Greetings PGI,
I am trying to launch Matrix Multiplication kernel from different CPU cores to GPU (K20c).
I want all the CPU threads first copy data to GPU memory, sync and then launch the kernel all at the same time. Here is the code:
#include <math.h>
#include <sys/time.h>
#include <stdlib.h>
#include <stdio.h>
#include <omp.h>
int main(int argc, char *argv[])
if(argc != 3) {
fprintf(stderr,"Use: %s size nIter\n",argv[0]);
return -1;
int Dim=atoi(argv[1]);
int itr=atoi(argv[2]);
if(itr <= 0) {
fprintf(stderr,"%s: Invalid nIter (%d)\n",argv[0],itr);
return -1;
omp_set_num_threads(itr);
#pragma omp parallel
int i=0,j=0,k=0,c=0,d=0;
float Matrix1[Dim][Dim], Matrix2[Dim][Dim],Result_ACC[Dim][Dim],Result_OMP[Dim][Dim],Diff=0,sum=0;
double tstart, tstop;
for (i=0;i<Dim;i++){
for(j=0;j<Dim;j++){
Result_ACC[i][j]=0;
Result_OMP[i][j]=0;
Matrix1[i][j]=((float)(rand()%50)/15);
Matrix2[i][j]=((float)(rand()%70)/17);
#pragma acc data pcopyin(Dim,Matrix1[0:Dim][0:Dim], Matrix2[0:Dim][0:Dim])
#pragma omp barrier
tstart = omp_get_wtime();
#pragma acc kernels loop create(Result_ACC[0:Dim][0:Dim],sum)
for (c = 0; c < Dim; c++) {
for (d = 0; d < Dim; d++) {
sum = 0;
for (k = 0; k < Dim; k++) {
sum = sum + Matrix1[c][k]*Matrix2[k][d];
Result_ACC[c][d] = sum;
tstop = omp_get_wtime();
printf ("Thread %d: %G seconds on GPU.\n",omp_get_thread_num(), tstop-tstart);
return 0;
As you can see, I first copy all the data to GPU ( #pragma acc data pcopyin(Dim,Matrix1[0:Dim][0:Dim], Matrix2[0:Dim][0:Dim])) , then sync all the threads (#pragma omp barrier) and start my timer. When I compile the code I get PGC-F-0155-Illegal context for barrier (main.c: 41) error.
What I am doing here is taking the data transfer overhead off my timing calculation and making sure that all threads launch the kernels at the same time.
Basically I am trying to figure out how the kernel scheduler works. If it runs all the kernels from CPU threads in parallel? Specifically, I am interested to know how the gangs and vectors are mapped to SMX. Any reference on details on kernel scheduling would be a great help.
Thanks a bunch,
Ali
