pragma unroll error - Advisory: Loop was not unrolled, unexpected control flow construct
I’ve been trying to play around with the pragma unroll construct but I keep getting the following compiler warning:
Any idea what can be causing it and how to get pragma unroll working?
One of the codes that exhibits the problem if it helps:
[codebox]#pragma unroll 4
	for (int kx = 0 ; kx < seWidth  ; kx++)
		unsigned char v;
		v = tex2D(seTex, kx, ky);
		if (v)
			// Erosion of image by structuring element
			fgResponse.x = fgResponse.x && PATCH(sx     + kx, threadIdx.y + ky);
			fgResponse.y = fgResponse.y && PATCH(sx + 1 + kx, threadIdx.y + ky);
			fgResponse.z = fgResponse.z && PATCH(sx + 2 + kx, threadIdx.y + ky);
			fgResponse.w = fgResponse.w && PATCH(sx + 3 + kx, threadIdx.y + ky);
		v = tex2D(secTex, kx, ky);
		if (v)
			// Erosion of image complement by background structuring element (not that
			// the background structuring element is not the structuring element complement
			// if we want non-square hit-or-miss transform
			bgResponse.x = bgResponse.x && !PATCH(sx     + kx, threadIdx.y + ky);
			bgResponse.y = bgResponse.y && !PATCH(sx + 1 + kx, threadIdx.y + ky);
			bgResponse.z = bgResponse.z && !PATCH(sx + 2 + kx, threadIdx.y + ky);
			bgResponse.w = bgResponse.w && !PATCH(sx + 3 + kx, threadIdx.y + ky);
	}[/codebox]
I’m quite certain that it’s the texture fetch that you are doing.
Unfortunately these calls can’t be unrolled if my memory serves me.
So you might have to go manual :)
Thanks, did some tests after your suggestion, and it seems that it’s not the texture fetch functions, but rather the logical operations.
For some reason, if I change all the && in the code to * loop unrolling works fine. Unfortunately I also have a goto in the original code
(to break out of two loops at once) which kills loop unrolling as well
Aha, so with some changes you manage to unroll despite the texture fetch being there? I haven’t tried it myself but I’ve seen people on this forum complain about it not being possible.
Yeah the “goto” should make things tricky for you :)
