• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.3 (docker image: nvcr.io/nvidia/deepstream:6.3-triton-multiarch)
• NVIDIA GPU Driver Version (valid for GPU only) 525.147.05
• Issue Type( questions, new requirements, bugs) Questions/Bugs
I am using the deepstream reference application (apps/sample_apps/deepstream-app) enabling the New Gst-nvstreammux ( export USE_NEW_NVSTREAMMUX=yes). The inputs are RTSP sources.
I have observed pixel distortions on the sink (type: 2) when the pipeline’s performance measurement (FPS) falls below the frame rate of the RTSP sources, which is 25fps.
To replicate this issue, I configured the application with 20 sources. I have 2 IP cameras, and I duplicated each stream 10 times within the sources_rtsp.csv file. A video example of pixel distortions can be found here:
pixel_distortions_example.zip (17.9 MB)
However, when I reduced the number of sources to 10, the pipeline can achieve a performance measurement of 25 FPS and the pixel distortions disappeared.
Has anyone encountered this issue before?
Your assistance would be greatly appreciated.
Thank you.
The deepstream-app configuration is:
application:
enable-perf-measurement: 1
perf-measurement-interval-sec: 5
tiled-display:
enable: 1
rows: 4
columns: 5
width: 1920
height: 1080
gpu-id: 0
nvbuf-memory-type: 0
source:
csv-file-path: sources_rtsp.csv
sink0:
enable: 1
type: 2
sync: 0
source-id: 0
gpu-id: 0
osd:
enable: 1
gpu-id: 0
border-width: 1
text-size: 15
text-color: 1;1;1;1
text-bg-color: 0.3;0.3;0.3;1
font: Serif
show-clock: 0
clock-x-offset: 800
clock-y-offset: 820
clock-text-size: 12
clock-color: 1;0;0;0
streammux:
attach-sys-ts: 1
config-file: config_mux.txt
primary-gie:
enable: 1
gpu-id: 0
model-engine-file: ../../models/Primary_Detector/resnet10.caffemodel_b20_gpu0_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size: 20
bbox-border-color0: 1;0;0;1
bbox-border-color1: 0;1;1;1
bbox-border-color2: 0;0;1;1
bbox-border-color3: 0;1;0;1
interval: 0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id: 1
config-file: config_infer_primary.yml
where sources_rtsp.csv contains:
enable,type,uri,num-sources,gpu-id,cudadec-memtype
1,4,rtsp://10.10.11.123:554,1,0,0
1,4,rtsp://10.10.11.122:554,1,0,0
and config_mux.txt contains:
[property]
adaptive-batching=1
frame-duration=-1
batch-size=20
## Set to maximum fps
overall-min-fps-n=25
overall-min-fps-d=1
## Set to ceil(maximum fps/minimum fps)
max-same-source-frames=1
[source-config-0]
## Set to ceil(current fps/minimum fps)
max-num-frames-per-batch=1
[source-config-1]
[source-config-2]
[source-config-3]
[source-config-4]
[source-config-5]
[source-config-6]
[source-config-7]
[source-config-8]
[source-config-9]
[source-config-10]
[source-config-11]
[source-config-12]
[source-config-13]
[source-config-14]
[source-config-15]
[source-config-16]
[source-config-17]
[source-config-18]
[source-config-19]
