Possible bug: GL_ARRAY_SIZE of a shader storage block member is always zero
I have a shader that defines the following block:
layout(std140) readonly buffer b_buff {
    mat4 u_mvp[8U];
When calling glGetProgramResourceiv to retrieve the array size (GL_ARRAY_SIZE) of the u_mvp variable, the driver returns 0.
If I replace the shader storage block with a uniform block it returns 8 as expected:
layout(std140) uniform b_buff {
    mat4 u_mvp[8U];
I couldn’t find something in the spec that differentiates the behavior of uniform blocks and shader storage blocks when it comes to reporting array sizes. But I am not quite sure.
OS: Linux 3.11.0-20-generic x86_64 (= Ubuntu 13.10 64bit)
Driver version: 331.20
GPU: GeForce GTX 560 Ti
Also the full source of my test to save you some time:
static int
create_program(const char *source, const GLenum type, GLuint *program)
	GLuint prog;
	GLint status;
	prog = glCreateShaderProgramv(type, 1, &source);
	glGetProgramiv(prog, GL_LINK_STATUS, &status);
	if (status == GL_FALSE) {
		GLint len = 0;
		GLint written = 0;
		char *txt;
		glGetProgramiv(prog, GL_INFO_LOG_LENGTH, &len);
		txt = malloc(len + 1);
		glGetProgramInfoLog(prog, len, &written, txt);
		error(txt);
		free(txt);
		return 1;
	*program = prog;
	return 0;
static int
test_shader_arrays()
	static const char *vert_source =
		"#version 440 core\n"
		"layout(location = 0) in vec3 position;\n"
		"layout(std140) readonly buffer b_buff {\n"
		"\tmat4 u_mvp[8U];\n"
		"};\n"
		"out gl_PerVertex {\n"
		"vec4 gl_Position;\n"
		"};\n"
		"void main()\n"
		"{\n"
		"\tgl_Position = u_mvp[gl_InstanceID] * "
		"vec4(position * 0.9, 1.0);\n"
		"}\n";
	GLuint prog;
	GLint count;
#if 1
	static const GLenum interface = GL_BUFFER_VARIABLE;
#else
	static const GLenum interface = GL_UNIFORM;
#endif
	unsigned i;
	if (create_program(vert_source, GL_VERTEX_SHADER, &prog)) {
		error("create_program() failed");
		return 1;
	glGetProgramInterfaceiv(prog, interface, GL_ACTIVE_RESOURCES, &count);
	for (i = 0; i < count; i++) {
		char name[256];
		GLsizei len;
		GLenum props[] = {GL_ARRAY_SIZE};
		GLenum out[1];
		glGetProgramResourceName(prog, interface, i, sizeof(name),
					 &len, name);
		name[len] = '
static int
GLuint prog;
GLint status;
	GLint len = 0;
	GLint written = 0;
	char *txt;
	error(txt);
	free(txt);
	return 1;
*program = prog;
return 0;
static int
#version 440 core\n”
“layout(location = 0) in vec3 position;\n”
“layout(std140) readonly buffer b_buff {\n”
“\tmat4 u_mvp[8U];\n”
“};\n”
“out gl_PerVertex {\n”
“vec4 gl_Position;\n”
“};\n”
“void main()\n”
“{\n”
“vec4(position * 0.9, 1.0);\n”
“}\n”;
GLuint prog;
GLint count;
#if 1
#else
#endif
unsigned i;
	return 1;
	char name[256];
	GLsizei len;
	GLenum out[1];
				 &len, name);
	name[len] = '\0';
	glGetProgramResourceiv(prog, interface, i,
			       1, props,
			       1, NULL, out);
	printf("name: %s array_size: %d\n", name, out[0]);
return 0;
				       1, props,
				       1, NULL, out);
	return 0;
