Hi!
Can someone help me with this code.I am getting overflow in 139 line(copy to GPU)?
Can someone show me where is problem and how ti fix it?
Here is code:
#define MAXSIZE 250000
#include
#include
#include //Writing to files
#include //Keep track of time
#include <cuda.h>
#include <cuda_runtime_api.h>
#include <cuda_runtime.h>
// to remove intellisense highlighting
#include <device_launch_parameters.h>
#ifndef CUDACC
#define CUDACC
#endif
#include
#include “device_launch_parameters.h”
using namespace std::chrono;
int data[MAXSIZE];
//Main CUDA kernel implementing Sieve of Eratosthenes
global static void CUDASieve(int num, int range, int bNum, int tNum){
const int threadId = threadIdx.x;
const int blockId = blockIdx.x;
int tmp = blockIdtNum + threadId;
while (tmp < range){
int i = 1;
while (((2 * tmp + 3)*i + tmp + 1) < MAXSIZE){
num[(2 * tmp + 3)*i + tmp + 1] = 0;
i++;
tmp += bNum * tNum;
void CUDAFilter(int *number, int size){
for (int i = 0; i<size; i++)
number[i] = 2 * i + 1;
number[0] = 2;
void reportTime(const char* msg, steady_clock::duration span) {
auto ms = duration_cast(span);
std::cout << msg << ms.count() << " millisecs" << std::endl;
void CPUgenPrime(uint64_t range, bool mode, std::ofstream &fileOut) {
//Start the clock
steady_clock::time_point ts, te;
ts = steady_clock::now();
fileOut << “\nCPU version\n” << “\nCPU version generating from range (0” << “~” << range << “)\n\n”;
//Keep track of results
uint64_t count = 0;
//Outer loop
for (uint64_t i = 0; i < range; i++)
//Inner loop
for (uint64_t j = 2; j*j <= i; j++) {
if (i % j == 0)
break;
else if (j + 1 > sqrt(i)) {
//User wants to see output on screen
if (mode) {
std::cout << std::fixed << i << “\t”;
fileOut << std::fixed << i << “\t”;
count++;
//Just write to file if mode is 0
else
count++;
//Stop the clock
te = steady_clock::now();
std::cout << "\n\nTotal number of primes: " << count << std::endl;
reportTime("\nCPU Program Completed in ", te - ts);
fileOut << "\n\nTotal number of primes: " << count << std::endl;
std::cout << "A log file with the current date/time has been placed in the program directory.\n";
std::cout << "--------------------------------------------------------------------------------\n";
std::ofstream fileInit(){
//Get current date and time
time_t rawtime;
struct tm * timeinfo;
char buffer[80];
time(&rawtime);
timeinfo = localtime(&rawtime);
//Format in Year-Month-Day_Hour_Minute_Seconds
strftime(buffer, 80, "%y-%m-%d_%H-%M-%S", timeinfo);
std::string dateTime(buffer);
//File handles
std::ofstream fileOut;
fileOut.open("GenPrime_out_" + dateTime + ".txt");
return fileOut;
int setupRange(int range) {
if (range == 0) {
std::cout << “[2/3] Please choose the range(3 ~ 500,000): \n”;
std::cin >> range;
//Error checking
if (range > 2 && range <= 500000) {
return range;
else {
std::cout << "Invalid input for range, value set to default 500,000\n";
return 500000;
else return range;
//Array of MAXSIZE is created and filled with prime numbers, where [i]
//is the prime int and the rest is padded with 0’s
//Example: cpudata[i] = {0,1,0,3,0,5,0,7,0,0,0,11,0,0,0…}
void justDoIt(int range, bool mode, std::ofstream& fileOut) {
//Output to file
fileOut << “CUDA Multithreading Sieve of Eratosthenes\n” << “CUDA Multithreading generating from range (0” << “~” << range << “)\n\n”;
//Filter out even numbers to simplify calculation
CUDAFilter(data, (range / 2) + 1);
//Initialize arrays
int *gpudata;
int cpudata[MAXSIZE];
//Allocate memory
cudaMalloc((void**)&gpudata, sizeof(int)*MAXSIZE);
//Copy to GPU
cudaMemcpy(gpudata, data, sizeof(int)*MAXSIZE, cudaMemcpyHostToDevice);
//Maximum threads per block for CUDA 5.2 is 1024
int bNum = 96, tNum = 1024;
//Start the clock
ts = stead_clock::now();
//Kernel call on the GPU
CUDASieve << <bNum, tNum, 0 >> >(gpudata, range, bNum, tNum);
//Synchronize the device and the host
cudaDeviceSynchronize();
//Copy from GPU back onto host
cudaMemcpy(&cpudata, gpudata, sizeof(int)*MAXSIZE, cudaMemcpyDeviceToHost);
//Free the memory on the GPU
cudaFree(gpudata);
//Reset the device for easy profiling
cudaDeviceReset();
//Stop the clock
//Display on screen
if (mode == 1) {
for (int i = 0; i < MAXSIZE; i++) {
if (cpudata[i] != 0)
printf("%d\t", cpudata[i]);
//Count number of primes
int count = std::count_if(cpudata, cpudata + MAXSIZE, [](int i){ return i; });
std::cout << "\n\nTotal number of primes: " << count-2 << std::endl;
//Write to file
if (cpudata[i] != 0) {
fileOut << cpudata[i] << "\t";
//Show the amount of time
reportTime("GPU Program Completed in ", te - ts);
fileOut << "\n\nTotal number of primes: " << count - 2 << std::endl;
void menu(int range, bool mode, std::ofstream& fileOut){
std::cout << “[3/3] Please select the version of the program you want to run\n”
<< “1. [] CUDA Multithreading Sieve of Eratosthenes version\n"
<< "2. [] Simple CPU version\n"
<< "3. [] Run both versions\n”
<< “0. Quit\n”
<< "Option: ";
int mainMenuOption;
std::cin >> mainMenuOption; //Accept user input
switch (mainMenuOption) {
case 0: // User wants to exit
break;
case 1:
std::cout << “CUDA Multithreading generating from range (0” << “~” << range << “)\n”;
std::cout << “--------------------------------------------------------------------------------\n”;
justDoIt(range, mode, fileOut);
//Close the file handle
fileOut.close();
break;
case 2:
std::cout << "CPU version generating from range (0" << "~" << range << ")\n";
CPUgenPrime(range, mode, fileOut);
fileOut.close();
break;
case 3:
std::cout << "Running all available options\n";
fileOut.close();
break;
default:
std::cout << "[Invalid option. Only integers 0-3 are allowed]\n";
menu(range, mode, fileOut);
break;
void setupScreenMode(int range) {
std::cout << “Team /dev/null GPU610 PRIME NUMBER GENERATOR v3.5\n”
<< “[1/3] Would you like to see the output on screen?\n”
<< “0 = NO, write to file only\n”
<< “1 = YES, display on screen\n”
<< "Show on screen?: ";
int mode = 1;
std::cin >> mode;
//Initialize file handle
std::ofstream fileOut = fileInit();
if (mode == 0) {
std::cout << "***Writing output to file only***\n\n";
range = setupRange(range);
else if (mode == 1) {
std::cout << "***Outputting results on screen***\n\n";
else {
std::cout << "[Invalid option selected, default option 0 (output to screen) selected]\n\n";
menu(range, 1, fileOut);
//Initialize value to be used in the program using command line arguments
int initRuntimeValue(int argc, char* argv){
//Save runtime parameter into local variable, if provided
int range = 500000;
if (argc == 1) {
std::cout << “[No command line parameters provided]\n\n”;
return 0;
if (argc == 2)
range = std::atoi(argv[1]);
if (range > 2 && range < 500000)
return range;
else {
std::cout << “[Bad input for range parameter (must be <= 500,000)]\n”
<< “Range has been set to 500,000\n”;
return range = 500000;
int main(int argc, char* argv) {
//Grab the command line arguments
int range = initRuntimeValue(argc, argv);
return 0;
