please run this there is a run time error
Hi all can any body please run this code, and see if there is a error while the execution…
my result —
bibrak@biebo-laptop:/media/Academics/Academic/Research/HPC/CUDA/Iam new to CUDA/test/fence$ make
nvcc -run -I/home/bibrak/NVIDIA_CUDA_SDK/common/inc -I/usr/local/cuda/include -L/home/bibrak/NVIDIA_CUDA_SDK/lib -lcutil -L/usr/local/cuda/lib -lcudart -lcuda test.cu
total mem: 128.284 MB, free: 1024.395 MB, used : 3199.889 MB
total mem: 255.312 MB, free: 114.434 MB, used : 140.879 MB
cudaSafeCall() Runtime API error in file <test.cu>, line 192 : unspecified launch failure.
make: *** [all] Error 255
[codebox]/*
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, project
#include <cutil_inline.h>
device unsigned int count = 0;
shared bool isLastBlockDone;
device shared float partialSum ;
const int N = 1024;
const int p = 2;
device float calPartialSum(const float *array,int i);
device float calculateTotalSum(const float *result);
global void sum(const float* array,float* result)
	int i = threadIdx.x;
	if(i == 0 ){
	partialSum = 0;
	__syncthreads();
               // Each block sums a subset of the input array
            float partialSum_thread = calPartialSum(array, i);
	partialSum += partialSum_thread;
	__threadfence_block(); // so that effect of one thread is vissible
				// to all
if (threadIdx.x == 0) {
                     // Thread 0 of each block stores the partial sum
                     // to global memory
                     result[blockIdx.x] = partialSum;
                     // Thread 0 makes sure its result is visible to
                     // all other threads
                     __threadfence();
                     // Thread 0 of each block signals that it is done
                    // unsigned int value = atomicInc(&count, gridDim.x);
                    	 unsigned int value = count++;
		// Thread 0 of each block determines if its block is
                     // the last block to be done
                     isLastBlockDone = (value == (gridDim.x - 1));
               // Synchronize to make sure that each thread reads
               // the correct value of isLastBlockDone
               __syncthreads();
if (isLastBlockDone) {
                     // The last block sums the partial sums
                     // stored in result[0 .. gridDim.x-1]
                     float totalSum = calculateTotalSum(result);
                         // Thread 0 of last block stores total sum
                         // to global memory and resets count so that
                         // next kernel call works properly
                         result[0] = totalSum;
                         count = 0;
// this funtion will calculate partial sum of the array
// the number of elements will be p
device float calPartialSum(const float *array,int i){
int start = i*p;
int end = start + p;
float pSum = 0;
for(int q = start; q<end ; q++){
pSum += array[q];
return pSum;
device float calculateTotalSum(const float *result){
float total = 0;
for (int q = 0; q<gridDim.x; q++){
	total += result[q];
return total;
int main(){
float *array;
float *result;
float *D_result;
float *D_array;
dim3 threads(256);
dim3 grid( (N/p) / threads.x );
//[debug]
unsigned int free_mem,total_mem, used_mem;
cuMemGetInfo( &free_mem, &total_mem );
used_mem = total_mem-free_mem;
printf(“total mem: %0.3f MB, free: %0.3f MB, used : %0.3f MB\n”,
((double)total_mem)/1024.0/1024.0,
((double)free_mem )/1024.0/1024.0,
((double)used_mem )/1024.0/1024.0 );
//[end debug]
array = (float*) malloc(N*sizeof(float));
size_t size_array = N * sizeof(float);
cutilSafeCall(cudaMalloc((void**)&D_array, size_array));
for(int w=0 ;w<N;w++){
array[w] = 1;
cutilSafeCall(cudaMemcpy(D_array,array,size_array,cudaMemcpy
HostToDevice));
size_t size_result = grid.x * sizeof(float);
result = (float*) malloc(size_result);
cutilSafeCall(cudaMalloc((void**)&D_result, size_result));
//cutilSafeCall(cudaMemcpy(D_result,array,size,cudaMemcpyHostT
oDevice));
sum<<<grid,threads>>>(D_array,D_result);
//[debug]
//[end debug]
//cutilSafeCall(cudaMemcpy(C.elements,d_C.elements,sizeC,cudaM
emcpyDeviceToHost));
cutilSafeCall(cudaMemcpy(result,D_result,size_result,cudaMem
cpyDeviceToHost));
//print result and free the memory
printf("The total sum = %f \n",result[0]);
free(array);
free(result);
cudaFree(D_result);
cudaFree(D_array);
return 0;
[/codebox]
I don’t mind trying to help, but when trying to build, I get:
make
nvcc -run -I/opt/cuda/sdk/C/common/inc/ -L/opt/cuda/sdk/C/lib -lcutil -L/opt/cuda/lib -lcudart -lcuda main.cu
main.cu(119): error: identifier “size” is undefined
main.cu(134): error: identifier “C” is undefined
main.cu(134): error: identifier “d_C” is undefined
main.cu(134): error: identifier “sizeC” is undefined
I would try commenting out stuff until I could determine where the problem occurs. Then move on to why.
i have attached the file(code)
test.cu (4.52 KB)
GTX295
total mem: 0.000 MB, free: 38.806 MB, used : 4057.194 MB
total mem: 895.750 MB, free: 849.434 MB, used : 46.316 MB
The total sum = 4.000000
TeslaC1060
total mem: 0.000 MB, free: 37.744 MB, used : 4058.256 MB
total mem: 4095.750 MB, free: 4049.434 MB, used : 46.316 MB
The total sum = 6.000000
what’s your kerel “sum” do? sum over all elememts in an array?
if so, I cannot understand your kernel code.
nvcc -run -I/opt/cuda/sdk/C/common/inc/ -L/opt/cuda/sdk/C/lib -lcutil -L/opt/cuda/lib -lcudart -lcuda test.cu
total mem: 0.000 MB, free: 0.000 MB, used : 0.000 MB
total mem: 511.688 MB, free: 320.820 MB, used : 190.867 MB
The total sum = 8.000000
No launch failure for me
thanks for the help …
i have implemented the addition of elements of array given in programing guide page 117.
i cannot understand why its giving me launch failure …
As I dislike repeating myself, I refer back to my first post.
