Do we have a way to predicate how much device memory is consumed per device context creation at least?
Below is the output of nvidia-smi in my environment.
The first process create a device context but has no actual workload, thus it never called cuMemAlloc().
However, it consumes 75MB on the device side.
Other processes are workers. Every worker allocated 171MB using cuMemAlloc().
However, they consumed 352MB on the device side for each.
My question is:
Do we have a way to predicate how much device memory is consumed per device context creation?
Do we have a way to predicate how much device memory is “actually” consumed on cuMemAlloc()?
Do we have a way to reduce these extra usage of device memory?
I’m not sure about the initial cost of context creation/overhead. But once these are instantiated, the differential cost to allocate more memory of reasonable size in one allocation should be approximately the size of that allocation. For example, in your “worker” processes which are currently using ~350MB, if you then allocate an additional 100MB, you should see that process use about ~450MB instead.
Run everything in a single process. This has additional benefits from a scheduling and latency perspective, when sharing a GPU like this. You might also try experimenting with CUDA-MPS if you are not already using it, but I don’t know if it would impact memory usage in this case:
Unfortunately, this option is not possible to adopt, because PostgreSQL uses multi-process model and my software works as an extension of PostgreSQL. It is not reasonable choice to rewrite entire PostgreSQL for multi-threading model.
Thanks for your information. I didn’t know about CUDA-MPS.
However, here are two unignorable limitations for me.
Dynamic parallelism is not supported.
Stream callbacks are not supported.
If this proxy-like architecture could solve the implicit device memory consumption problem, it is an idea to implement own proxy feature that proxies GPU kernel call from other worker processes.
However, result of my small test implies this approach will not solve the problem, because multiple GPU context in a process also consumes same amount of device memory when individual processes made a GPU context per context.
It is not an option to share a particular GPU context by multiple workers because a device error by a particular worker process will break on-device status of other worker processes.
I like to know what is the reason of this not small device memory consumption…
#include <stdio.h>
#include <cuda.h>
int main(int argc, const char *argv[])
CUdevice device;
CUcontext context;
CUdeviceptr dptr;
int i, status;
cuInit(0);
cuDeviceGet(&device,0);
while (cuCtxCreate(&context, 0, device) == CUDA_SUCCESS)
printf("create one GPU context\n");
sleep(2);
printf("no more GPU context\n");
return 0;
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 59879 C ./a.out 3775MiB |
Mon Mar 28 15:50:43 2016
| NVIDIA-SMI 352.79 Driver Version: 352.79 |
| 0 GeForce GTX 980 Off | 0000:02:00.0 Off | N/A |
| 33% 36C P2 40W / 180W | 3972MiB / 4095MiB | 0% Default |
| 1 Tesla K20c Off | 0000:04:00.0 Off | 0 |
| 30% 35C P8 27W / 225W | 12MiB / 4799MiB | 0% Default |
| 0 59879 C ./a.out 3929MiB |
The first example (case of postgresql extension) linked libcudadevrt.a, however, the small program above never linked any CUDA libraries. It just called cuCxtCreate() via driver API, however, each context consumed about 60MB-70MB for each.
That sounds about right. When I had to size this for an automated regression test framework that needed to work across numerous different devices and CUDA versions and ran across a pool of hundreds of systems, I conservatively assumed 90 MB per context (when using the runtime, not the driver interface). I do not recall ever running into trouble with that estimate. CUDA context memory consumption has been quite stable for years, so unlikely to either decrease or increase drastically.
My recommendation is to accept this “context overhead” as a fact of life, and simply deploy GPUs with sufficiently large memory. Devices with 4 GB of memory are fairly affordable these days.
It looks to me a better design is to launch a CUDA proxy server and create a certain number of CUDA contexts preliminary, then attach each worker with a particular CUDA context on demand at the proxy server side, not creating CUDA context individual workers.
It will make error handling a bit complicated, but we can also expect performance and concurrency benefit.
