I am trying to use template with pgf90 but compilation fails with PGF90-S-0155 error. Other compilers (gnu, intel, cce) compile the same code without failure. Would you have a suggestion on how to compile the code with PGI please ?
pgf90 -g -c RealPrecision.F90 -o RealPrecision.o
pgf90 -g -c 0T.F90 -o 0T.o
pgf90 -g -c 1.F90 -o 1.o
PGF90-S-0155-reducevals is use-associated from modules xi_mod and xrp_mod, and cannot
be accessed (1.F90: 7)
Having a PIN does make a difference if you are under maintenance contract.
Your PIN expired in 2014, making it eligible for 14.4 or older.
If we fix the reported problem, it will be in a future release, not 14.4.
It will also be in
a future community edition as well, but that is not released as often as
professional edition releases.
My sysadmin showed me the new PIN and PIN codes.
How can i share them with you ? If i enter them in my profile, will my sysadmin still be able to manage the license keys ?
I see multiple FREE-PGI-OSX PINs tied to accounts from your email address.
Those are not licenses actually, just the ability to download a version of the PGI
compilers for OS X that is not licensed. So having a PIN like that does not
give any extra PGI support.
We do not offer the FREE-PGI-OSX product anymore. It was limited in
what it allowed you to do.
I suggest that you go to http://www.pgroup.com/products/community.htm
and download the 16.10 version of the MAC OS X product, which is identical
to the standard PGI compilers on MACs, and is a free license.
If however, you have a purchased PIN for OS X that is current, you
can send it to license@pgroup.com, and we will get the PIN tied to your account.
It looks like the PGI Fortran compiler is accessing the module procedure “reducevals” via USE association, not the two instances of the generic interface of the same name.
It compiles if you change the name of the subroutine in both modules (and the reference thereto in the generic interfaces) to something different.
It also compiles if you add a redundant ONLY clause to the USE statements (e.g., USE xrp_mod, ONLY : reduceVals).
This seems like it might be worth recommending as a work-around.
