Precision and rounding in float point registers.
Hi All,
I’m trying to figure out how the .rn, .rm, .rp, .rz rounding qualifiers work on floating points in PTX. The documentation of them is pretty sketchy (see the “PTX: Parallel Thread Execution” PDF, the ADD instruction for example). Why? I’ve written a CUDA emulator to run on Windows, and wanted to figure out how these strange rounding options really work, so I could try to do the same. So, I wrote a small PTX/CUDA driver program that tests the difference between 1 and 1+1/2^n for some positive integer n, using 32-bit floating point registers, and the ADD{.rnd}.F32 and SETP.EQ.F32 instructions. Eventually, for some n, I expect no difference between the two numbers because the mantissa can hold only 23 bits. Otherwise, why even offer these rounding options on instructions?
I ran my program on a GT 470 GPU. What I expected was to see no difference between 1 and 1+1/2^23 in a 32-bit floating point register. For .rn, .rm, .rz rounding, there was no difference, which is what I expected. (I may be off by 1, so please be kind.) But for .rp, it seems that registers retain a mantissa of 150 digits. While I can understand computing floating points with a higher precision than 32-bits within the floating point unit, then truncating the results to 32 bits, I didn’t expect to see that the GPU computes it to a 150-bit mantissa. And, especially to find that 32-bit f.p. registers are not actually 32-bits!! (Seeing is believing–look at the code.)
Am I correct? Is a 32-bit f.p. register really NOT 32 bits?! And is this IEEE 754-2008 floating point conforming? As you can tell, I’m not an IEEE 754-2008 expert, and I don’t have a copy of the spec. And, I don’t understand what the doc means by “Instructions that support rounding modifiers are IEEE-754 compliant. Double-precision instructions support subnormal inputs and results.” Is there any better discussion of floating point calculations on the Fermi?
Ken
Here’s my code (C++, and PTX) and output:
[codebox]#include <stdio.h>
#include
#include <cuda.h>
void test(int x, const char * s)
int t = x;
if (t != 0)
	std::cout << "fail " << t << " " << s << "\n";
	std::cout.flush();
#define ALIGN_UP(offset, alignment) (offset) = ((offset) + (alignment) - 1) & ~((alignment) - 1)
void load_and_test_float(CUmodule cuModule, char * test_name)
try
	CUfunction proc;
	test(cuModuleGetFunction(&proc, cuModule, test_name), "cuModuleGetFunction");
	int max = 1000;
	float * h_R = (float*)malloc(max * sizeof(float));
	memset(h_R, 0, max * sizeof(float));
	CUdeviceptr d_R;
	test(cuMemAlloc(&d_R, max * sizeof(float)), "cuMemAlloc");
	test(cuMemcpyHtoD(d_R, h_R, sizeof(int)), "cuMemcpyHtoD");
	CUdeviceptr d_N;
	int h_N = 0;
	test(cuMemAlloc(&d_N, sizeof(int)), "cuMemAlloc");
	test(cuMemcpyHtoD(d_N, &h_N, sizeof(int)), "cuMemcpyHtoD");
	int offset = 0;
	void* ptr;
	ptr = (void*)(size_t)d_R;
	ALIGN_UP(offset, __alignof(ptr));
	test(cuParamSetv(proc, offset, &ptr, sizeof(ptr)), "cuParamSetv");
	offset += sizeof(ptr);
	ptr = (void*)(size_t)d_N;
	test(cuParamSetSize(proc, offset), "cuParamSetSize");
	int threadsPerBlock = 1;
	int blocksPerGrid = 1;
	test(cuFuncSetBlockShape(proc, threadsPerBlock, 1, 1), "cuFuncSetBlockShape");
	test(cuLaunchGrid(proc, blocksPerGrid, 1), "cuLaunchGrid");
	test(cuMemcpyDtoH(h_R, d_R, max * sizeof(float)), "cuMemcpyDtoH");
	test(cuMemcpyDtoH(&h_N, d_N, sizeof(int)), "cuMemcpyDtoH");
	test(cuMemFree(d_R), "cuMemFree");
	test(cuMemFree(d_N), "cuMemFree");
	union FOO
		float f;
		int i;
	} foo;
	for (int i = 0; i < h_N; ++i)
		foo.f = h_R[i];
		printf("%d %f %x\n", i, h_R[i], foo.i);
catch (...)
	std::string s = test_name;
	s = s.append(" crashed.\n");
	test(1, s.c_str());
int main(int argc, char *argv)
argc--; argv++;
test(cuInit(0), "cuInit");
int deviceCount = 0;
test(cuDeviceGetCount(&deviceCount), "cuDeviceGetCount");
int device = 0;
if (argc)
	device = atoi(*argv);
CUdevice cuDevice = 0;
test(cuDeviceGet(&cuDevice, device), "cuDeviceGet");
CUcontext cuContext;
int xxx = cuCtxCreate(&cuContext, 0, cuDevice);
CUmodule cuModule;
test(cuModuleLoad(&cuModule, "inst.ptx"), "cuModuleLoad");
load_and_test_float(cuModule, "TestRP");
load_and_test_float(cuModule, "TestRZ");
load_and_test_float(cuModule, "TestRN");
load_and_test_float(cuModule, "TestRM");
return 0;
[/codebox]
[codebox] .version 2.1
.target sm_20
// .version 1.4
// .target sm_13
.entry TestRP (
	.param .u32 __results,	// Float*
	.param .u32 __N		// N*
.reg .u32 %r<5>;
.reg .f32 %f32_<5>;
.reg .pred %p<3>;
// Set up
ld.param.u32	%r0,[__results];
mov.u32		%r2, 0;
// rp
mov.f32		%f32_1, 1.0;
again_rp:
mov.f32		%f32_0, 1.0;
div.full.f32	%f32_1, %f32_1, 2.0;
add.rp.f32	%f32_3, %f32_0, %f32_1;
st.global.f32	[%r0], %f32_3;
add.u32		%r2, %r2, 1;
add.u32		%r0, %r0, 4;
setp.ne.f32	%p0, %f32_3, %f32_0;
@%p0 bra again_rp;
end:
// Pass back the number of tests performed.
ld.param.u32	%r1,[__N];
st.global.u32	[%r1], %r2;
exit;
.entry TestRZ (
.reg .u32 %r<5>;
.reg .f32 %f32_<5>;
.reg .pred %p<3>;
// Set up
mov.u32		%r2, 0;
// rz
again_rz:
add.rz.f32	%f32_3, %f32_0, %f32_1;
@%p0 bra again_rz;
end:
exit;
.entry TestRN (
.reg .u32 %r<5>;
.reg .f32 %f32_<5>;
.reg .pred %p<3>;
// Set up
mov.u32		%r2, 0;
// rn
again_rz:
add.rn.f32	%f32_3, %f32_0, %f32_1;
@%p0 bra again_rz;
end:
exit;
.entry TestRM (
.reg .u32 %r<5>;
.reg .f32 %f32_<5>;
.reg .pred %p<3>;
// Set up
mov.u32		%r2, 0;
// rm
again_rz:
add.rm.f32	%f32_3, %f32_0, %f32_1;
@%p0 bra again_rz;
// see if it retains precision in a register, and I can subtract it.
mov.u32		%r3, 130;		// Only go to 130 bin decimal places.
again:
setp.ne.u32	%p0, %r3, %r2;
@%p0 bra again;
sub.rp.f32	%f32_3, %f32_3, %f32_1;
setp.eq.f32	%p0, %f32_3, %f32_0;
@%p0 bra equal;
st.global.f32	[%r0], 99.0;
bra		end;
equal:
st.global.f32	[%r0], 101.0;
end:
exit;
[/codebox]
Output:
[codebox]# ./ptx-inst.exe
0 1.500000 3fc00000
1 1.250000 3fa00000
2 1.125000 3f900000
3 1.062500 3f880000
4 1.031250 3f840000
5 1.015625 3f820000
6 1.007813 3f810000
7 1.003906 3f808000
8 1.001953 3f804000
9 1.000977 3f802000
10 1.000488 3f801000
11 1.000244 3f800800
12 1.000122 3f800400
13 1.000061 3f800200
14 1.000031 3f800100
15 1.000015 3f800080
16 1.000008 3f800040
17 1.000004 3f800020
18 1.000002 3f800010
19 1.000001 3f800008
20 1.000000 3f800004
21 1.000000 3f800002
22 1.000000 3f800001
23 1.000000 3f800001
24 1.000000 3f800001
25 1.000000 3f800001
26 1.000000 3f800001
27 1.000000 3f800001
28 1.000000 3f800001
29 1.000000 3f800001
30 1.000000 3f800001
31 1.000000 3f800001
32 1.000000 3f800001
33 1.000000 3f800001
34 1.000000 3f800001
35 1.000000 3f800001
36 1.000000 3f800001
37 1.000000 3f800001
38 1.000000 3f800001
39 1.000000 3f800001
40 1.000000 3f800001
41 1.000000 3f800001
42 1.000000 3f800001
43 1.000000 3f800001
44 1.000000 3f800001
45 1.000000 3f800001
46 1.000000 3f800001
47 1.000000 3f800001
48 1.000000 3f800001
49 1.000000 3f800001
50 1.000000 3f800001
51 1.000000 3f800001
52 1.000000 3f800001
53 1.000000 3f800001
54 1.000000 3f800001
55 1.000000 3f800001
56 1.000000 3f800001
57 1.000000 3f800001
58 1.000000 3f800001
59 1.000000 3f800001
60 1.000000 3f800001
61 1.000000 3f800001
62 1.000000 3f800001
63 1.000000 3f800001
64 1.000000 3f800001
65 1.000000 3f800001
66 1.000000 3f800001
67 1.000000 3f800001
68 1.000000 3f800001
69 1.000000 3f800001
70 1.000000 3f800001
71 1.000000 3f800001
72 1.000000 3f800001
73 1.000000 3f800001
74 1.000000 3f800001
75 1.000000 3f800001
76 1.000000 3f800001
77 1.000000 3f800001
78 1.000000 3f800001
79 1.000000 3f800001
80 1.000000 3f800001
81 1.000000 3f800001
82 1.000000 3f800001
83 1.000000 3f800001
84 1.000000 3f800001
85 1.000000 3f800001
86 1.000000 3f800001
87 1.000000 3f800001
88 1.000000 3f800001
89 1.000000 3f800001
90 1.000000 3f800001
91 1.000000 3f800001
92 1.000000 3f800001
93 1.000000 3f800001
94 1.000000 3f800001
95 1.000000 3f800001
96 1.000000 3f800001
97 1.000000 3f800001
98 1.000000 3f800001
99 1.000000 3f800001
100 1.000000 3f800001
101 1.000000 3f800001
102 1.000000 3f800001
103 1.000000 3f800001
104 1.000000 3f800001
105 1.000000 3f800001
106 1.000000 3f800001
107 1.000000 3f800001
108 1.000000 3f800001
109 1.000000 3f800001
110 1.000000 3f800001
111 1.000000 3f800001
112 1.000000 3f800001
113 1.000000 3f800001
114 1.000000 3f800001
115 1.000000 3f800001
116 1.000000 3f800001
117 1.000000 3f800001
118 1.000000 3f800001
119 1.000000 3f800001
120 1.000000 3f800001
121 1.000000 3f800001
122 1.000000 3f800001
123 1.000000 3f800001
124 1.000000 3f800001
125 1.000000 3f800001
126 1.000000 3f800001
127 1.000000 3f800001
128 1.000000 3f800001
129 1.000000 3f800001
130 1.000000 3f800001
131 1.000000 3f800001
132 1.000000 3f800001
133 1.000000 3f800001
134 1.000000 3f800001
135 1.000000 3f800001
136 1.000000 3f800001
137 1.000000 3f800001
138 1.000000 3f800001
139 1.000000 3f800001
140 1.000000 3f800001
141 1.000000 3f800001
142 1.000000 3f800001
143 1.000000 3f800001
144 1.000000 3f800001
145 1.000000 3f800001
146 1.000000 3f800001
147 1.000000 3f800001
148 1.000000 3f800001
149 1.000000 3f800000
0 1.500000 3fc00000
1 1.250000 3fa00000
2 1.125000 3f900000
3 1.062500 3f880000
4 1.031250 3f840000
5 1.015625 3f820000
6 1.007813 3f810000
7 1.003906 3f808000
8 1.001953 3f804000
9 1.000977 3f802000
23 1.000000 3f800000
0 1.500000 3fc00000
1 1.250000 3fa00000
2 1.125000 3f900000
3 1.062500 3f880000
4 1.031250 3f840000
5 1.015625 3f820000
6 1.007813 3f810000
7 1.003906 3f808000
8 1.001953 3f804000
9 1.000977 3f802000
0 1.500000 3fc00000
1 1.250000 3fa00000
2 1.125000 3f900000
3 1.062500 3f880000
4 1.031250 3f840000
5 1.015625 3f820000
6 1.007813 3f810000
7 1.003906 3f808000
8 1.001953 3f804000
9 1.000977 3f802000
24 1.500000 3fc00000
25 1.250000 3fa00000
26 1.125000 3f900000
27 1.062500 3f880000
28 1.031250 3f840000
29 1.015625 3f820000
30 1.007813 3f810000
31 1.003906 3f808000
32 1.001953 3f804000
33 1.000977 3f802000
34 1.000488 3f801000
35 1.000244 3f800800
36 1.000122 3f800400
37 1.000061 3f800200
38 1.000031 3f800100
39 1.000015 3f800080
40 1.000008 3f800040
41 1.000004 3f800020
42 1.000002 3f800010
43 1.000001 3f800008
44 1.000000 3f800004
45 1.000000 3f800002
47 1.000000 3f800000
48 1.000000 3f800000
50 1.000000 3f800000
51 1.000000 3f800000
52 1.000000 3f800000
53 1.000000 3f800000
54 1.000000 3f800000
55 1.000000 3f800000
56 1.000000 3f800000
57 1.000000 3f800000
58 1.000000 3f800000
59 1.000000 3f800000
60 1.000000 3f800000
61 1.000000 3f800000
62 1.000000 3f800000
63 1.000000 3f800000
64 1.000000 3f800000
65 1.000000 3f800000
66 1.000000 3f800000
67 1.000000 3f800000
68 1.000000 3f800000
69 1.000000 3f800000
70 1.000000 3f800000
71 1.000000 3f800000
72 1.000000 3f800000
73 1.000000 3f800000
74 1.000000 3f800000
75 1.000000 3f800000
76 1.000000 3f800000
77 1.000000 3f800000
78 1.000000 3f800000
79 1.000000 3f800000
80 1.000000 3f800000
81 1.000000 3f800000
82 1.000000 3f800000
83 1.000000 3f800000
84 1.000000 3f800000
85 1.000000 3f800000
86 1.000000 3f800000
87 1.000000 3f800000
88 1.000000 3f800000
89 1.000000 3f800000
90 1.000000 3f800000
91 1.000000 3f800000
92 1.000000 3f800000
93 1.000000 3f800000
94 1.000000 3f800000
95 1.000000 3f800000
96 1.000000 3f800000
97 1.000000 3f800000
98 1.000000 3f800000
99 1.000000 3f800000
100 1.000000 3f800000
101 1.000000 3f800000
102 1.000000 3f800000
103 1.000000 3f800000
104 1.000000 3f800000
105 1.000000 3f800000
106 1.000000 3f800000
107 1.000000 3f800000
108 1.000000 3f800000
109 1.000000 3f800000
110 1.000000 3f800000
111 1.000000 3f800000
112 1.000000 3f800000
113 1.000000 3f800000
114 1.000000 3f800000
115 1.000000 3f800000
116 1.000000 3f800000
117 1.000000 3f800000
118 1.000000 3f800000
119 1.000000 3f800000
120 1.000000 3f800000
121 1.000000 3f800000
122 1.000000 3f800000
123 1.000000 3f800000
124 1.000000 3f800000
125 1.000000 3f800000
126 1.000000 3f800000
127 1.000000 3f800000
128 1.000000 3f800000
129 1.000000 3f800000
130 101.000000 42ca0000
[/codebox]
Rounding modes describe what you want the implementation to do when the exact answer of an operation does not fit inside the destination format.
In your example, when n=24, 1+1/2^24 is:
1.000000000000000000000001
The two floating-point numbers closest to the exact answer are 1 and 1+2^-23:
1.00000000000000000000001
Which one would you choose as an approximation? It depends on the rounding mode.
  • Rounding “toward negative” (rn) or “toward zero” (rz) will yield the lower bound 1.
  • Rounding “toward positive” (rp) will yield the upper bound 1+2^-23.
  • For Rounding to the nearest: here we have a draw (both FP numbers are equally distant to the exact answer). By convention we select the FP number whose least-significant bit is zero (1.00000000000000000000000).
You eventually reach 1 in RP mode when n=150 because 2^-n cannot be represented as a single-precision floating-point number. Computing it causes an underflow and yields 0 (because your division by 2 uses the default RN mode). So you are actually computing 1+0, which returns 1 as you’d expect.
The behavior of rounding modes on Fermi, or Tesla is no different than on any IEEE-754-compliant CPU. See for instance fesetround() and fegetround() in the C standard library.
Hi All,
I’m back on this problem with precision and floats in CUDA. In my previous post, I was computing a value that could not be represented in IEEE 754-2008 32-bit floats. That produced a NaN, which explains the results I saw. Sylvain Collange, thanks for pointing that out.
However, I now stumbled on an inconsistency in SETP instruction that I cannot explain, and I specifically avoid NaN values. This is very unusual, since the GPU should produce consistent, understandable results.
In my example, I compare two numbers, 1.0 (=0x3f800000) and a number that is 1.0 plus a very small fraction (= 0x3f800001), where fraction = 1/2^50. Note that fraction is 8.8e-16, and is not NaN with 32-bit floats. The number “1.0 plus fraction” is produced two ways. The first way is by computation, 1.0 + 1/2^50 using add.rp.f32. I use TESTP to verify the result of the addition is normal and NaN.
[codebox] // First, create a very small number in register %fraction = 1/2^50.
mov.f32		%fraction, 1.0;
mov.u32		%r0, 0;
mov.u32		%r1, 50;
again:
div.full.f32	%fraction, %fraction, 2.0;
add.u32		%r0, %r0, 1;
setp.ne.u32	%p0, %r0, %r1;
@%p0 bra again;
// Add fraction to 1.0, using "rp" rounding.
// Note, 1.0 = 0x3f800000.
// The result should be 0x3f800001.
mov.f32		%one, 1.0;
add.rp.f32	%one_plus_fraction, %one, %fraction;
[/codebox]
The second method is by loading the hexidecimal equivalent these numbers values into two registers.
[codebox] // Cerate hardwired 1.0, and 1.0 + 1/2^50.
mov.f32		%hardwire_one, 0f3f800000;
mov.f32		%hardwire_one_plus_fraction, 0f3f800001;
[/codebox]
I first compare the values hardwire_one and hardwire_one_plus_fraction using the SETP instruction.
[codebox] // Compare hardwired values.
setp.ne.f32	%cmp_ne_f32_hardwire, %hardwire_one, %hardwire_one_plus_fraction;
setp.ne.b32	%cmp_ne_b32_hardwire, %hardwire_one, %hardwire_one_plus_fraction;
[/codebox]
The values of the two “%cmp_ne_…32_hardwire” registers are both true. In other words, the two numbers are NOT EQUAL, whether compared using .f32 or .b32. This makes sense because if I set up a similar comparison on the CPU, the two numbers are different. And, the bit patterns are different.
Next I compare the two numbers one and one_plus_fraction (the computed value).
[codebox] // Compare using the SETP instruction directly using the f32 registers.
setp.ne.f32	%cmp_ne_f32_directly, %one, %one_plus_fraction;
setp.ne.b32	%cmp_ne_b32_directly, %one, %one_plus_fraction;
[/codebox]
The values of these two “%cmp_ne_…32_directly” comparisons are false! In other words, SETP says two number are THE SAME, whether compared using .f32 or .b32. While I can see that the two numbers are approximately equal give the guard bit (beta = 2, p = 24), the comparison using B32 does not show the bit values are different, when they actual should be different.
Now, you may think that I’m off my rocker: the bit values of the two numbers one and one_plus_fraction are actually the same, because that’s what the GPU says. But, I passed these 32-bit values back to my calling C program via global memory, and verified that the binary values are indeed different, 0x3f800000 and 0x3f800001. In addition, I decided to reload these values from global space into fresh, clean .f32 registers on the GPU. The SETP instruction now says the values are DIFFERENT!!! This is inconsistent. Does anyone have an idea why the GPU is working this way?
(Attached is the source for this little exercise.)
Ken D.
ptx_inst.zip (6.1 KB)
Hi All,
mov.u32		%r0, 0;
mov.u32		%r1, 50;
again:
@%p0 bra again;
mov.f32		%one, 1.0;
[/codebox]
[/codebox]
[/codebox]
[/codebox]
Ken D.
Confirmed with CUDA 3.2RC (on Linux 64). This looks like a compiler bug (likely in a constant propagation phase of ptxas).
Good catch!
Here is the disassembly with nv50dis:
--> Disassembling kernel  SetpFloats with nvc0dis
00000000: 2800440400005d04 l3 mov b32 $r1 c1[0x100]
00000008: 18fe00000001dde2 mov b32 $r7 0x3f800000
00000010: 28004000a0015d04 l3 mov b32 $r5 c0[0x28]
00000018: 189a000000009de2 mov b32 $r2 0x26800000
00000020: 18fe000004021d02 ??? b32 $r8 $r0 0x3f800001 [unknown: 1800000000000100]
00000028: 900000000051dc85 st b32 wb g[$r5+0] $r7
00000030: 900000003051dc05 st u8 wb g[$r5+0xc] $r7
00000038: 5100c9a000701c00 add rp f32 $r0 $r7 0x26800000
00000040: 2800400090019d04 l3 mov b32 $r6 c0[0x24]
00000048: 9000000010509c85 st b32 wb g[$r5+0x4] $r2
00000050: 9000000040521c05 st u8 wb g[$r5+0x10] $r8
00000058: 9000000020501c85 st b32 wb g[$r5+0x8] $r0
00000060: 9000000010609c05 st u8 wb g[$r6+0x4] $r2
00000068: 9000000020601c85 st b32 wb g[$r6+0x8] $r0
00000070: 900000000061dc05 st u8 wb g[$r6+0] $r7
00000078: 900000003061dc85 st b32 wb g[$r6+0xc] $r7
00000080: 9000000040621c05 st u8 wb g[$r6+0x10] $r8
00000088: 8000000000511c85 ld b32 $r4 ca g[$r5+0]
00000090: 800000002050dc05 ld u8 $r3 ca g[$r5+0x8]
00000098: 8000000000509c85 ld b32 $r2 ca g[$r5+0]
000000a0: 8000000020501c05 ld u8 $r0 ca g[$r5+0x8]
000000a8: 2800400080019de4 mov b32 $r6 c0[0x20]
000000b0: 180000000401dd02 ??? b32 $r7 $r0 0x1 [unknown: 1800000000000100]
000000b8: 900000000861dc05 st u8 wb g[$r6+0x2] $r7
000000c0: 900000000c61dc05 st u8 wb g[$r6+0x3] $r7
000000c8: 900000001861dc05 st u8 wb g[$r6+0x6] $r7
000000d0: 900000002061dc05 st u8 wb g[$r6+0x8] $r7
000000d8: 90000000006fdc05 st u8 wb g[$r6+0] $r63
000000e0: 90000000046fdc05 st u8 wb g[$r6+0x1] $r63
000000e8: 900000001c6fdc05 st u8 wb g[$r6+0x7] $r63
000000f0: 90000000246fdc05 st u8 wb g[$r6+0x9] $r63
000000f8: 228e00000c41dc00 set $p0 ne f32 $r4 $r3
00000100: 1a8e00000023dc03 set $p1 ne u32 $r2 $r0
00000108: 2010c00007f01c04 selp b32 $r0 $r63 0x1 not $p0
00000110: 2012c00007f09c04 selp b32 $r2 $r63 0x1 not $p1
00000118: 9000000010601c05 st u8 wb g[$r6+0x4] $r0
00000120: 9000000014609c05 st u8 wb g[$r6+0x5] $r2
00000128: 8000000000001de7 exit
Instructions at 000000d8 and 000000e0 store directly the precomputed value 0 at __B[0] and __B[1]. This is wrong, the expected result is 1.
Just to nitpick, it was an underflow which produced a zero as a result of the division, rather than a NaN. NaNs are used for mathematically undefined operations, such as 0×Infinity or square root of a negative number.
Good catch!
Sorry, I am a bit lost as to what we are trying to figure out here. The .rn, .rz, .rp, .rm suffixes correspond to the standard four IEEE-754 rounding modes round-to-nearest-or-even, round-towards-zero, round-towards-plus-infinity, round-towards-minus-infinity. On sm_20 hardware, these rounding modes are supported for single-precision adds and multiplies, among other operations. If we add increasingly small, non-zero, positive fractions to 1.0f, we expect the result to eventually become 1.0f (0x3f800000) for .rn, .rz, and .rm. We expect the result to become 1.0f + 1ulp (0x3f800001) for .rp. When I tried the .rp case mentioned above with the program below, things work just fine. The program prints: result = 1.000000119e+000 (3f800001) on my C2050 machine. [NOTE: inline PTX is not a supported feature].
CUDA offers device functions (intrinsics) that give access to basic arithmetic operations as well as various conversions with all four IEEE rounding modes, and I would highly recommend using these device functions instead of using PTX. For single-precision addition the relevant device functions are:
__fadd_rn() // corresponds to add.rn.f32, “n = nearest”
__fadd_rz() // corresponds to add.rz.f32, “z = zero”
__fadd_rd() // corresponds to add.rm.f32, “d = down”
__fadd_ru() // corresponds to add.rp.f32, “u = up”
#include <stdlib.h>
// Macro to catch CUDA errors in CUDA runtime calls
#define CUDA_SAFE_CALL(call) \
do { \
cudaError_t err = call;                                           \
if (cudaSuccess != err) {                                         \
    fprintf (stderr, "Cuda error in file '%s' in line %i : %s.\n",\
             __FILE__, __LINE__, cudaGetErrorString(err) );       \
    exit(EXIT_FAILURE);                                           \
} while (0)
// Macro to catch CUDA errors in kernel launches
#define CHECK_LAUNCH_ERROR() \
do { \
/* Check synchronous errors, i.e. pre-launch */                   \
cudaError_t err = cudaGetLastError();                             \
/* Check asynchronous errors, i.e. kernel failed (ULF) */         \
err = cudaThreadSynchronize();                                    \
             __FILE__, __LINE__, cudaGetErrorString( err) );      \
} while (0)
static unsigned floatAsUInt(float x)
volatile union {
    float f;
    unsigned i;
} xx;
xx.f = x;
return xx.i;
device forceinline float fadd_rp (void)
float res;
asm (" .reg .u32 iter, maxiter;\n"
     "        .reg .f32 fraction, one, one_plus_fraction;\n"
     "        .reg .pred noteq;\n"
     "        mov.f32         fraction, 1.0;\n"
     "        mov.u32         iter, 0;\n"
     "        mov.u32         maxiter, 50;\n"
     "$again: div.full.f32	  fraction, fraction, 2.0;\n"
     "        add.u32	  iter, iter, 1;\n"
     "        setp.ne.u32     noteq, iter, maxiter;\n"
     "@noteq  bra             $again;\n"
 "        mov.f32	  one, 1.0;\n"
     "        add.rp.f32	  one_plus_fraction, one, fraction;\n"
     "        mov.f32         %0, one_plus_fraction;\n"
     : "=f"(res)
return res;
global void fadd_rp_kernel (float *result)
*result = fadd_rp();
int main (void)
float res;
float *res_d;
CUDA_SAFE_CALL (cudaMalloc ((void**)&res_d, sizeof(res_d[0])));
fadd_rp_kernel<<<1,1>>>(res_d);
CHECK_LAUNCH_ERROR();
CUDA_SAFE_CALL (cudaMemcpy (&res, res_d, sizeof(res_d[0]),
                            cudaMemcpyDeviceToHost));
CUDA_SAFE_CALL (cudaFree (res_d));
printf ("result = %16.9e (%08x)\n", res, floatAsUInt(res));
return EXIT_SUCCESS;
}[/codebox]
#include <stdlib.h>
do { \
} while (0)
do { \
} while (0)
volatile union {
    float f;
    unsigned i;
} xx;
xx.f = x;
return xx.i;
float res;
     : "=f"(res)
return res;
int main (void)
float res;
float *res_d;
}[/codebox]
It looks like I have a simple repro for the second issue discussed here, and it seems to be a problem inside PTXAS, as Sylvain diagnosed. I will file a compiler bug. If I compile the attached program with -Xptxas -O0 or -Xptxas -O1, it prints “one .ne. one_plus_fraction = 1”, as expected. However, if I compile with -Xptxas -O2 instead it prints “one .ne. one_plus_fraction = 0”. Thanks for bringing this issue to our attention.
#include <stdlib.h>
do { \
} while (0)
do { \
} while (0)
device forceinline int fadd_rp (void)
int res;
asm (“.reg .u32 iter, maxiter;\n\t”
     ".reg .f32 fraction, one, one_plus_fraction;\n\t"
     ".reg .pred noteq;\n"
     "        setp.ne.f32     noteq, one, one_plus_fraction;\n"
     "        selp.u32        %0, 1, 0, noteq;\n"
     : "=r"(res)
return res;
global void fadd_rp_kernel (int *result)
int main (void)
int res;
int *res_d;
printf ("one .ne. one_plus_fraction = %d\n", res);
}[/codebox]
#include <stdlib.h>
do { \
} while (0)
do { \
} while (0)
int res;
     : "=r"(res)
return res;
int main (void)
int res;
int *res_d;
}[/codebox]
Sorry for the confusion. I wasn’t sure what was the cause of the problem with SETP–the instruction or the operands–thus placed the follow-up message on this thread. I’m now much clearer how rounding of floats work in PTX. Thank you all for your explanations.
What is new to me is that PTXAS is not a translator that converts one PTX instruction into one machine instruction, but more like a compiler. After looking at the output of nv50dis, it’s just amazing to see how much of my PTX example was rewritten. The loop to compute %faction is gone! Since I’m writing tests for each PTX instruction I implement in my emulator, I’ll be sure to follow it up with a peek at the disassembled machine code from now on, if I see something unusual.
Ken D.
Ken D.
