I try to find out if modifications I did on a kernel gives me better or worst performance. I run the kernel several hounds times and use the average time it needs to compare the different kernel. I guess that these timings depends on the core and memory clock values. Since the core clock drops if the temp of the gpu increases I get better results when I start with a cool gpu than I will get with a hot one. So this way to compare kernel performance is not very objective.
Is there a better way to find out which kernel performs better independent from core/mem clock and gpu temps?
Not all of the nvidia-smi commands mentioned in the document, are supported on some Geforce cards and although the document only mentions the “Lock clocks to base” setting in Nsight Graphics, there is a similar setting in Nsight Compute.
