Power consumption big discrepancy for relatively idle scenarios: Linux vs. Windows
NVIDIA has been constantly working to improve power management in Linux but there are still certain situations when the Linux driver needlessly uses a lot more power than Windows 10 (haven’t tried W11 yet).
Environment:
OS: Fully updated Fedora 36, Linux 5.19.16, NVIDIA 520.56.06
DE: XFCE4 without compositing
GPU: GTX 1660 Ti, stock
CPU: Ryzen 7 5800X
Monitor: 2560x1440@144Hz connected via DisplayPort
Additional settings:
    Option      "Coolbits" "28"
    Option      "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
    Option      "UseNvKmsCompositionPipeline" "Off"
Driver options
options nvidia NVreg_EnableS0ixPowerManagement=1
options nvidia-drm modeset=1
  1. Working in Firefox. In Windows 10 when you browse light static HTML pages (uBlock Origin, no banners, etc) GPU consumes on average around 9W. Under Linux: 27W. Steps to reproduce: Just launch Firefox with a new Tab page where you see you most visited websites and Pocket recommendations below. Start erratically scrolling it up and down fast. This is a 100% static webpage for all intents and purposes.
  2. Try to drag around the screen a simple static application [window] after minimizing or closing all other applications, e.g. Mousepad. It starts with ~27W, then settles on 15W. Under Windows 10? Again, around 9W.
  3. Full screen 1080p videos in Firefox under Linux consume around ~25W vs ~12W in Windows. Just open any Twitch stream and switch to full screen. No video acceleration is used in Linux. In Windows 10 video acceleration is used/enabled, which means it should use more energy but it uses less. So, under Linux not only your CPU is used to decode videos (more power use), also your GPU uses more energy to render videos which makes Linux power-wise a very bad desktop OS.
  4. mpv with vdpau vs Windows MPC-HC. Again Windows comes on top by a wide margin.
It would be great if NVIDIA addressed these scenarios.
Better yet, it would be really great if there was a special list of applications for which the NVIDIA driver was allowed to clock up GPU and VRAM.
@aplattner @amrits
Would be great if people chimed in and reported other scenarios where the Linux NVIDIA driver uses more power vs. Windows 10/11.
I don’t really use Windows but I’ve noticed the Nvidia driver generally speaking is quick to decrease the performance state(read: increase voltage & clocks), often resulting in performance state fighting where it decreases and then increases the performance state in a loop when not even interacting with the PC.
Viewing the dynamic performance state information returned by NVML shows that the graphics threshold for increasing the performance state is always 40 %. This doesn’t seem right as a higher performance state is naturally going to have much lower clocks than if it was a lower one.
Some images from my own app showing this:
I think there needs to be a way to tune these thresholds based on whether you prefer faster clock boosting or power savings. It seems like the option in nvidia-settings doesn’t do anything.
Nice data!
Environment:
OS : Fedora 37 KDE (X11) / Windows 10
CPU : Ryzen 7 1800X
GPU : GTX 1080Ti
Monitors : 1440p144 DP + 1080p60 HDMI
On Linux, my 1080Ti is almost always using between 65W - 80W (“stuck” on performance level 3) just doing some web browsing and switching / moving windows. On complete idle (nothing moving on the screen), it takes at least 30 secs for the power usage to go down to ~20W (going down to performance level 0).
Doing the same on Windows 10 , power consumption is only between 17W - 22W . It will go up to ~65W in some situations (starting some apps for example) but will go back down within 10 secs.
  • I tried only using a 1080p60 monitor : Would still average ~60W power usage
  • A few months ago I tried other distributions and DEs : No difference
My current workaround is to lock my GPU to performance level 0 which uses between 20W - 30W. I still get decent desktop performance (with some slowdowns) but I have to reboot to unlock the performance levels (mostly for gaming).
