I have problems with the sqrt precision on OpenCL kernel. For instance sqrt( 14400.0f ) seems to return 120.000008. The error is not a big one but later it expands. Is there any flag or precision qualifier to give more accuracy? GPU is GeForce 8600 GT.
Floating point numbers are represented in base 2, so displaying such a number in base 10 is not always possible in 7 digits or less. (For example, 1 + 2**-22 can be represented exactly in single precision, but requires a lot more than 7 digits to represent exactly in base 10.) The fractional distance between one floating point number and the next one is approximately 10^-7, which is where the 7 significant digit rule of thumb comes from.
[edited later to reflect that the information is specific to the single-precision variant of native_sqrt()]
Thanks for alerting us to this documentation issue. Table C-2 and section C.2 incorrectly state that native_sqrt() maps to a square root with IEEE rounding. In fact the single-precision variant of the function maps to the PTX instruction sqrt.approx.f32, that is, an approximate square root satisfying the accuracy bound of <= 3 ulps set forth in the OpenCL specification. I will follow up with our documentation team.
