I’m getting this error when trying to compile my Fortran program. The executable is created, but it is just skipping the code within the “accelerated” block.
Any ideas on how to fix it?
Thanks,
Chris
pgfortran tblock-07-5.f90 -o tblock-07-5 -ta=nvidia,time -Minfo=accel,ccff -fast -mcmodel=medium
/tmp/pgaccxwjbfCJOVw66.gpu(272): error: identifier "__pgf90io_src_info03" is undefined
1 error detected in the compilation of "/tmp/pgnvdxGjbf94JpPV8.nv0".
PGF90-W-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (tblock-07-5.f90: 7424)
set_xlength:
7424, Generating present_or_copyin(mixl_type(:))
Generating present_or_copyin(rt(:,:,:,:))
Generating present_or_copyin(r(:,:,:,:))
Generating present_or_copyin(x(:,:,:,:))
Generating present_or_copyin(ni(:))
Generating present_or_copyin(nj(:))
Generating present_or_copyin(nk(:))
Generating present_or_copyin(area_max(:))
Generating present_or_copyin(vol_total(:))
Generating present_or_copyout(difmin(:))
7426, Loop is parallelizable
Accelerator kernel generated
7426, !$acc loop gang ! blockidx%x
7442, !$acc loop vector(128) ! threadidx%x
7453, !$acc loop vector(128) ! threadidx%x
7463, !$acc loop vector(128) ! threadidx%x
7441, Loop is parallelizable
7442, Loop is parallelizable
7452, Loop is parallelizable
7453, Loop is parallelizable
7463, Loop is parallelizable
7464, Loop is parallelizable
0 inform, 1 warnings, 0 severes, 0 fatal for set_xlength
