• Hardware (RGX 3080)
• Network Type (Classification)
• TLT Version format_version: 2.0
toolkit_version: 3.22.05
published_date: 05/25/2022()
• Training spec file
• How to reproduce the issue ?
Copy the comment from [Errno 2] No such file or directory:when 'tao classification train' is run - #10 by pddarrell
From your .tao_mounts.json, you already mount “/home/perter/TAO_toolkit” to “/workspace/tao-experiments”.
In all command such as " ! tao classification train -e spec.txt " , please note that the spec.txt should be in the path of docker. In other words, the spec.txt should be available in “destination” of the tao_mounts.josn.
