Compiler info:
pgfortran 13.3-0 64-bit target on x86-64 Linux -tp k8e
Command line:
pgfortran test2.f90 -o test2.exe; ./test2.exe
Output:
**debug(threed_deallocate): entering
**debug(threed_deallocate): on rec 1
**debug(image_deallocate): entering
in mem?
T
**debug(image_deallocate): exiting
**debug(threed_deallocate): deallocating rec array, size 1
in mem?
F
in mem?
Error: segmentation violation
rax 0000000000000000, rbx 6563696e00000000, rcx 00000000005963c0
rdx 00000000005963c0, rsp 0000007fbfffc8c0, rbp 0000007fbfffc8d0
rsi 0000000000000000, rdi 0000000000000000, r8 0000000000000000
r9 0000000000000001, r10 000000000045b1dc, r11 0000000000000246
r12 0000000000000000, r13 6563696e00000000, r14 0000000000568ca0
r15 0000000000000000
--- traceback not available
Workaround:
Remove the assignment (" = ‘nice’ ") on line 4 of test2.f90
Output with workaround:
in mem?
T
in mem?
F
**debug(threed_deallocate): deallocated rec array
test2.f90 (likely this can be trimmed further):
module images_base
type image
logical :: in_memory = .false.
character(len=4) :: type = 'nice' ! Commenting the default assignment to 'nice' gets rid of problem
contains
final :: image_deallocate
end type image
contains
subroutine image_allocate(img)
type(image), intent(inout) :: img
if (img%in_memory) call image_deallocate(img)
img%in_memory = .true.
end subroutine image_allocate
subroutine image_deallocate(img)
write(*,'(a)') '**debug(image_deallocate): entering'
print *, 'in mem?'
print *, img%in_memory
if (img%in_memory) img%in_memory = .false.
write(*,'(a)') '**debug(image_deallocate): exiting'
end subroutine image_deallocate
end module images_base
module threeds_base
use images_base
type threed_reconstruction
type(image) :: vol_image
end type threed_reconstruction
type threed
type(threed_reconstruction), allocatable :: rec(:)
contains
final :: threed_deallocate
end type threed
contains
subroutine threed_init( self )
type(threed), intent(inout) :: self
integer :: nnum_of_recs, current_rec
nnum_of_recs = 1
if (allocated(self%rec)) deallocate(self%rec)
allocate(self%rec(nnum_of_recs))
if (self%in_memory) call threed_deallocate(self)
do current_rec=1,size(self%rec)
call image_allocate(self%rec(current_rec)%vol_image)
enddo
self%in_memory = .true.
end subroutine threed_init
subroutine threed_deallocate(self)
integer :: current_rec
logical, parameter :: debug = .true.
write(*,'(a)') '**debug(threed_deallocate): entering'
if (self%in_memory) then
write(*,'(a,i0)') '**debug(threed_deallocate): on rec ', current_rec
call image_deallocate(self%rec(current_rec)%vol_image)
enddo
write(*,'(a,i0)') '**debug(threed_deallocate): deallocating rec array, size ', size(self%rec)
write(*,'(a)') '**debug(threed_deallocate): deallocated rec array'
endif
self%in_memory = .false.
end subroutine threed_deallocate
end module threeds_base
module threeds
contains
subroutine threed_unit_test_1()
use threeds_base
type(threed) :: self
call threed_init(self)
end subroutine threed_unit_test_1
end module
program testprog
use threeds
call threed_unit_test_1()
end program
