Dear all,
we moved from version 17.10 of PGI Fortran compiler to version 18.10 in Visual Studio 2015 environment.
The following error appears in compiling phase of any kind of CUDA kernel:
pgnvd-Error-PSDK is not set
followed by:
error F0155 : Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code
Best regards
Oriano
Hi Oriano,
PGI 18.10 requires VS 2017’s SDK. Most likely you don’t have this installed and hence the error.
Please see the following link: https://www.pgroup.com/support/windows-coinstall.htm
Hope this helps,
Mat
I am having the same error about pgnvd-Error-PSDK not being set, although I have VS 2017 and the relevant SDK installed as described on https://www.pgroup.com/support/windows-coinstall.htm
Is there anything else I am missing?
Regards,
Aristotelis
There’s a known issue where the PSDK variable doesn’t properly get set, depending on the version of visual studio. The good news is that this should be easy rectify.
Inside the PGI installation dir, within the bin/ directory (C:\Program Files\PGI\win64<version-number>\bin), there should be a file named localrc. Open the file in some text editor and you’ll notice an entry named PSDK17. Double-check that the value points to a valid path with the right trailing version number.
For example, this is what the path is on my system. You’ll want to make sure that the valid path and the quoted value in the PSDK17 variable are the same.
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023
