two different methods as involving <TT>put</TT>s or
! <TT>get</TT>s (e.g the SHMEM library), or in the case of
! negotiated communication (e.g MPI), <TT>send</TT>s and
! <TT>recv</TT>s.
! The difference between SHMEM and MPI is that SHMEM uses one-sided
! communication, which can have very low-latency high-bandwidth
! implementations on tightly coupled systems. MPI is a standard
! developed for distributed computing across loosely-coupled systems,
! and therefore incurs a software penalty for negotiating the
! communication. It is however an open industry standard whereas SHMEM
! is a proprietary interface. Besides, the <TT>put</TT>s or
! <TT>get</TT>s on which it is based cannot currently be implemented in
! a cluster environment (there are recent announcements from Compaq that
! occasion hope).
! The message-passing requirements of climate and weather codes can be
! reduced to a fairly simple minimal set, which is easily implemented in
! any message-passing API. <TT>mpp_mod</TT> provides this API.
! Features of <TT>mpp_mod</TT> include:
! 1) Simple, minimal API, with free access to underlying API for
! more complicated stuff.<BR/>
! 2) Design toward typical use in climate/weather CFD codes.<BR/>
! 3) Performance to be not significantly lower than any native API.
! This module is used to develop higher-level calls for <LINK
! SRC="mpp_domains.html">domain decomposition</LINK> and <LINK
! SRC="mpp_io.html">parallel I/O</LINK>.
! Parallel computing is initially daunting, but it soon becomes
! second nature, much the way many of us can now write vector code
! without much effort. The key insight required while reading and
! writing parallel code is in arriving at a mental grasp of several
! independent parallel execution streams through the same code (the SPMD
! model). Each variable you examine may have different values for each
! stream, the processor ID being an obvious example. Subroutines and
! function calls are particularly subtle, since it is not always obvious
! from looking at a call what synchronization between execution streams
! it implies. An example of erroneous code would be a global barrier
! call (see <LINK SRC="#mpp_sync">mpp_sync</LINK> below) placed
! within a code block that not all PEs will execute, e.g:
! <PRE>
! if( pe.EQ.0 )call mpp_sync()
! </PRE>
! Here only PE 0 reaches the barrier, where it will wait
! indefinitely. While this is a particularly egregious example to
! illustrate the coding flaw, more subtle versions of the same are
! among the most common errors in parallel code.
! It is therefore important to be conscious of the context of a
! subroutine or function call, and the implied synchronization. There
! are certain calls here (e.g <TT>mpp_declare_pelist, mpp_init,
! mpp_malloc, mpp_set_stack_size</TT>) which must be called by all
! PEs. There are others which must be called by a subset of PEs (here
! called a <TT>pelist</TT>) which must be called by all the PEs in the
! <TT>pelist</TT> (e.g <TT>mpp_max, mpp_sum, mpp_sync</TT>). Still
! others imply no synchronization at all. I will make every effort to
! highlight the context of each call in the MPP modules, so that the
! implicit synchronization is spelt out.
! For performance it is necessary to keep synchronization as limited
! as the algorithm being implemented will allow. For instance, a single
! message between two PEs should only imply synchronization across the
! PEs in question. A <I>global</I> synchronization (or <I>barrier</I>)
! is likely to be slow, and is best avoided. But codes first
! parallelized on a Cray T3E tend to have many global syncs, as very
! fast barriers were implemented there in hardware.
! Another reason to use pelists is to run a single program in MPMD
! mode, where different PE subsets work on different portions of the
! code. A typical example is to assign an ocean model and atmosphere
! model to different PE subsets, and couple them concurrently instead of
! running them serially. The MPP module provides the notion of a
! <I>current pelist</I>, which is set when a group of PEs branch off
! into a subset. Subsequent calls that omit the <TT>pelist</TT> optional
! argument (seen below in many of the individual calls) assume that the
! implied synchronization is across the current pelist. The calls
! <TT>mpp_root_pe</TT> and <TT>mpp_npes</TT> also return the values
! appropriate to the current pelist. The <TT>mpp_set_current_pelist</TT>
! call is provided to set the current pelist.
! </DESCRIPTION>
! <PUBLIC>
! F90 is a strictly-typed language, and the syntax pass of the
! compiler requires matching of type, kind and rank (TKR). Most calls
! listed here use a generic type, shown here as <TT>MPP_TYPE_</TT>. This
! is resolved in the pre-processor stage to any of a variety of
! types. In general the MPP operations work on 4-byte and 8-byte
! variants of <TT>integer, real, complex, logical</TT> variables, of
! rank 0 to 5, leading to 48 specific module procedures under the same
! generic interface. Any of the variables below shown as
! <TT>MPP_TYPE_</TT> is treated in this way.
! </PUBLIC>
#include <fms_platform.h>
#if defined(use_libSMA) && defined(sgi_mipspro)
use shmem_interface
#endif
#if defined(use_libMPI) && defined(sgi_mipspro)
use mpi
#endif
use mpp_parameter_mod, only : MPP_VERBOSE, MPP_DEBUG, ALL_PES, ANY_PE, NULL_PE
use mpp_parameter_mod, only : NOTE, WARNING, FATAL, MPP_CLOCK_DETAILED,MPP_CLO
CK_SYNC
use mpp_parameter_mod, only : CLOCK_COMPONENT, CLOCK_SUBCOMPONENT, CLOCK_MODUL
E_DRIVER
use mpp_parameter_mod, only : CLOCK_MODULE, CLOCK_ROUTINE, CLOCK_LOOP, CLOCK_I
NFRA
use mpp_parameter_mod, only : MAX_EVENTS, MAX_BINS, MAX_EVENT_TYPES, PESET_MAX
, MAX_CLOCKS
use mpp_parameter_mod, only : MAXPES, EVENT_WAIT, EVENT_ALLREDUCE, EVENT_BROAD
CAST
use mpp_parameter_mod, only : EVENT_RECV, EVENT_SEND, MPP_READY, MPP_WAIT
use mpp_parameter_mod, only : mpp_parameter_version=>version, mpp_parameter_ta
gname=>tagname
use mpp_data_mod, only : stat, mpp_stack, ptr_stack, status, ptr_status,
sync, ptr_sync
use mpp_data_mod, only : mpp_from_pe, ptr_from, remote_data_loc, ptr_remo
te
use mpp_data_mod, only : mpp_data_version=>version, mpp_data_tagname=>tag
name
implicit none
private
#if defined(use_libSMA) || defined(use_GSM)
#include <mpp/shmem.fh>
#endif
#if defined(use_libMPI) && !defined(sgi_mipspro)
#include <mpif.h>
!sgi_mipspro gets this from 'use mpi'
#endif
!--- public paramters -----------------------------------------------
public :: MPP_VERBOSE, MPP_DEBUG, ALL_PES, ANY_PE, NULL_PE, NOTE, WARNING, FAT
AL
public :: MPP_CLOCK_SYNC, MPP_CLOCK_DETAILED, CLOCK_COMPONENT, CLOCK_SUBCOMPON
ENT
public :: CLOCK_MODULE_DRIVER, CLOCK_MODULE, CLOCK_ROUTINE, CLOCK_LOOP, CLOCK_
INFRA
public :: MAXPES
!--- public data from mpp_data_mod ------------------------------
public :: request
!--- public interface from mpp_util.h ------------------------------
public :: stdin, stdout, stderr, stdlog, lowercase, uppercase, mpp_error, mpp_
error_state
public :: mpp_set_warn_level, mpp_sync, mpp_sync_self, mpp_set_stack_size, mpp
_pe
public :: mpp_node, mpp_npes, mpp_root_pe, mpp_set_root_pe, mpp_declare_pelist
public :: mpp_get_current_pelist, mpp_set_current_pelist, mpp_clock_begin, mpp
_clock_end
public :: mpp_clock_id, mpp_clock_set_grain, mpp_record_timing_data
!--- public interface from mpp_comm.h ------------------------------
public :: mpp_chksum, mpp_max, mpp_min, mpp_sum, mpp_transmit, mpp_send, mpp_r
ecv
public :: mpp_broadcast, mpp_malloc, mpp_init, mpp_exit
#ifdef use_MPI_GSM
public :: mpp_gsm_malloc, mpp_gsm_free
#endif
! public data type
!peset hold communicators as SHMEM-compatible triads (start, log2(stride), num
type :: communicator
private
character(len=32) :: name
integer, pointer :: list(:) =>NULL()
integer :: count
integer :: start, log2stride ! dummy variables when libMPI is def
ined.
integer :: id, group ! MPI communicator and group id for
this PE set.
! dummy variables when libSMA is def
ined.
end type communicator
type :: event
private
character(len=16) :: name
integer(LONG_KIND), dimension(MAX_EVENTS) :: ticks, bytes
integer :: calls
end type event
!a clock contains an array of event profiles for a region
type :: clock
private
integer(LONG_KIND) :: tick
integer(LONG_KIND) :: total_ticks
integer :: peset_num
logical :: sync_on_begin, detailed
integer :: grain
type(event), pointer :: events(:) =>NULL() !if needed, allocate to MAX_EVEN
T_TYPES
end type clock
type :: Clock_Data_Summary
private
real(DOUBLE_KIND) :: msg_size_sums(MAX_BINS)
real(DOUBLE_KIND) :: msg_time_sums(MAX_BINS)
real(DOUBLE_KIND) :: total_data
real(DOUBLE_KIND) :: total_time
integer(LONG_KIND) :: msg_size_cnts(MAX_BINS)
integer(LONG_KIND) :: total_cnts
end type Clock_Data_Summary
type :: Summary_Struct
private
type (Clock_Data_Summary) :: event(MAX_EVENT_TYPES)
end type Summary_Struct
! public interface from mpp_util.h
! <INTERFACE NAME="mpp_error">
! <OVERVIEW>
! Error handler.
! </OVERVIEW>
! <DESCRIPTION>
! It is strongly recommended that all error exits pass through
! <TT>mpp_error</TT> to assure the program fails cleanly. An individual
! PE encountering a <TT>STOP</TT> statement, for instance, can cause the
! program to hang. The use of the <TT>STOP</TT> statement is strongly
! discouraged.
! Calling mpp_error with no arguments produces an immediate error
! exit, i.e:
! <PRE>
! call mpp_error
! call mpp_error(FATAL)
! </PRE>
! are equivalent.
! The argument order
! <PRE>
! call mpp_error( routine, errormsg, errortype )
! </PRE>
! is also provided to support legacy code. In this version of the
! call, none of the arguments may be omitted.
! The behaviour of <TT>mpp_error</TT> for a <TT>WARNING</TT> can be
! controlled with an additional call <TT>mpp_set_warn_level</TT>.
! <PRE>
! call mpp_set_warn_level(ERROR)
! </PRE>
! causes <TT>mpp_error</TT> to treat <TT>WARNING</TT>
! exactly like <TT>FATAL</TT>.
! <PRE>
! call mpp_set_warn_level(WARNING)
! </PRE>
! resets to the default behaviour described above.
! <TT>mpp_error</TT> also has an internal error state which
! maintains knowledge of whether a warning has been issued. This can be
! used at startup in a subroutine that checks if the model has been
! properly configured. You can generate a series of warnings using
! <TT>mpp_error</TT>, and then check at the end if any warnings has been
! issued using the function <TT>mpp_error_state()</TT>. If the value of
! this is <TT>WARNING</TT>, at least one warning has been issued, and
! the user can take appropriate action:
! <PRE>
! if( ... )call mpp_error( WARNING, '...' )
! if( mpp_error_state().EQ.WARNING )call mpp_error( FATAL, '...' )
! </PRE>
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_error( errortype, routine, errormsg )
! </TEMPLATE>
! <IN NAME="errortype">
! One of <TT>NOTE</TT>, <TT>WARNING</TT> or <TT>FATAL</TT>
! (these definitions are acquired by use association).
! <TT>NOTE</TT> writes <TT>errormsg</TT> to <TT>STDOUT</TT>.
! <TT>WARNING</TT> writes <TT>errormsg</TT> to <TT>STDERR</TT>.
! <TT>FATAL</TT> writes <TT>errormsg</TT> to <TT>STDERR</TT>,
! and induces a clean error exit with a call stack traceback.
! </IN>
! </INTERFACE>
interface mpp_error
module procedure mpp_error_basic
module procedure mpp_error_mesg
module procedure mpp_error_noargs
end interface
! public interface from mpp_comm.h
#ifdef use_libSMA
!currently SMA contains no generic shmem_wait for different integer kinds:
!I have inserted one here
interface shmem_integer_wait
module procedure shmem_int4_wait_local
module procedure shmem_int8_wait_local
end interface
#endif
! ROUTINES TO INITIALIZE/FINALIZE MPP MODULE: mpp_init, mpp_exit
! <SUBROUTINE NAME="mpp_init">
! <OVERVIEW>
! Initialize <TT>mpp_mod</TT>.
! </OVERVIEW>
! <DESCRIPTION>
! Called to initialize the <TT>mpp_mod</TT> package. It is recommended
! that this call be the first executed line in your program. It sets the
! number of PEs assigned to this run (acquired from the command line, or
! through the environment variable <TT>NPES</TT>), and associates an ID
! number to each PE. These can be accessed by calling <LINK
! SRC="#mpp_npes"><TT>mpp_npes</TT></LINK> and <LINK
! SRC="#mpp_pe"><TT>mpp_pe</TT></LINK>.
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_init( flags )
! </TEMPLATE>
! <IN NAME="flags" TYPE="integer">
! <TT>flags</TT> can be set to <TT>MPP_VERBOSE</TT> to
! have <TT>mpp_mod</TT> keep you informed of what it's up to.
! </IN>
! </SUBROUTINE>
! <SUBROUTINE NAME="mpp_exit">
! <OVERVIEW>
! Exit <TT>mpp_mod</TT>.
! </OVERVIEW>
! <DESCRIPTION>
! Called at the end of the run, or to re-initialize <TT>mpp_mod</TT>,
! should you require that for some odd reason.
! This call implies synchronization across all PEs.
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_exit()
! </TEMPLATE>
! </SUBROUTINE>
! <SUBROUTINE NAME="mpp_malloc">
! <OVERVIEW>
! Symmetric memory allocation.
! </OVERVIEW>
! <DESCRIPTION>
! This routine is used on SGI systems when <TT>mpp_mod</TT> is
! invoked in the SHMEM library. It ensures that dynamically allocated
! memory can be used with <TT>shmem_get</TT> and
! <TT>shmem_put</TT>. This is called <I>symmetric
! allocation</I> and is described in the
! <TT>intro_shmem</TT> man page. <TT>ptr</TT> is a <I>Cray
! pointer</I> (see the section on <LINK
! SRC="#PORTABILITY">portability</LINK>). The operation can be expensive
! (since it requires a global barrier). We therefore attempt to re-use
! existing allocation whenever possible. Therefore <TT>len</TT>
! and <TT>ptr</TT> must have the <TT>SAVE</TT> attribute
! in the calling routine, and retain the information about the last call
! to <TT>mpp_malloc</TT>. Additional memory is symmetrically
! allocated if and only if <TT>newlen</TT> exceeds
! <TT>len</TT>.
! This is never required on Cray PVP or MPP systems. While the T3E
! manpages do talk about symmetric allocation, <TT>mpp_mod</TT>
! is coded to remove this restriction.
! It is never required if <TT>mpp_mod</TT> is invoked in MPI.
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_malloc( ptr, newlen, len )
! </TEMPLATE>
! <IN NAME="ptr">
! a cray pointer, points to a dummy argument in this routine.
! </IN>
! <IN NAME="newlen" TYPE="integer">
! the required allocation length for the pointer ptr
! </IN>
! <IN NAME="len" TYPE="integer">
! the current allocation (0 if unallocated).
! </IN>
! </SUBROUTINE>
! <SUBROUTINE NAME="mpp_set_stack_size">
! <OVERVIEW>
! Allocate module internal workspace.
! </OVERVIEW>
! <DESCRIPTION>
! <TT>mpp_mod</TT> maintains a private internal array called
! <TT>mpp_stack</TT> for private workspace. This call sets the length,
! in words, of this array.
! The <TT>mpp_init</TT> call sets this
! workspace length to a default of 32768, and this call may be used if a
! longer workspace is needed.
! This workspace is symmetrically allocated, as required for
! efficient communication on SGI and Cray MPP systems. Since symmetric
! allocation must be performed by <I>all</I> PEs in a job, this call
! must also be called by all PEs, using the same value of
! <TT>n</TT>. Calling <TT>mpp_set_stack_size</TT> from a subset of PEs,
! or with unequal argument <TT>n</TT>, may cause the program to hang.
! If any MPP call using <TT>mpp_stack</TT> overflows the declared
! stack array, the program will abort with a message specifying the
! stack length that is required. Many users wonder why, if the required
! stack length can be computed, it cannot also be specified at that
! point. This cannot be automated because there is no way for the
! program to know if all PEs are present at that call, and with equal
! values of <TT>n</TT>. The program must be rerun by the user with the
! correct argument to <TT>mpp_set_stack_size</TT>, called at an
! appropriate point in the code where all PEs are known to be present.
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_set_stack_size(n)
! </TEMPLATE>
! <IN NAME="n" TYPE="integer"></IN>
! </SUBROUTINE>
! GLOBAL REDUCTION ROUTINES: mpp_max, mpp_sum, mpp_min
! <INTERFACE NAME="mpp_max">
! <OVERVIEW>
! Reduction operations.
! </OVERVIEW>
! <DESCRIPTION>
! Find the max of scalar a the PEs in pelist
! result is also automatically broadcast to all PEs
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_max( a, pelist )
! </TEMPLATE>
! <IN NAME="a">
! <TT>real</TT> or <TT>integer</TT>, of 4-byte of 8-byte kind.
! </IN>
! <IN NAME="pelist">
! If <TT>pelist</TT> is omitted, the context is assumed to be the
! current pelist. This call implies synchronization across the PEs in
! <TT>pelist</TT>, or the current pelist if <TT>pelist</TT> is absent.
! </IN>
! </INTERFACE>
interface mpp_max
module procedure mpp_max_real8
#ifndef no_8byte_integers
module procedure mpp_max_int8
#endif
#ifndef no_4byte_reals
module procedure mpp_max_real4
#endif
module procedure mpp_max_int4
end interface
interface mpp_min
module procedure mpp_min_real8
module procedure mpp_min_int8
#endif
module procedure mpp_min_real4
#endif
module procedure mpp_min_int4
end interface
! <INTERFACE NAME="mpp_sum">
! <OVERVIEW>
! Reduction operation.
! </OVERVIEW>
! <DESCRIPTION>
! <TT>MPP_TYPE_</TT> corresponds to any 4-byte and 8-byte variant of
! <TT>integer, real, complex</TT> variables, of rank 0 or 1. A
! contiguous block from a multi-dimensional array may be passed by its
! starting address and its length, as in <TT>f77</TT>.
! Library reduction operators are not required or guaranteed to be
! bit-reproducible. In any case, changing the processor count changes
! the data layout, and thus very likely the order of operations. For
! bit-reproducible sums of distributed arrays, consider using the
! <TT>mpp_global_sum</TT> routine provided by the <LINK
! SRC="mpp_domains.html"><TT>mpp_domains</TT></LINK> module.
! The <TT>bit_reproducible</TT> flag provided in earlier versions of
! this routine has been removed.
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_sum( a, length, pelist )
! </TEMPLATE>
! <IN NAME="length"></IN>
! <IN NAME="pelist"></IN>
! <INOUT NAME="a"></INOUT>
! </INTERFACE>
interface mpp_sum
module procedure mpp_sum_int8
module procedure mpp_sum_int8_scalar
module procedure mpp_sum_int8_2d
module procedure mpp_sum_int8_3d
module procedure mpp_sum_int8_4d
module procedure mpp_sum_int8_5d
#endif
module procedure mpp_sum_real8
module procedure mpp_sum_real8_scalar
module procedure mpp_sum_real8_2d
module procedure mpp_sum_real8_3d
module procedure mpp_sum_real8_4d
module procedure mpp_sum_real8_5d
module procedure mpp_sum_cmplx8
module procedure mpp_sum_cmplx8_scalar
module procedure mpp_sum_cmplx8_2d
module procedure mpp_sum_cmplx8_3d
module procedure mpp_sum_cmplx8_4d
module procedure mpp_sum_cmplx8_5d
module procedure mpp_sum_int4
module procedure mpp_sum_int4_scalar
module procedure mpp_sum_int4_2d
module procedure mpp_sum_int4_3d
module procedure mpp_sum_int4_4d
module procedure mpp_sum_int4_5d
module procedure mpp_sum_real4
module procedure mpp_sum_real4_scalar
module procedure mpp_sum_real4_2d
module procedure mpp_sum_real4_3d
module procedure mpp_sum_real4_4d
module procedure mpp_sum_real4_5d
module procedure mpp_sum_cmplx4
module procedure mpp_sum_cmplx4_scalar
module procedure mpp_sum_cmplx4_2d
module procedure mpp_sum_cmplx4_3d
module procedure mpp_sum_cmplx4_4d
module procedure mpp_sum_cmplx4_5d
#endif
end interface
! <INTERFACE NAME="mpp_transmit">
! <OVERVIEW>
! Basic message-passing call.
! </OVERVIEW>
! <DESCRIPTION>
! <TT>integer, real, complex, logical</TT> variables, of rank 0 or 1. A
! <TT>mpp_transmit</TT> is currently implemented as asynchronous
! outward transmission and synchronous inward transmission. This follows
! the behaviour of <TT>shmem_put</TT> and <TT>shmem_get</TT>. In MPI, it
! is implemented as <TT>mpi_isend</TT> and <TT>mpi_recv</TT>. For most
! applications, transmissions occur in pairs, and are here accomplished
! in a single call.
! The special PE designations <TT>NULL_PE</TT>,
! <TT>ANY_PE</TT> and <TT>ALL_PES</TT> are provided by use
! association.
! <TT>NULL_PE</TT>: is used to disable one of the pair of
! transmissions.<BR/>
! <TT>ANY_PE</TT>: is used for unspecific remote
! destination. (Please note that <TT>put_pe=ANY_PE</TT> has no meaning
! in the MPI context, though it is available in the SHMEM invocation. If
! portability is a concern, it is best avoided).<BR/>
! <TT>ALL_PES</TT>: is used for broadcast operations.
! It is recommended that <LINK
! SRC="#mpp_broadcast"><TT>mpp_broadcast</TT></LINK> be used for
! broadcasts.
! The following example illustrates the use of
! <TT>NULL_PE</TT> and <TT>ALL_PES</TT>:
! <PRE>
! real, dimension(n) :: a
! if( pe.EQ.0 )then
! do p = 1,npes-1
! call mpp_transmit( a, n, p, a, n, NULL_PE )
! end do
! else
! call mpp_transmit( a, n, NULL_PE, a, n, 0 )
! end if
! call mpp_transmit( a, n, ALL_PES, a, n, 0 )
! </PRE>
! The do loop and the broadcast operation above are equivalent.
! Two overloaded calls <TT>mpp_send</TT> and
! <TT>mpp_recv</TT> have also been
! provided. <TT>mpp_send</TT> calls <TT>mpp_transmit</TT>
! with <TT>get_pe=NULL_PE</TT>. <TT>mpp_recv</TT> calls
! <TT>mpp_transmit</TT> with <TT>put_pe=NULL_PE</TT>. Thus
! the do loop above could be written more succinctly:
! <PRE>
! if( pe.EQ.0 )then
! do p = 1,npes-1
! call mpp_send( a, n, p )
! end do
! else
! call mpp_recv( a, n, 0 )
! end if
! </PRE>
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_transmit( put_data, put_len, put_pe, get_data, get_len, get_pe )
! </TEMPLATE>
! </INTERFACE>
interface mpp_transmit
module procedure mpp_transmit_real8
module procedure mpp_transmit_real8_scalar
module procedure mpp_transmit_real8_2d
module procedure mpp_transmit_real8_3d
module procedure mpp_transmit_real8_4d
module procedure mpp_transmit_real8_5d
module procedure mpp_transmit_cmplx8
module procedure mpp_transmit_cmplx8_scalar
module procedure mpp_transmit_cmplx8_2d
module procedure mpp_transmit_cmplx8_3d
module procedure mpp_transmit_cmplx8_4d
module procedure mpp_transmit_cmplx8_5d
module procedure mpp_transmit_int8
module procedure mpp_transmit_int8_scalar
module procedure mpp_transmit_int8_2d
module procedure mpp_transmit_int8_3d
module procedure mpp_transmit_int8_4d
module procedure mpp_transmit_int8_5d
module procedure mpp_transmit_logical8
module procedure mpp_transmit_logical8_scalar
module procedure mpp_transmit_logical8_2d
module procedure mpp_transmit_logical8_3d
module procedure mpp_transmit_logical8_4d
module procedure mpp_transmit_logical8_5d
#endif
module procedure mpp_transmit_real4
module procedure mpp_transmit_real4_scalar
module procedure mpp_transmit_real4_2d
module procedure mpp_transmit_real4_3d
module procedure mpp_transmit_real4_4d
module procedure mpp_transmit_real4_5d
module procedure mpp_transmit_cmplx4
module procedure mpp_transmit_cmplx4_scalar
module procedure mpp_transmit_cmplx4_2d
module procedure mpp_transmit_cmplx4_3d
module procedure mpp_transmit_cmplx4_4d
module procedure mpp_transmit_cmplx4_5d
#endif
module procedure mpp_transmit_int4
module procedure mpp_transmit_int4_scalar
module procedure mpp_transmit_int4_2d
module procedure mpp_transmit_int4_3d
module procedure mpp_transmit_int4_4d
module procedure mpp_transmit_int4_5d
module procedure mpp_transmit_logical4
module procedure mpp_transmit_logical4_scalar
module procedure mpp_transmit_logical4_2d
module procedure mpp_transmit_logical4_3d
module procedure mpp_transmit_logical4_4d
module procedure mpp_transmit_logical4_5d
end interface
interface mpp_recv
module procedure mpp_recv_real8
module procedure mpp_recv_real8_scalar
module procedure mpp_recv_real8_2d
module procedure mpp_recv_real8_3d
module procedure mpp_recv_real8_4d
module procedure mpp_recv_real8_5d
module procedure mpp_recv_cmplx8
module procedure mpp_recv_cmplx8_scalar
module procedure mpp_recv_cmplx8_2d
module procedure mpp_recv_cmplx8_3d
module procedure mpp_recv_cmplx8_4d
module procedure mpp_recv_cmplx8_5d
module procedure mpp_recv_int8
module procedure mpp_recv_int8_scalar
module procedure mpp_recv_int8_2d
module procedure mpp_recv_int8_3d
module procedure mpp_recv_int8_4d
module procedure mpp_recv_int8_5d
module procedure mpp_recv_logical8
module procedure mpp_recv_logical8_scalar
module procedure mpp_recv_logical8_2d
module procedure mpp_recv_logical8_3d
module procedure mpp_recv_logical8_4d
module procedure mpp_recv_logical8_5d
#endif
module procedure mpp_recv_real4
module procedure mpp_recv_real4_scalar
module procedure mpp_recv_real4_2d
module procedure mpp_recv_real4_3d
module procedure mpp_recv_real4_4d
module procedure mpp_recv_real4_5d
module procedure mpp_recv_cmplx4
module procedure mpp_recv_cmplx4_scalar
module procedure mpp_recv_cmplx4_2d
module procedure mpp_recv_cmplx4_3d
module procedure mpp_recv_cmplx4_4d
module procedure mpp_recv_cmplx4_5d
#endif
module procedure mpp_recv_int4
module procedure mpp_recv_int4_scalar
module procedure mpp_recv_int4_2d
module procedure mpp_recv_int4_3d
module procedure mpp_recv_int4_4d
module procedure mpp_recv_int4_5d
module procedure mpp_recv_logical4
module procedure mpp_recv_logical4_scalar
module procedure mpp_recv_logical4_2d
module procedure mpp_recv_logical4_3d
module procedure mpp_recv_logical4_4d
module procedure mpp_recv_logical4_5d
end interface
interface mpp_send
module procedure mpp_send_real8
module procedure mpp_send_real8_scalar
module procedure mpp_send_real8_2d
module procedure mpp_send_real8_3d
module procedure mpp_send_real8_4d
module procedure mpp_send_real8_5d
module procedure mpp_send_cmplx8
module procedure mpp_send_cmplx8_scalar
module procedure mpp_send_cmplx8_2d
module procedure mpp_send_cmplx8_3d
module procedure mpp_send_cmplx8_4d
module procedure mpp_send_cmplx8_5d
module procedure mpp_send_int8
module procedure mpp_send_int8_scalar
module procedure mpp_send_int8_2d
module procedure mpp_send_int8_3d
module procedure mpp_send_int8_4d
module procedure mpp_send_int8_5d
module procedure mpp_send_logical8
module procedure mpp_send_logical8_scalar
module procedure mpp_send_logical8_2d
module procedure mpp_send_logical8_3d
module procedure mpp_send_logical8_4d
module procedure mpp_send_logical8_5d
#endif
module procedure mpp_send_real4
module procedure mpp_send_real4_scalar
module procedure mpp_send_real4_2d
module procedure mpp_send_real4_3d
module procedure mpp_send_real4_4d
module procedure mpp_send_real4_5d
module procedure mpp_send_cmplx4
module procedure mpp_send_cmplx4_scalar
module procedure mpp_send_cmplx4_2d
module procedure mpp_send_cmplx4_3d
module procedure mpp_send_cmplx4_4d
module procedure mpp_send_cmplx4_5d
#endif
module procedure mpp_send_int4
module procedure mpp_send_int4_scalar
module procedure mpp_send_int4_2d
module procedure mpp_send_int4_3d
module procedure mpp_send_int4_4d
module procedure mpp_send_int4_5d
module procedure mpp_send_logical4
module procedure mpp_send_logical4_scalar
module procedure mpp_send_logical4_2d
module procedure mpp_send_logical4_3d
module procedure mpp_send_logical4_4d
module procedure mpp_send_logical4_5d
end interface
! <INTERFACE NAME="mpp_broadcast">
! <OVERVIEW>
! Parallel broadcasts.
! </OVERVIEW>
! <DESCRIPTION>
! The <TT>mpp_broadcast</TT> call has been added because the original
! syntax (using <TT>ALL_PES</TT> in <TT>mpp_transmit</TT>) did not
! support a broadcast across a pelist.
! Global broadcasts through the <TT>ALL_PES</TT> argument to <LINK
! SRC="#mpp_transmit"><TT>mpp_transmit</TT></LINK> are still provided for
! backward-compatibility.
! current pelist. <TT>from_pe</TT> must belong to the current
! pelist. This call implies synchronization across the PEs in
! </DESCRIPTION>
! <TEMPLATE>
! call mpp_broadcast( data, length, from_pe, pelist )
! </TEMPLATE>
! <IN NAME="length"> </IN>
! <IN NAME="from_pe"> </IN>
! <IN NAME="pelist"> </IN>
! <INOUT NAME="data(*)"> </INOUT>
! </INTERFACE>
interface mpp_broadcast
module procedure mpp_broadcast_real8
module procedure mpp_broadcast_real8_scalar
module procedure mpp_broadcast_real8_2d
module procedure mpp_broadcast_real8_3d
module procedure mpp_broadcast_real8_4d
module procedure mpp_broadcast_real8_5d
module procedure mpp_broadcast_cmplx8
module procedure mpp_broadcast_cmplx8_scalar
module procedure mpp_broadcast_cmplx8_2d
module procedure mpp_broadcast_cmplx8_3d
module procedure mpp_broadcast_cmplx8_4d
module procedure mpp_broadcast_cmplx8_5d
module procedure mpp_broadcast_int8
module procedure mpp_broadcast_int8_scalar
module procedure mpp_broadcast_int8_2d
module procedure mpp_broadcast_int8_3d
module procedure mpp_broadcast_int8_4d
module procedure mpp_broadcast_int8_5d
module procedure mpp_broadcast_logical8
module procedure mpp_broadcast_logical8_scalar
module procedure mpp_broadcast_logical8_2d
module procedure mpp_broadcast_logical8_3d
module procedure mpp_broadcast_logical8_4d
module procedure mpp_broadcast_logical8_5d
#endif
module procedure mpp_broadcast_real4
module procedure mpp_broadcast_real4_scalar
module procedure mpp_broadcast_real4_2d
module procedure mpp_broadcast_real4_3d
module procedure mpp_broadcast_real4_4d
module procedure mpp_broadcast_real4_5d
module procedure mpp_broadcast_cmplx4
module procedure mpp_broadcast_cmplx4_scalar
module procedure mpp_broadcast_cmplx4_2d
module procedure mpp_broadcast_cmplx4_3d
module procedure mpp_broadcast_cmplx4_4d
module procedure mpp_broadcast_cmplx4_5d
#endif
module procedure mpp_broadcast_int4
module procedure mpp_broadcast_int4_scalar
module procedure mpp_broadcast_int4_2d
module procedure mpp_broadcast_int4_3d
module procedure mpp_broadcast_int4_4d
module procedure mpp_broadcast_int4_5d
module procedure mpp_broadcast_logical4
module procedure mpp_broadcast_logical4_scalar
module procedure mpp_broadcast_logical4_2d
module procedure mpp_broadcast_logical4_3d
module procedure mpp_broadcast_logical4_4d
module procedure mpp_broadcast_logical4_5d
end interface
! <INTERFACE NAME="mpp_chksum">
! <OVERVIEW>
! Parallel checksums.
! </OVERVIEW>
! <DESCRIPTION>
! <TT>mpp_chksum</TT> is a parallel checksum routine that returns an
! identical answer for the same array irrespective of how it has been
! partitioned across processors. <TT>LONG_KIND</TT>is the <TT>KIND</TT>
! parameter corresponding to long integers (see discussion on
! OS-dependent preprocessor directives) defined in
! the header file <TT>fms_platform.h</TT>. <TT>MPP_TYPE_</TT> corresponds
to any
! 4-byte and 8-byte variant of <TT>integer, real, complex, logical</TT>
! variables, of rank 0 to 5.
! Integer checksums on FP data use the F90 <TT>TRANSFER()</TT>
! intrinsic.
! The <LINK SRC="http://www.gfdl.noaa.gov/fms-cgi-bin/cvsweb.cgi/FMS/share
d/chksum/chksum.html">serial checksum module</LINK> is superseded
! by this function, and is no longer being actively maintained. This
! provides identical results on a single-processor job, and to perform
! serial checksums on a single processor of a parallel job, you only
! need to use the optional <TT>pelist</TT> argument.
! <PRE>
! use mpp_mod
! integer :: pe, chksum
! real :: a(:)
! pe = mpp_pe()
! chksum = mpp_chksum( a, (/pe/) )
! </PRE>
! The additional functionality of <TT>mpp_chksum</TT> over
! serial checksums is to compute the checksum across the PEs in
! <TT>pelist</TT>. The answer is guaranteed to be the same for
! the same distributed array irrespective of how it has been
! partitioned.
! </DESCRIPTION>
! <TEMPLATE>
! mpp_chksum( var, pelist )
! </TEMPLATE>
! <IN NAME="pelist" TYPE="integer" DIM="(:)"> </IN>
! <IN NAME="var" TYPE="MPP_TYPE_"> </IN>
! </INTERFACE>
interface mpp_chksum
module procedure mpp_chksum_i8_1d
module procedure mpp_chksum_i8_2d
module procedure mpp_chksum_i8_3d
module procedure mpp_chksum_i8_4d
#endif
module procedure mpp_chksum_i4_1d
module procedure mpp_chksum_i4_2d
module procedure mpp_chksum_i4_3d
module procedure mpp_chksum_i4_4d
module procedure mpp_chksum_r8_0d
module procedure mpp_chksum_r8_1d
module procedure mpp_chksum_r8_2d
module procedure mpp_chksum_r8_3d
module procedure mpp_chksum_r8_4d
module procedure mpp_chksum_r8_5d
module procedure mpp_chksum_c8_0d
module procedure mpp_chksum_c8_1d
module procedure mpp_chksum_c8_2d
module procedure mpp_chksum_c8_3d
module procedure mpp_chksum_c8_4d
module procedure mpp_chksum_c8_5d
module procedure mpp_chksum_r4_0d
module procedure mpp_chksum_r4_1d
module procedure mpp_chksum_r4_2d
module procedure mpp_chksum_r4_3d
module procedure mpp_chksum_r4_4d
module procedure mpp_chksum_r4_5d
module procedure mpp_chksum_c4_0d
module procedure mpp_chksum_c4_1d
module procedure mpp_chksum_c4_2d
module procedure mpp_chksum_c4_3d
module procedure mpp_chksum_c4_4d
module procedure mpp_chksum_c4_5d
#endif
end interface
! module variables
type(communicator),save :: peset(0:PESET_MAX) !0 is a dummy used to hold singl
e-PE "self" communicator
logical :: module_is_initialized = .false.
logical :: debug = .false.
integer :: npes=1, root_pe=0, pe=0
integer(LONG_KIND) :: tick, ticks_per_sec, max_ticks, start_tick, end_tick,
tick0=0
integer :: mpp_comm_private
logical :: first_call_system_clock_mpi=.TRUE.
real(DOUBLE_KIND) :: mpi_count0=0 ! use to prevent integer overflow
real(DOUBLE_KIND) :: mpi_tick_rate=0.d0 ! clock rate for mpi_wtick()
logical :: mpp_record_timing_data=.TRUE.
type(clock),save :: clocks(MAX_CLOCKS)
integer :: log_unit, etc_unit
character(len=32) :: configfile='logfile'
integer :: peset_num=0, current_peset_num=0
integer :: world_peset_num !the world communicat
or
integer :: error
integer :: clock_num=0, num_clock_ids=0,current_clock=0, previous
_clock(MAX_CLOCKS)=0
real :: tick_rate
integer, allocatable :: request(:)
character(len=32) :: etcfile='._mpp.nonrootpe.stdout'
#ifdef SGICRAY
integer :: in_unit=100, out_unit=101, err_unit=102 !see intro_io(3F): to see w
hy these values are used rather than 5,6,0
#else
integer :: in_unit=5, out_unit=6, err_unit=0
#endif
!--- variables used in mpp_util.h
type(Summary_Struct) :: clock_summary(MAX_CLOCKS)
logical :: warnings_are_fatal = .FALSE.
integer :: error_state=0
integer :: clock_grain=CLOCK_LOOP-1
!--- variables used in mpp_comm.h
#ifdef use_libMPI
#ifdef _CRAYT3E
!BWA: mpif.h on t3e currently does not contain MPI_INTEGER8 datatype
!(O2k and t90 do)
!(t3e: fixed on 3.3 I believe)
integer, parameter :: MPI_INTEGER8=MPI_INTEGER
#endif
#endif use_libMPI
integer :: clock0 !measures total runtime from mpp_init to mpp_e
xit
integer :: mpp_stack_size=0, mpp_stack_hwm=0
integer :: tag=1
logical :: verbose=.FALSE.
#ifdef _CRAY
integer(LONG_KIND) :: word(1)
#endif
#if defined(sgi_mipspro) || defined(__ia64)
integer(INT_KIND) :: word(1)
#endif
character(len=128), public :: version= &
'$Id mpp.F90 $'
character(len=128), public :: tagname= &
'$Name: latest $'
contains
#include <system_clock.h>
#include <mpp_util.inc>
#include <mpp_comm.inc>
end module mpp_mod
#ifdef test_mpp
#ifdef SYSTEM_CLOCK
#undef SYSTEM_CLOCK
#endif
program test !test various aspects of mpp_mod
#ifdef sgi_mipspro
use shmem_interface
#endif
use mpp_mod, only : mpp_init, mpp_exit, mpp_pe, mpp_npes, mpp_root_pe, stdout
use mpp_mod, only : mpp_clock_id, mpp_clock_begin, mpp_clock_end, mpp_sync, mp
p_malloc
use mpp_mod, only : mpp_declare_pelist, mpp_set_current_pelist, mpp_set_stack_
size
use mpp_mod, only : mpp_broadcast, mpp_transmit, mpp_sum, mpp_max, mpp_chksum,
ALL_PES
#ifdef use_MPI_GSM
use mpp_mod, only : mpp_gsm_malloc, mpp_gsm_free
#endif
implicit none
integer, parameter :: n=1048576
real, allocatable, dimension(:) :: a, b, c
#ifdef use_MPI_GSM
real :: d(n)
pointer (locd, d)
#else
real, allocatable, dimension(:) :: d
integer(LONG_KIND) :: locd
#endif
integer :: tick, tick0, ticks_per_sec, id
integer :: pe, npes, root, i, j, k, l, m, n2, istat
real :: dt
call mpp_init()
call mpp_set_stack_size(3145746)
pe = mpp_pe()
npes = mpp_npes()
root = mpp_root_pe()
call SYSTEM_CLOCK( count_rate=ticks_per_sec )
allocate( a(n), b(n) )
id = mpp_clock_id( 'Random number' )
call mpp_clock_begin(id)
call random_number(a)
call mpp_clock_end (id)
! time transmit, compare against shmem_put and get !
if( pe.EQ.root )then
print *, 'Time mpp_transmit for various lengths...'
#ifdef SGICRAY
print *, 'For comparison, times for shmem_get and shmem_put are also provid
ed.'
#endif
print *
end if
id = mpp_clock_id( 'mpp_transmit' )
!timing is done for cyclical pass (more useful than ping-pong etc)
l = n
do while( l.GT.0 )
!--- mpp_transmit -------------------------------------------------
call mpp_sync()
call SYSTEM_CLOCK(tick0)
do i = 1,npes
call mpp_transmit( put_data=a(1), plen=l, to_pe=modulo(pe+npes-i,npes),
get_data=b(1), glen=l, from_pe=modulo(pe+i,npes) )
! call mpp_sync_self( (/modulo(pe+npes-i,npes)/) )
end do
call mpp_sync()
call SYSTEM_CLOCK(tick)
dt = real(tick-tick0)/(npes*ticks_per_sec)
dt = max( dt, epsilon(dt) )
if( pe.EQ.root )write( stdout(),'(/a,i8,f13.6,f8.2)' )'MPP_TRANSMIT length,
time, bw(Mb/s)=', l, dt, l*8e-6/dt
!#ifdef SGICRAY
! !--- shmem_put ----------------------------------------------------
! call mpp_sync()
! call SYSTEM_CLOCK(tick0)
! do i = 1,npes
! call shmem_real_put( b, a, l, modulo(pe+1,npes) )
! end do
! call mpp_sync()
! call SYSTEM_CLOCK(tick)
! dt = real(tick-tick0)/(npes*ticks_per_sec)
! dt = max( dt, epsilon(dt) )
! if( pe.EQ.root )write( stdout(),'( a,i8,f13.6,f8.2)' )'SHMEM_PUT length
, time, bw(Mb/s)=', l, dt, l*8e-6/dt
! !--- shmem_get ----------------------------------------------------
! call mpp_sync()
! do i = 1,npes
! call shmem_real_get( b, a, l, modulo(pe+1,npes) )
! end do
! if( pe.EQ.root )write( stdout(),'( a,i8,f13.6,f8.2)' )'SHMEM_GET length
!#endif
l = l/2
end do
! test mpp_sum !
print '(/a)', 'Time mpp_sum...'
end if
a = real(pe+1)
call mpp_sync()
call mpp_sum(a(1:1000),1000)
dt = real(tick-tick0)/ticks_per_sec
if( pe.EQ.root )write( stdout(),'(a,2i4,f9.1,i8,f13.6,f8.2/)' ) &
'mpp_sum: pe, npes, sum(pe+1), length, time, bw(Mb/s)=', pe, npes, a(1),
n, dt, n*8e-6/dt
call mpp_clock_end(id)
! test mpp_max !
print *
print *, 'Test mpp_max...'
end if
a = real(pe+1)
print *, 'pe, pe+1 =', pe, a(1)
call mpp_max( a(1) )
print *, 'pe, max(pe+1)=', pe, a(1)
!pelist check
call mpp_sync()
call flush(stdout(),istat)
if( npes.GE.2 )then
if( pe.EQ.root )print *, 'Test of pelists: bcast, sum and max using PEs 0..
.npes-2 (excluding last PE)'
call mpp_declare_pelist( (/(i,i=0,npes-2)/) )
a = real(pe+1)
if( pe.NE.npes-1 )call mpp_broadcast( a, n, npes-2, (/(i,i=0,npes-2)/) )
print *, 'bcast(npes-1) from 0 to npes-2=', pe, a(1)
a = real(pe+1)
if( pe.NE.npes-1 )then
call mpp_set_current_pelist( (/(i,i=0,npes-2)/) )
id = mpp_clock_id( 'Partial mpp_sum' )
call mpp_sum( a(1:1000), 1000, (/(i,i=0,npes-2)/) )
end if
if( pe.EQ.root )print *, 'sum(pe+1) from 0 to npes-2=', a(1)
a = real(pe+1)
if( pe.NE.npes-1 )call mpp_max( a(1), (/(i,i=0,npes-2)/) )
if( pe.EQ.root )print *, 'max(pe+1) from 0 to npes-2=', a(1)
end if
call mpp_set_current_pelist()
#ifdef use_CRI_pointers
! test mpp_chksum !
if( modulo(n,npes).EQ.0 )then !only set up for even division
n2 = 1024
a = 0.d0
if( pe.EQ.root )call random_number(a(1:n2))
! if( pe.EQ.root )call random_number(a)
call mpp_sync()
call mpp_transmit( put_data=a(1), plen=n2, to_pe=ALL_PES, &
get_data=a(1), glen=n2, from_pe=root )
! call mpp_transmit( put_data=a(1), plen=n, to_pe=ALL_PES, &
! get_data=a(1), glen=n, from_pe=root )
m= n2/npes
! m= n/npes
allocate( c(m) )
c = a(pe*m+1:pe*m+m)
print *
print *, 'Test mpp_chksum...'
print *, 'This test shows that a whole array and a distributed array giv
e identical checksums.'
end if
print *, 'chksum(a(1:1024))=', mpp_chksum(a(1:n2),(/pe/))
print *, 'chksum(c(1:1024))=', mpp_chksum(c)
! print *, 'chksum(a)=', mpp_chksum(a,(/pe/))
! print *, 'chksum(c)=', mpp_chksum(c)
end if
!test of pointer sharing
#ifdef use_MPI_GSM
call mpp_gsm_malloc( locd, sizeof(d) )
#else
allocate( d(n) )
locd = LOC(d)
end if
call mpp_broadcast(locd,root)
#endif
call random_number(d)
end if
call mpp_sync()
call test_shared_pointers(locd,n)
#ifdef use_MPI_GSM
call mpp_gsm_free( locd )
#else
deallocate( d )
end if
#endif
#endif
call mpp_exit()
contains
subroutine test_shared_pointers(locd,n)
integer(LONG_KIND), intent(in) :: locd
integer :: n
real :: dd(n)
pointer( p, dd )
p = locd
print *, 'TEST_SHARED_POINTERS: pe, locd=', pe, locd
print *, 'TEST_SHARED_POINTERS: pe, chksum(d)=', pe, mpp_chksum(dd,(/pe/))
return
end subroutine test_shared_pointers
end program test
#endif test_mpp
