**• Hardware Platform (Jetson / GPU)**Xavier • DeepStream Version5.0 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi.
I’d like to get the pipeline process time within my code so that I can do analysis on it.
I can find the code for latency_measurement_buf_prob in deepstream.c which outputs the -->frame<-- latency to the terminal, when you export NV_ENABLE_LATENCY_MEASUREMENT=1. This seems to come from the NvDsFrameLatencyInfo structure in the AppCtx object.
Where is the similar code that outputs to the terminal the pipeline latencies when you set NV_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1?
Which object do I get the NvDsMetaCompLatency structure from so that I can calculate the latencies for each component?
It’s stored as NvDsBatchMeta field batch_user_meta_list, you can by enable environment variable
export NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1 to get the components latency.
Thanks. The reason I was wanting pipleine latencies is because my Frame latency seems to be a timestamp value, rather than the difference between decode and osd timestamps(?). So this is actually my problem.
In deepstream_app.c line 614 when I include output for latency_info[i].comp_in_timestamp these are all returning 0 (as %lf) when I run the application (which I guess is the reason the latency is such a large figure). I’m using a USB camera, have set [streammux] live_source to 1 and sink sync to 0.
You can check the frame arriving time for each components. which we already implemented, you can get it by enabling above mentioned environt viariables.
