Tigga
September 10, 2008, 9:34am
1
I’m fairly sure I know the answer to this, but I’m going to ask anyway…
If I have a device pointer:
double *pointer_device;
and I want a new incremented device pointer:
double *pointer_device2 = &pointer_device[1];
is this a safe operation on the CPU?
Ailleur
September 10, 2008, 10:53am
2
I am not saying this with authority as i have not completly fixed my problem, but when i tried to do:
udata = kernel->udata + iip * nur;
udata[offset + last_rindex];
Where udata and kernel->udata are float*, the program would crash.
While
Works (params.knur = nur)
Maybe some of the answer is there, but as i said, dont take this for granted!
[snapback]437848[/snapback]
Hmm, I assume that works, but now that you ask, it could explain some wrong output I am seeing if this turn out to be actually not supported…
I’ll try to report back asap to see if my problem is fixed when I change this.
[snapback]437916[/snapback]
Not sure yet, I think it works. After splitting things up, I end up with the same incorrect answers in the second array, so it looks like the results are the same and I have a bug somewhere else in my code…
I have been using such assignments without any problem:
float e; float *d_e; float *dptr; int *nx; int *ny; int *nout;
unsigned int mem_size = sizeof(float);
__constant__ int dmiscint[32];
dptr = &d_e[miscint[16] * ((*ny+1) * (*nout - 1) + (*ny+1)/2) + (*nx+1)/2 ];
CUDA_SAFE_CALL(cudaMemcpy(&e, dptr, mem_size, cudaMemcpyDeviceToHost));
