Hello everybody, sorry for my english. I’m spanish.
Well, I have a problem inside a kernel. Imagine the following kernel:
__global__ test (... float *res, int size1, int size2 ...)
int tam= size1 + size2;
float vector[tam];
// Make things with vector and store the result in res for example
I want to create a vector of size tam (sum of different sizes that change) but I get the following error: expression must have a constant value.
I can’t use constant or const before its declaration, so which is the best thing to do it?
Thanks a lot!
Greetings
