Jetson
• DeepStream Version
6.1.1
i’m trying t populate the NvBufSurface surf with the cv::Mat image with this function that basically
creates a NvBufSurface* new_image then
NvBufSurfaceMap (new_image, 0, 0, NVBUF_MAP_READ_WRITE)
NvBufSurfaceSyncForCpu (new_image, 0, 0) -
copy the buffer into new_image with
memcpy(new_image->surfaceList[0].mappedAddr.addr[0], rgba.ptr(), 112 * 112 * 4); -
and then copy the surface new_image to the original surface surf
NvBufSurfaceCopy(new_image, surf)
but when i try to read back the data from the surf i get this strange disalignment of the pixels
the first row is ok, then the next rows starts to shifts somehome as shown here
this is the code of the function
void put_surf_image_back3(NvBufSurface *surf, cv::Mat &image, bool use_pitch_alignment) {
std::cout << "put_surf_image_back3 start" << "\n";
NvBufSurfTransformParams surf_transform_params = {
.transform_flag = NVBUFSURF_TRANSFORM_FILTER,
.transform_flip = NvBufSurfTransform_None,
.transform_filter = NvBufSurfTransformInter_Default,
.src_rect = nullptr,
.dst_rect = nullptr
if ((surf == nullptr) || (surf->numFilled <= 0)) {
std::cerr << "write_surf_bgra_to_disk: surf is nullptr or numFilled is 0" << std::endl;
return;
std::cout << "surf->surfaceList[0].width : " << surf->surfaceList[0].width << "\n";
std::cout << "surf->surfaceList[0].height : " << surf->surfaceList[0].height << "\n";
std::cout << "surf->surfaceList[0].colorFormat : " << surf->surfaceList[0].colorFormat << "\n";
std::cout << "surf->numFilled : " << surf->numFilled << "\n";
NvBufSurface *new_image = nullptr;
NvBufSurfaceCreateParams nvbufsurface_create_params{
.gpuId = surf->gpuId,
.width = surf->surfaceList[0].width,
.height = surf->surfaceList[0].height,
.size = 0,
.isContiguous = true,
.colorFormat = NVBUF_COLOR_FORMAT_RGBA,
.layout = NVBUF_LAYOUT_PITCH,
.memType = NVBUF_MEM_DEFAULT
// we create the new surface new_image
if (NvBufSurfaceCreate(&new_image, 1, &nvbufsurface_create_params) != 0) {
std::cerr << "put_surf_image_back: failed to allocate memory" << std::endl;
return;
std::cout << "new_image->surfaceList[0].width : " << new_image->surfaceList[0].width << "\n";
std::cout << "new_image->surfaceList[0].height : " << new_image->surfaceList[0].height << "\n";
std::cout << "new_image->surfaceList[0].colorFormat : " << new_image->surfaceList[0].colorFormat << "\n";
std::cout << "new_image->numFilled : " << new_image->numFilled << "\n";
new_image->numFilled = 1;
if (NvBufSurfaceMap (new_image, 0, 0, NVBUF_MAP_READ_WRITE) != 0){
printf("Err in Map\n");
if (NvBufSurfaceSyncForCpu (new_image, 0, 0) !=0) {
printf("Err in Synccpu");
cv::Mat rgba;
std::cout << "image.size() : " << image.size() << "\n";
// std::cout << "image.at(0,0) : " << image.at(0,0) << "\n";
cv::cvtColor(image, rgba, cv::COLOR_BGR2RGBA);
// Copy the buffers to the allocated memory
if (NvBufSurfaceCopy(new_image, surf) != 0) {
std::cerr << "put_surf_image_back: failed to copy buffers" << std::endl;
NvBufSurfaceDestroy(new_image);
return;
std::cout << "put_surf_image_back3 end" << "\n";
and this if the output debug of the function
surf->surfaceList[0].width : 112
surf->surfaceList[0].height : 112
surf->surfaceList[0].colorFormat : 19
surf->numFilled : 1
new_image->surfaceList[0].width : 112
new_image->surfaceList[0].height : 112
new_image->surfaceList[0].colorFormat : 19
new_image->numFilled : 0
image.size() : [112 x 112]
new_image->numFilled : 1
what i’m missing here?
