Hi! I am modifying a simple SWE (Shallow Water Equations) 1D in order to use PGI Accelerator 11.6 (and Visual Studio 2008) on a nVidia Tesla C2050.
The code has a structure like this:
CALL sub1
CALL sub2
DO i = 1,N
CALL sub3
CALL subM
END DO
I have used “!$acc reflected” and “!$acc region do” in every subroutine inside the DO loop (since those subroutines consist essentially of one or more DO loops):
MODULE mod3
CONTAINS
SUBROUTINE sub3
!$ acc reflected(arr1,...)
!$acc region do
DO i = 1,N
END DO
!$acc end region
Then I created a “!$acc data region copy” outside the main program DO loop to avoid continuos data transfer between the host and the device:
CALL sub1
CALL sub2
!$acc data region copy(arr1,...)
DO i = 1,N
CALL sub3
CALL subM
END DO
!$acc end data region
The results I obtain with the accelerated code are different from the non-accelerated code. It looks like values in the arrays are not being updated correctly. I also tried “mirror” and “update device” (bedore entering the main program’s DO loop) combination, but i get an error (about copying datas from host to device).
I’ve uploaded the zipped VS 2008 project on MediaFire since it’s a little bit long and it would have appeared as a mess on this post:
http://www.mediafire.com/?pobzr88jeaglzct
Thanks in advance for the help,
Nicola
