hi everyone
i have this program that does not do much, not taking into account that it does not want to compile. i have been figting with it for the past four or so hours and it just wont budge. perhaps someone here can tell a noob like what in the world am i doing wrong as i am sick and tired of it by now!!
[codebox]///////////////////////////////////////////////////////////////////////////////
// Name: fft_qpskDemod.cu
// Copyright: NUI Maynooth
// Author: Isa Iminov
// Date: 27/07/09
// Description:
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <cutil.h>
#include <cutil_inline.h>
#include <cufft.h>
//#include “kernel_fft_qpskDemod.cu”
//#include “structures.h”
// Name: structures.h
// Date: 17/07/09
// Description: Declaration of global types
#ifndef STRUCTURES_H
#define STRUCTURES_H
// Global types
typedef struct {
float real;
float imag;
} Complex;
#endif
// Name: kernel_fft_qpskDemod.cu
// Date: 27/07/09
// Description:
#ifndef KERNEL_QPSK2D_CU
#define KERNEL_QPSK2D_CU
// Global types
// Kernel that copies real data to complex data
global void real2complex( Complex *d_b, cufftComplex *c, int R, int C ) {
// Compute index for RxC array/data structure
int ix = blockIdx.x * blockDim.x + threadIdx.x; // row of threads (single channel)
//int iy = blockIdx.y * blockDim.y + threadIdx.y;
//int idx = ix + iy * N;
// Perform operation
/*if ( ix < R && iy < C ) {
c[idx].x = d_b[idx].real;
c[idx].y = d_b[idx].imag;
} // end if
for ( int iy = 0; iy < R; iy++ ) {
c[ iy*C + ix ].x = d_b[ iy*C + ix ].real;
c[ iy*C + ix ].y = d_b[ iy*C + ix ].imag;
} // end for
} // end real2complex
// Kernel that copies complex data to real data
global void complex2real( cufftComplex *c, Complex *d_b, int R, int C ) {
/*if ( idx < N && idy < N ) {
d_b[idx].real = c[idx].x;
d_b[idx].imag = c[idx].y;
} // end if
d_b[ iy*C + ix ].real = c[ iy*C + ix ].x;
d_b[ iy*C + ix ].imag = c[ iy*C + ix ].y;
} // end for
} // end complex2real
// Kernel that performs QPSK 2D mapping in global memory
global void qpskModul( float *d_a, Complex *Lookup_d, Complex *d_b, int R, int C ) {
// Perform mapping
/*if ( ix < N && iy < N ) {
d_b[ idx ].real = Lookup_d[ ( int )d_a[ idx ] ].real;
d_b[ idx ].imag = Lookup_d[ ( int )d_a[ idx ] ].imag;
} // end if
d_b[ iy*C + ix ].real = Lookup_d[ ( int )d_a[ iy*C + ix ] ].real;
d_b[ iy*C + ix ].imag = Lookup_d[ ( int )d_a[ iy*C + ix ] ].imag;
} // end for
} // end qpskModul
global void qpskDemod( float *d_a, Complex *Lookup_d, Complex *d_b, int R, int C ) {
// Perform demapping
if ( d_b[ idx ].real == -sqrt( 2.0 ) ) {
if ( d_b[ idx ].imag == -sqrt( 2.0 ) ) d_a[ idx ] = 0;
else d_a[ idx ] = 2;
} // end if
else {
if ( d_b[ idx ].imag == sqrt( 2.0 ) ) d_a[ idx ] = 3;
else d_a[ idx ] = 1;
} // end else
} // end if
if ( d_b[ iy*C + ix ].real == -sqrt( 2.0 ) ) {
if ( d_b[ iy*C + ix ].imag == -sqrt( 2.0 ) ) d_a[ iy*C + ix ] = 0;
else d_a[ iy*C + ix ] = 2;
} // end if
else {
if ( d_b[ iy*C + ix ].imag == sqrt( 2.0 ) ) d_a[ iy*C + ix ] = 3;
else d_a[ iy*C + ix ] = 1;
} // end else
} // end for
} // end qpskDemod
#endif
// Main program
#define DO_CPU
#undef DO_CPU
#define DO_GPU
//#undef DO_GPU
int main( int argc, char **argv ) {
printf( “fft and QPSK demod program for a 2D matrix…\n” );
printf( “=============================================\n” );
// Create timers
printf( “Initialising timers…\n” );
unsigned int timer1, timer2, timer3, timer4 = 0;
cutCreateTimer( &timer1 ); // CPU timer
cutCreateTimer( &timer2 ); // GPU timer
cutCreateTimer( &timer3 ); // cudaMemcpy timer 1
cutCreateTimer( &timer4 ); // cudaMemcpy timer 2
// Initialise memory
printf( “Initialising memory…\n” );
const int R = 256; // make a big array with RxC elements
const int C = 128; // where R = row (channel), C = col (channel elements)
float *a_h; // host data
Complex *b_h, *Lookup; // host data structures
a_h = ( float * )malloc( sizeof( float )RC ); // allocate array on host
b_h = ( Complex * )malloc( sizeof( Complex )RC ); // allocate structure on host
Lookup = ( Complex * )malloc( sizeof( Complex )*4 ); // allocate structure on host
float *a_d; // device data
Complex *b_d, *Lookup_d; // device data structures
cudaMallocHost( ( void ** ) &a_d, sizeof( float )RC ); // allocate array on device
cudaMallocHost( ( void ** ) &b_d, sizeof( Complex )RC ); // allocate structure on device
cudaMallocHost( ( void ** ) &Lookup_d, sizeof( Complex )*4 ); // allocate structure on device
cufftComplex *r_complex_d;
cudaMallocHost( (void **) &r_complex_d, sizeof(cufftComplex)RC);
// Initialize host array
printf( “Initialising data matrix…\n” );
unsigned int data = 0xf01919c6; // randome 4byte worth of data
unsigned int mask = 0x00000003; // bit mask
unsigned int temp = 0x00000000; // temporary storage
for ( int i = 0; i < R; i++ ) {
for ( int j = 0; j < C; j++ ) {
temp = data & mask;
a_h[ i*C + j ] = ( int )temp;
data = data >> 2;
} // end for
} // end for
// Initialise lookup table
printf( “Initialising lookup table…\n” );
Lookup[ 0 ].real = -sqrt( 2.0 ); Lookup[ 0 ].imag = -sqrt( 2.0 );
Lookup[ 1 ].real = sqrt( 2.0 ); Lookup[ 1 ].imag = -sqrt( 2.0 );
Lookup[ 3 ].real = sqrt( 2.0 ); Lookup[ 3 ].imag = sqrt( 2.0 );
Lookup[ 2 ].real = -sqrt( 2.0 ); Lookup[ 2 ].imag = sqrt( 2.0 );
printf( "\nPerforming cuda memory copy operation… " );
cutStartTimer( timer3 ); // start cudaMemcpy timer 3
cudaMemcpy( Lookup_d, Lookup, sizeof( Complex )*4, cudaMemcpyHostToDevice );
cutStopTimer( timer3 ); // stop cudaMemcpy timer 3
printf( " %f ms\n", cutGetTimerValue( timer3 ) );
cutResetTimer( timer3 );
#ifdef DO_CPU
// Do calculation on host
printf( “Performing QPSK 2D operation on CPU…\n” );
cutStartTimer( timer1 ); // start CPU timer
b_h[ i*C + j ] = Lookup[ ( int )a_h[ i*C + j ] ];
} // end for
} // end for
cutStopTimer( timer1 ); // stop CPU timer
#endif
#ifdef DO_GPU
// Do calculation on device
cutStartTimer( timer2 ); // start GPU timer
printf( "Performing cuda memory copy operation… " );
cutStartTimer( timer3 ); // start cudaMemcpy timer 1
cudaMemcpy( a_d, a_h, sizeof( float )RC, cudaMemcpyHostToDevice );
cutStopTimer( timer3 ); // stop cudaMemcpy timer 1
printf( “Initialising plan for CUDA fft…\n” );
cufftHandle plan;
cufftPlan2d( &plan, R, C, CUFFT_C2C);
printf( “Computing execution configuration…\n” );
int block_size_x = 16; // # of threads per block = x*y
int block_size_y = 32; // upto max of 512
dim3 blockDim( block_size_x, block_size_y ); // block size in threads
dim3 gridDim ( R/blockDim.x, C/blockDim.y ); // grid size in bloack
printf( “Performing configuration check…\n” );
if ( R % block_size_x != 0 ) gridDim.x += 1;
if ( C % block_size_y != 0 ) gridDim.y += 1;
qpskModul <<< gridDim, blockDim >>> ( a_d, Lookup_d, b_d, R, C );
real2complex <<< gridDim, blockDim >>> ( b_d, r_complex_d, R, C );
cufftExecC2C( plan, r_complex_d, r_complex_d, CUFFT_INVERSE );
cufftExecC2C( plan, r_complex_d, r_complex_d, CUFFT_FORWARD );
complex2real <<< gridDim, blockDim >>> ( r_complex_d, b_d, R, C );
qpskDemod <<< gridDim, blockDim >>> ( a_d, Lookup_d, b_d, R, C );
// Retrieve result from device and store it in host array
cutStartTimer( timer4 ); // start cudaMemcpy timer 2
cudaMemcpy( a_h, a_d, sizeof( float )RC, cudaMemcpyDeviceToHost );
cutStopTimer( timer4 ); // stop cudaMemcpy timer 2
printf( " %f ms\n", cutGetTimerValue( timer4 ) );
cutStopTimer( timer2 ); // stop GPU timer
#endif
// Print results
// printf( “\n x. y data value: real part: imag part:\n” );
// for ( int i = 0; i < R; i++ ) {
// for ( int j = 0; j < C; j++ ) {
// printf( “%3d.%3d %11f %12f %12f\n”, i, j, a_h[ iC + j ], b_h[ iC + j ].real, b_h[ i*C + j ].imag );
// } //end for
// } // end for
printf( “\nCPU calculation time: %f ms\n”, cutGetTimerValue( timer1 ) );
printf( “GPU operation time: %f ms\n”, cutGetTimerValue( timer2 ) );
printf( “GPU calculation time: %f ms\n”, cutGetTimerValue( timer2 )-cutGetTimerValue( timer3 )-cutGetTimerValue( timer4 ) );
printf( “\nLookup Table:\n” );
for ( int i = 0; i < 4; i++ ) printf( “%2d real:%10f imag:%10f\n”, i, Lookup[ i ].real, Lookup[ i ].imag );
//printf( “\nGrid size: %2dx%2dx%2dx blocks (2D max)\nBlock size: %2dx%2dx%2dx threads (3D max)\n”, gridDim, blockDim );
// Cleanup
printf( “\nCleanup memory…\n” );
free( a_h ); cudaFreeHost( a_d ); free( Lookup );
free( b_h ); cudaFreeHost( b_d ); cudaFreeHost( Lookup_d );
cudaFreeHost( r_complex_d );
cufftDestroy( plan );
// Exit
printf( “Shutting down…” );
cutilExit( argc, argv );
} // end main
[/codebox]
