Problem with cudaMemcpyToSymbol
I’m trying to execute this program, but when it execute the cudaMemcpyToSymbol I got this message"invalid device symbol". A piece of code has been copied.
In the Header
typedef struct{
	unsigned short ordre;
	double coefficient[FIRCOEFFSIZE];
	unsigned short inputLength;
}FILTRE;
In the .cu
a Part of Main
static __device__ __constant__ FILTRE GPUcoeff;
FILTRE filtre;
	filtre.ordre = FIRCOEFFSIZE;
	filtre.coefficient[0] = 1;
	filtre.inputLength = SHAPEDLEN+(DELAY*2);
	matchedFilter(dataQ, &filtre, &fs, dimBlock, dimGrid);
a Part of matchedFilter function
void matchedFilter(double *shaped, FILTRE* fir1, double *fs, dim3 dimBlock, dim3 dimGrid)
	//Declaration of GPU's variable in ****
	double *GPUShape;
	double *GPUFs;
	//Load data in GPU's constant memory
	cutilSafeCall(cudaMemcpyToSymbol("GPUcoeff", &fir1, sizeof(FILTRE)));
Is the symbol declared in the same compilation unit as the function call? If it isn’t, you to refactor your code or add a wrapper function to get the access to symbol, because all symbols have to be defined in the same compiation unit where they are used. Also, you are missing a couple for arguments in the call itself - as per here there has to be an offset and direction arguments supplied.
Thank you for your help, but I found my problem. I replace the flag argument -arch=compute_13 by -arch=compute_20.
have a good day! External Image
