Hi All,
i am trying to get an Nvidia K2 grid card running on XenServer 6.5. XenServer is installed on a supported Supermicro hardware. Recommanded BIOS settings (disable 4G etc.)are also configured.
The installation of the vGPU manager, version 346.68, was successful.
In XenCenter under Server-> GPU i can see the vGPU types, but im not able to edit the vGPUs and i´m also not able to add an vGPU to a VM. Assigning the whole GPUs to an VM works without problems.
The vGPU Manager is loaded. Below some outputs from the xenserver shell.
Any suggestions? Any ideas?
Type "xsconsole" for access to the management console.
[root@demo-xen-hdx3d ~]# nvidia-smi
Fri Oct 2 20:12:40 2015
| NVIDIA-SMI 346.68 Driver Version: 346.68 |
| 0 GRID K2 On | 0000:05:00.0 Off | Off |
| N/A 36C P8 29W / 117W | 11MiB / 4095MiB | 0% Default |
| 1 GRID K2 On | 0000:06:00.0 Off | Off |
| N/A 32C P8 27W / 117W | 11MiB / 4095MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
[root@demo-xen-hdx3d ~]# lsmod | grep nvidia
nvidia 8375444 14
[root@demo-xen-hdx3d ~]# xe gpu-group-list
uuid ( RO) : 1a4081c0-5dc4-d309-e2ad-5dee489b87be
name-label ( RW): Group of Matrox Electronics Systems Ltd. MGA G200eW WPCM450 GPUs
name-description ( RW):
uuid ( RO) : 955f7abf-3bfd-8582-bcd9-9204a324f632
name-label ( RW): Group of NVIDIA Corporation GK104GL [GRID K2] GPUs
[root@demo-xen-hdx3d ~]# xe vgpu-list
Regards
Sascha
