Hi guys,
I have some code. I marked it with ACC and compiled it.
PGI reported that kernel was generated, but I got the error at runtime. Debugging show the following error:
pgi_uacc_launch funcnum=0 argptr=0xbfe8c370 sizeargs=0xbfe8c368 async=-1 devid=1
Arguments to function 0 morr_two_moment_micro_1694_gpu:
27 26 27 58 71 27 1 2
2 89128960 97471648 98050560 114294784 98520224 99099136 113691136
99568800 100147712 113246208 100617376 101196288 112642560 101665952 102244864
112197632 102714528 103293440 111593984 103763104 104342016 111149056 104857600
105302528 110545408 105860256 106439168 110100480 106908832 107487744 109496832
108402336 108003328 109051904 97001984 93328384 93328896 93329408 93329920
93330432 93330944 93331456 93331968 93332480 93332992 96423072 93327872
93327360 93326848 93326336 93325824 93325312 93324800 93324288 93323776
93323264 92274688 91671040 91226112 90622464 90177536 89145856 89162752
95865344 95420416 94816768 94371840 92719616 118 58 -6809
82 2296 27 1 1127481344 3187 27 1566
1 1 674505948 1124897428 1077936128 1160942153 1232348160 1148796928
1135776330 1195593728 1141014987 1105259141
0x0000001b 0x0000001a 0x0000001b 0x0000003a 0x00000047 0x0000001b 0x00000001 0x00000002
0x00000002 0x05500000 0x05cf4ca0 0x05d82200 0x06d00000 0x05df4ca0 0x05e82200 0x06c6ca00
0x05ef4ca0 0x05f82200 0x06c00000 0x05ff4ca0 0x06082200 0x06b6ca00 0x060f4ca0 0x06182200
0x06b00000 0x061f4ca0 0x06282200 0x06a6ca00 0x062f4ca0 0x06382200 0x06a00000 0x06400000
0x0646ca00 0x0696ca00 0x064f4ca0 0x06582200 0x06900000 0x065f4ca0 0x06682200 0x0686ca00
0x067616a0 0x06700000 0x06800000 0x05c82200 0x05901400 0x05901600 0x05901800 0x05901a00
0x05901c00 0x05901e00 0x05902000 0x05902200 0x05902400 0x05902600 0x05bf4ca0 0x05901200
0x05901000 0x05900e00 0x05900c00 0x05900a00 0x05900800 0x05900600 0x05900400 0x05900200
0x05900000 0x05800000 0x0576ca00 0x05700000 0x0566ca00 0x05600000 0x05504200 0x05508400
0x05b6ca00 0x05b00000 0x05a6ca00 0x05a00000 0x0586ca00 0x00000076 0x0000003a 0xffffe567
0x00000052 0x000008f8 0x0000001b 0x00000001 0x43340000 0x00000c73 0x0000001b 0x0000061e
0x00000001 0x00000001 0x283424dc 0x430c9294 0x40400000 0x45329249 0x49742400 0x44794000
0x43b2924a 0x47435000 0x440281cb 0x41e0ea85
cuda_launch argument bytes=516, max=240 move 276 bytes at offset 240 to devaddr 0x5400000
call to cuEventSynchronize returned error 700: Launch failed
I remember there was a limit for size of kernel arguments (256 byte). Could it be the reason of launch failure in this case? What else should I check to find the reason of failure? No shared memory is used.
Alexey
