I would like to flash a DTB.
I did two tests:
- (re)flash the "/boot/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb" found on my TX2: OK
- flash an extracted DTB from "/proc/device-tree/": KO, the TX2 is not booting anymore
# Extract device tree directly fom my TX2
$ sudo dtc -I fs -O dts -o extracted.dts /proc/device-tree
I have a lot of warnings “no-unit_address_vs_reg” (ignored by “-W no-unit_address_vs_reg” option) but I still have these warnings left:
extracted_proc.dts: Warning (pci_bridge): Node /pcie-controller@10003000 node name is not "pci" or "pcie"
extracted_proc.dts: Warning (pci_bridge): Node /pcie-controller@10003000/pci@2,0 missing bus-range for PCI bridge
extracted_proc.dts: Warning (pci_bridge): Node /pcie-controller@10003000/pci@1,0 missing bus-range for PCI bridge
extracted_proc.dts: Warning (pci_bridge): Node /pcie-controller@10003000/pci@3,0 missing bus-range for PCI bridge
extracted_proc.dts: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
extracted_proc.dts: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
extracted_proc.dts: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
extracted_proc.dts: Warning (simple_bus_reg): Node /mods-simple-bus/mods-clocks missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@200 simple-bus unit address format error, expected "c8"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@18 simple-bus unit address format error, expected "12"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@16 simple-bus unit address format error, expected "10"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@14 simple-bus unit address format error, expected "e"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@12 simple-bus unit address format error, expected "c"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@10 simple-bus unit address format error, expected "a"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@17 simple-bus unit address format error, expected "11"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@15 simple-bus unit address format error, expected "f"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@101 simple-bus unit address format error, expected "65"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@13 simple-bus unit address format error, expected "d"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@11 simple-bus unit address format error, expected "b"
extracted_proc.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@118 simple-bus unit address format error, expected "76"
extracted_proc.dts: Warning (simple_bus_reg): Node /external-connection/disp-state missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx3 missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx1 missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/dsi simple-bus unit address format error, expected "15300000"
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/sor1 simple-bus unit address format error, expected "15580000"
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/dc_common simple-bus unit address format error, expected "15200000"
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx6 missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx4 missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/sor simple-bus unit address format error, expected "15540000"
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx2 missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx0 missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/disp_imp_table missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx7 missing or empty reg/ranges property
extracted_proc.dts: Warning (simple_bus_reg): Node /host1x/ctx5 missing or empty reg/ranges property
extracted_proc.dts: Warning (gpios_property): Missing property '#gpio-cells' in node /cpus/cpu@0 or bad phandle (referred from /eeprom-manager/bus@3/eeprom@0:enable-gpio[0])
extracted_proc.dts: Warning (gpios_property): Missing property '#gpio-cells' in node /cpus/cpu@0 or bad phandle (referred from /eeprom-manager/bus@3/eeprom@1:enable-gpio[0])
extracted_proc.dts: Warning (gpios_property): Missing property '#gpio-cells' in node /clock@5000000 or bad phandle (referred from /plugin-manager/fragment-comms-a00-chip/override@1/_overlay_/wifi-wake-ap:gpios[0])
extracted_proc.dts: Warning (gpios_property): Missing property '#gpio-cells' in node /energy-costs/core-cost1 or bad phandle (referred from /plugin-manager/fragment-comms-a00-chip/override@1/_overlay_/wifi-enable:gpios[0])
# Convert DTS to DTB
$ dtc -I dts -O dtb -o extracted.dtb extracted.dts
# Flash it from my PC
$ cd ~/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/
$ cp extracted.dtb kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb
$ sudo ./flash -k kernel-dtb jetson-tx2 mmcblk0p1
What’s wrong? Thanks for your help.
